Question about Mastech 19-range Digital Multimeter Dmm Mas830b
Explain the ramp type dmm - Mastech 19-range Digital Multimeter Dmm Mas830b
    Master:
  • 683 Answers
How do you check air conditioner fuses on a 2001 pontiac bonneville?
  1. Get a DMM (Digital Multimeter);
  2. Set the DMM to "OHMS" (any range, doesn't matter);
  3. Remove any fuse you wish to test from the fuse block on the car;
  4. Place the two probe ends from the DMM on the two terminals of the fuse.
  5. Read the display on the DMM. If you get a numeric reading (usually between 0 and 5 ohms), your fuse is good. If the DMM does not measure resistance (open circuit), the fuse is blown.
Jul 22, 2014 | 2001 Pontiac Bonneville
Tip
Safety concerns with car ramps.
Alot of people feel just a little bit uneasy when it come to getting under a car when on car ramps. A little trick is to drive the car on the ramps, put blocks, or wheel chucks behind the grounded tires. Then using a jack, jack one of the ramped tires up enough to remove its ramp. Reverse that ramp and then lower the vehicle down. It can't roll down the ramps because it is wheel locked inplace. Please though reverse that prcedure to drive it off the ramps.
Please note, I selected Chevy as the manufacturer only because 'any' is not an option
on Dec 08, 2009 | Chevrolet Chevy Cars & Trucks
How to check scooter batteries
Remove the seat. Remove the cowling that covers the battery. Batteries should be accessible now. Use a Digital Multi- Meter or DMM. A simple battery meter will not take the 24v current. Set the meter on volt; at the 100 scale and read the meter. voltage output will read on the screen. How to Find Problems in 24 Volt Electrical System eHow Link is to page that explains how to use the meter to find your issue. If you have a 12volt system the procedure is the same.
Mar 04, 2014 | Pride Health & Beauty
True treadmill 850p e3 EEPROM code
Normally the E3 is problem with the sensor speed.
Use the DMM tester, and prove the sensor with some metal and connect the DMM, with the 2 wires from sensor, if the Dmm in continuity mode BEEP, the sensor is Good, If NOT beep, the sensor is Faulty, Replace.
Blessing.
cuadra2016@yandex.com
whatsapp:+50588611441
Dec 16, 2013 | Exercise & Fitness
I have a UPS 1000 VA with 12 V X 2 Battery, Problems: when we on ups input 200 V without load, it gives output 210 V. when load it gives 230 V on electricity. When Electricity cut off it gives 250 V. When...
arif qc, Are you using a DMM that is or will make "true RMS" measurements or is it an "average responding" type of voltmeter? Is this APC ups designed for 120 vac input/output or is this unit a 220 vac input/output type? Use only a "TRUE RMS" type DMM to make your measurements!!! I believe if you visit Tripp-Lite site, you will find a tutorial video clip of why you should use a true-rms meter to make measurements of output voltages. 12fixlouie
Sep 07, 2010 | APC Smart-UPS 1000VA UPS System
I have two pieces a ramp from which car is supposed to take off, and one for landing. But i cannot see how they connect to the rest of the track
Just had the same issue and have figured it out! Build the complete track as normal, and the ramp just clips onto the track in your desired location! If you want to see a pic of what i mean just type scalectrix leap ramp into google image search
Merry Xmas
Dec 25, 2009 | Scalextric Toys
COD5 cant connect with friends online matches
its probably the rate of connection between your friends and you if so you should try switching to wireless or wired connection hope this helps=/
Oct 01, 2009 | Dmm Call of Duty: World at War
Dmm v twin
The manufacture has clearly defined that this device is designed for 8 mm to 10.5 mm ropes. This type of belay device works on friction, so by adding the extra thickness of a 11 mm rope, increases the friction on the device, thus heating it faster, and possibly taking it to premature failure. I have contacted the manufacture directly for their imput on this subject, and will update you once they respond.
Apr 04, 2009 | Dmm V Twin Belay Device
Mastech 19-range Digital Multimeter Dmm Mas830b Logo
62 people viewed this question
Top Mastech Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Paul Woodward
Are you a Mastech Measuring Tool and Sensor Expert? Answer questions, earn points and help others
