Question about Kenmore 71279 Bottom Freezer Refrigerator
Kenmore model 795.7500401 need to know cu sq ft
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote that tells you how to figure out how big your refrigerator and/or your freezer is...
New Refrigerator Size or Refrigerator Cubic Feet
Heatman101
Posted on Aug 28, 2010
I need to know how much stone in tons I need to fill 8.5 acre at 1.5 ft depth
Stone is approximated at about 2700 lbs. per cu. yd.
An acre is 43560 sq. ft.
8.5 acres is 370260 sq. ft.
There 9 sq.ft. per sq. yd., thus there are 41140 sq. yds. in 8.5 acres.
A cubic yard is 3 feet by 3 feet by 3 feet (LxWxH).
Since you are only going to be at 1.5 feet, each square yard is equal to 1/2 cubic yard, so to figure the cubic yards divide sq.yds. by 2, thus you get 20570 cu. yds. of stone.
20570 x 2700 = 55539000 pounds. Divide by 2000 to get tons:
55539000/2000 = 27769.5 tons.
Nov 16, 2016 | Office Equipment & Supplies
How many cubic feet for 1560 square feet 2inches deep?
2" out of 12" is equal to 2/12 feet; or 0.16666 feet.
1560 sq ft x 0.166667 ft = 260.00052 cu ft; or 260 cu ft
Apr 08, 2015 | Rubber Landscape Mulch Mocha Brown
Convert 30pounds per sq.foot to pounds per cubic foot(concrete=150#/cubic foot at 1in. thick conc. slab).
These are not the same, so cannot be directly converted.
Pounds per sq ft is a measure of pressure, while lbs / cu ft is a measure of density, weight per unit volume.
I think maybe what you are doing here is converting the weight of concrete in a 1" slab, where a sq ft would contain
1 x 1 x 1/12 = .0833 cu ft
The figure of 150 lb/ cu ft is correct for the average density of concrete, so the above slab would have
1/12 x 150 = 12.5 lbs/sq ft at 1" thickness
BTW that is a thin slab of concrete, insufficient even for a light-duty pathway. If you are referring to a screed for tiling or similar, that is cement.
Mar 01, 2015 | Office Equipment & Supplies
Dimensions
This model is a 25.6 Cu. Ft.
Height to Top of Hinge: 69 1/4"
Height to Top of Case: 68 3/4"
Case Depth w/o Door: 28"
Case Depth less Door Handle: 32 1/4"
Case Depth w/ Door Handle: 34 7/8"
Depth w/ Fresh Food Door Open 90°: 50 1/16"
Width: 35 3/4"
Width w/ Door Open 90° w/ Door Handle: 42 3/8"
Air Clearances - Each Side: 1/8"
Air Clearances - Top: 1"
Air Clearances - Back: 1"
Approximate Shipping Weight: 360 lbs.
Capacity
Total: 25.6 cu. ft.
Fresh Food: 16.02 cu. ft.
Freezer: 9.59 cu. ft.
Shelf Area: 22.4 sq. ft.
Dec 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Spacks on 15" orion 2 xtreme sub
Here are the Specs from Orion's spec sheet.
Sensitivity @ 2.84V/1m 93DB
FS 23Hz
QMS 9.05
QES 0.47
Qts 0.44
BL (Force Factor) 8.7 TM
SD (Piston Area) 500 sq.CM \ 78 sq. in.
VAS (Volume Acoustic suspension) 224 Liters \ 7.92cu.ft
Xmax 7.75MM \ 0.30 in.
Enclosure Recommendations
Sealed Volume 1.60 cu. ft.
Vented Volume 2.75 cu. ft.
Port Dia (Inside Dia.) 4 in.
Port Length 8.5 in.
Nov 07, 2009 | Orion Xtreme XTR15d Car Speaker
8 inch woofer blown need specs...OHM, Impedence and wattage
John,
Checkout JL Audio's 8" subs I'll leave specs at the bottom, if you want to look around for something cheaper check out this install I did on a Jaguar X-Type. The sub here is a good example of a free air application and you can look for a sub with the same features. Keep in mind however this setup is using a high power Coustic 10" sub and you only need to handle the stock amp- 25 watts. So you may not need such a beefy sub, but something close would be good. If your sub uses a small enclosure go with something like the JL listed below. Good luck and let me know if you need anything else.7a2e6d4.jpg -Dynami
12855.jpg Reviews W1v2 Technologies Recommended Power Chart Tutorials 12856.jpg 8W1v2 DRIVER SPECIFICATIONS 8W1v2-4 8W1v2-8 buyitnow.jpg buyitnow.jpg Free Air Resonance (Fs): 34.55 Hz 36.60 Hz Electrical “Q” (Qes): 0.508 0.612 Mechanical “Q” (Qms): 6.260 6.000 Total Speaker “Q” (Qts): 0.470 0.555 Equivalent Compliance (Vas): 0.66 cu. ft. / 18.801 liters 0.63 cu. ft. / 17.87 liters One-Way, Linear Excursion (Xmax)*: 0.3 in. / 7.6 mm 0.3 in. / 7.6 mm Reference Efficiency (no): Efficiency (1W/1m)**: 83.86 dB SPL 83.58 dB SPL Effective Piston Area (Sd): 32.67 sq. in. / 0.0211 sq. m. 32.67 sq. in. / 0.0211 sq. m. DC Resistance (Re): 4.00 ohm 7.84 ohm Nominal Impedance (Znom): 4 ohm 8 ohm Thermal Power Handling (Pt): 150W 150W Driver Displacement: 0.02 cu. ft. / 0.571 liters 0.02 cu. ft. / 0.571 liters Net Weight: 6.3 lbs. / 2.9 kg 6.3 lbs. / 2.9 kg * Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
** Efficiency (1W/1m) is not an accurate indicator of a subwoofer’s output capability and should not be used as a comparison to other subwoofers to determine which one is “louder”.
acrobat.gif Click here to download the owner's manual (PDF). Click Here For Recommended Enclosure Specifications 8W1v2 DRIVER PHYSICAL SPECIFICATIONS
12819.jpg Nominal
Diameter
Overall
Diameter (A) Mounting Hole
Diameter (B)
Bolt Hole
Circle (C)
Magnet
Diameter (D)
Mounting
Depth (E) 8.0 in. / 200 mm 8.54 in. / 217 mm 7.09 in. / 180 mm 7.85 in. / 199 mm 4.54 in. / 115 mm 3.85 in. / 98 mm 12864.jpg
Apr 06, 2009 | OEM Systems Car Audio & Video
I have a Kenmore washer model 417.44072300. I
3.4 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 27, 2009 | Kenmore Washing Machines
Kenmore 71279 Bottom Freezer Refrigerator Logo
476 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
