Question about Hasbro Playskool Helmet Heroes Motorbike Police Officer
I bought this from goodwill don't know how Mic works
How do I connect my used keyboard? I purchased it at Goodwill and I cant seem to get it to work. Thanks. K
Many things bought at goodwill were thrown out because they quit working . you quite possibly bought junk
Apr 02, 2016 | Computers & Internet
My mic recently has just stopped working
I don't want to insult your intelligence but experience makes me ask, 1 be sure it isn't muted in your audio board program and 2 make sure you didn't plug it I to the speaker jack or another jack by mistake.
Apr 03, 2015 | DreamGear Prime Solo Black Wired Gaming...
My flatscreen tv is flickering and audio sometimes doesn't work. the screen goes black sometimes and when that happens the audio doesn't work
maybe your tv is old. If your tv was from goodwill or you had it for a long time....that might happen.if ya just bought it from a store that is not like goodwill nvm.
Oct 26, 2013 | Televison & Video
Hello There, I just bought the Rode NT1-A, and I am trying to record in protools, but i'm not getting any levels whatsoever. I'm plugged in to an MBOX, in the XLR, I have Phantom Power turned on,...
It sounds like you have done everything right. It would be a good idea to check both the mic and Protools system separately. If you can, verify that the mic works using another device such as a mixer. Also try getting a level into Protools using another mic, preferably a dynamic which doesn't require phantom power. If you are trying to use an original MBOX under Windows 7 or the latest version of OSX then it may not work at all.
Sep 19, 2011 | Rode NT1A Professional Microphone
I have a General Lee radio. Bought it used from a pawn shop for a really good price ($70, don't think they know what it is). I turned it on worked great, for maybe 12 hours off and on. The next day it...
depending on how old it is, it could have bad caps. Could be the switching transistor, mic... Any number of things. It is the kind of thing where you have to start checking things down the line looking for the issue. Start with the simple things like the mic, cold solder joints. Look for obviously burnt parts. After that it gets a bit more technical checking parts in the TX section.
Hopefully its just a bad mic wire which would cause the radio to have no RX. Try a new mic. Good luck!
Aug 11, 2011 | Radio Communications
Hello, i've just bought a sure sm58 mic so i thought i would get a good cable to go with it, i purchased a (Planet Waves 10 feet Custom Series 1/4 inch XLR Balanced Microphone Cable) but when connected...
Where do you connect the 1/4 inch connector? At the same device (karaoke)?
Also check and report if the 1/4 inch connector is "mono" or "stereo"
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 16, 2011 | Shure SM58 Professional Microphone
My iLIVE mod# IT188b will not turn on.... reset button not working either??? this is the second unit I have had(first one did the same thing)but was able to return without reciept...not the case this time!...
This particular unit has issues with bad solder connections on the main audio board which come loose because the woofer speaker vibrates them loose. I've repaired unit myself with a soldering iron.
Dec 02, 2009 | GPX 2.1 Speaker Bar with ipod Dock ...
Hasbro Playskool Helmet Heroes Motorbike Police Officer Logo
26 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
