Question about Cell Phones
My iphone will not charge or power up. I have the battery showing on screen with the red and the "bolt" icon showing that it is charging. I have been charging for 24 hrs and it will not charge or power on. How do I get this resolved??
  • 4,102 Answers
Hi, you have got bad cells in your battery and this is preventing it from holding any charge all you need to do is get the battery replaced and this will solve your problem, this is a common problem and usually happens if the battery or phone has got hot, but replacing the battery will solve your problem.
let me know how you get on or if you need further assistance ok
plz rate this solution as i have a whole page on unrated posts, thanks
Posted on Aug 27, 2010
Show charging symbols
Your question was posted under the Nuvi 680 GPS, so I am assuming this is the model that you have.
On the main screen, you will see a green battery status indicator in the upper right-hand corner of the screen. The battery is divided into 4 parts. Each part represents 1/4 power. So if you have one green bar, that indicates that the battery has 1/4 of power left. If there are 3 bars, that indicates that there is 3/4 power left.
When the unit is charging, you will see a yellow lightning bolt appear over the green battery status icon.
When the lightning bolt is not there, this means the unit is running off of the battery.
When leaving the unit to charge, press and hold the power button until you see that the screen says Charging Battery. A few seconds later, the screen will go blank to save energy.
Pressing the screen again later will either say Charging Battery or Battery Charge Complete.
Mar 26, 2013 | Garmin Nuvi 680 GPS Receiver
I have had my iphone less than a week- i did not expect it to have problems so soon. .... i have iphone 2g my battery ran out now it wont recharge or turn back on? .... but it doesn't turn on, it...
If your iPhone's battery runs very far down, the iPhone won't turn on. That's because it's using its remaining battery life to preserve your data and settings.So, your iPhone could be refusing to turn on because its battery doesn't have enough juice. In that case, plug your iPhone into a wall charger or into your computer (plug it directly into the computer; some USB ports on keyboards don't have enough power to charge iPhones). Let it sit for 10-20 minutes. If it was low on battery and needed a charge, when it's got enough juice to power the screen, it will turn on and show you its charging status, starting with the red battery icon.During this process, you may also want to make sure there's no lint packed into your cable or the iPhone's dock connector. This isn't a hugely common problem, but a lot of pocket lint could interfere with the iPhone getting a charge.
Jun 28, 2011 | BoxWave Corporation Apple iPhone 2G...
My iphone is not showing the chargfing icon yet it is charging, slowly
You may please keep in mind that iPhone battery may drain instead of charge if iPhone is connected to a computer that's turned off or is in sleep or standby mode. If you charge the battery while syncing or using iPhone, it may take longer to charge. About not showing the charging icon, please try resetting the phone by pressing the Sleep/Wake Button and the Home Button both simultaneously after which the phone restarts after some time with apple logo on the screen. -- MS Ramakrishna
Oct 13, 2010 | Apple iPhone Smartphone
IPhone won't charge - stuck in screen with battery and bolt
i have the same problem with my iphone 3gs 32gb have you found something that has worked? ive tried everything let me know if u find a way!! please!
Dec 29, 2009 | Apple iPhone Smartphone
Iphone wont charge
plz change ur baterry ur charger
Sep 15, 2009 | Apple iPhone Smartphone
My i-touch is chirping and only icon shows up on screen
take it to an apple store? or you can try pluging it in to ur computer.
Sep 04, 2009 | Apple iPod touch
My iphone does not want to start up PLEASE HELP!!
sounds like you either need a new powerpack or a new battery :( sorry
Jun 24, 2009 | Apple iPhone (16 GB) Smartphone
My iphone won't sync with itunes. it did at first but now keeps coming up with an error I have an original iphone, never been jailbroken or any such thing, and can not currently get it to sync with itunes...
Recharge
Make sure iPhone is charged. Connect to a USB port and look for the lightning bolt battery icon in the upper right. If you don't see this icon, then iPhone is not charging. The battery will charge to 80% in an hour.
Note: If you put your computer into sleep mode while iPhone is connected via USB, iPhone may not charge.
This screen means to keep iPhone connected so it continues charging. Please note:
If iPhone is not sufficiently charged it will not show up in iTunes
Use a high-power USB port such as the one on your computer, or use your iPhone AC adapter.
Don't use the USB port on your keyboard because it is a low-power port and iPhone will not charge.
Make sure you are using USB to charge. Accessories that use FireWire to charge are not supported with iPhone.
If you see the red part of the battery image flash three times and then the screen goes black, it means that iPhone is not receiving power to charge.
If the above steps dont resolve follow the following steps :
Retry with a different USB port.
Note:
Restart
Try restarting iPhone. To turn it off, press and hold the Sleep/Wake button until the red slider appears. Slide your finger across the slider to turn off iPhone. To turn iPhone on, press and hold the Sleep/Wake button until the Apple logo appears.
Does iPhone appear frozen or stuck? Try pressing and holding the Home button for at least 6 seconds to close a frozen application. Then try restarting iPhone again.
Note: If that doesn't work, try restarting your computer.
Reinstall
Reinstall iTunes 7.7 or later.
Get the latest version of iTunes (7.3 or later) from http://www.apple.com/itunes/download/
Thanks.
Oct 21, 2008 | Lands Phones
Iphone won't charge and now won't work
I left my phone charging for a few hours and it appeared not to be charging as the battery icon was staying at 10% of charge. I was confused because it had the charging icon in the upper right hand corner. If your phone is doing something similar i simply powered the phone down and turned it back on. The charge went from 10% to 100% on the display. This is what worked for me hope this helps.
Jan 22, 2008 | Apple iPhone Smartphone
Cell Phones Logo
51 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
