Question about KWorld PC to TV (0872880887527) Video Capture
When i hook up my kworld pc to tv model kw-pctv 1600 the monitor is blurry everytime but when i unhook the cable from my monitor and unplug it from the kworld box the monitor resolution goes back to crystal clear state and i have a pretty good monitor all my games play with no problems at all, is there something i am not doing correctly cause the hook up for this product is pretty simple is there something extra needed,please help.
  • 4,924 Answers
I think th eproblem is from the resolution set in the computer ..depending on the video card you have ...look in the tray system (the right side of the task bar ..where all the working programs are displayed) ..and click (right) on the video driver icon ...and on display modes...and change the resolutions until the image is good..Im not sure which one will work cause there are a few there ...but when the image will clear you will know that that is the one ..Just make some trials..
the issue might be that the resolution set is not fitting with the large screen of the TV ..try a larger resolution for it ..
After that if the Icons seams too small just right click on the desktop ..and go to properties...and settings ..(the last one in the right ) ..and advanced and enlarge the icons and the writing ..
you can also change the resolution from the settings here ..
Posted on Aug 28, 2010
I did buy a PC TO TV KW 1600 , when I connect the S-Video cable to TV I don't have any audio from tv. Can you help me
The converter is for video only. To get the audio as well, you'll need to connect a cable from the computer's audio output jack to the TV's audio input. The computer end will need to be a 1/8-inch stereo plug (like the one you'll find on iPod headphones), with RCA plugs for the TV. Here is one from Radio Shack, so you'll know what to look for. Connect the audio to the same AV input as the S-video cable and you'll have both picture and sound.
Nov 28, 2010 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
I have hooked this up with the red/blu and green and only get rainbow on the screen
gumbyliving
There is several things that can cause this problem. To better help you see where the problem exactly is I need to know what 2 devices you are connecting between and how you have them connected.
Thanks
Issken
Feb 21, 2010 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
Pctv does not show anything on tv except colored lines
This may be caused by the inverter board found behind the LCD panel. You need to re-solder the two sides of the coil found on the inverter board.
There seems to be loose connections on the solder probably caused by heat..
Please send us your feedback & vote to help us help you as it should be.
Feb 11, 2010 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
Kworld pc to tv
You may have a bad tube or light if its a projection tv, try a different set of cables first and if you have the same problem, hook up the device to another TV, if it is still red the you know the device is bad, if not, the TV you are hooking it to may not be compatible
Mar 30, 2009 | KWorld KW-PCTV TV Input
Get only black and white picture on TV through converter box
Try fiddling with the PAL/NTSC switches on the back of the device. I got color working by flipping one of the switches about half way towards "On".
Feb 22, 2009 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
I can't get it to work please help....
You may need to switch your laptop monitor to an external monitor using the Fn + F5 keys or similar -see your laptop manual. This will send the VGA signal to the HD-15 VGA connector going to the converter.
The instructions that come with the unit doesn't address this.
Oct 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
Driver installed need to set up tv tuner on windows media center
I uninstalled the cyberlink encoder and tried the mainconcepts encoder. Seems to be working now, although terribly.
Jan 25, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
KWorld PC to TV Converter
I had the same problem. It turned out the issue was that I had the VGA Y-cable connectors between the PC and the KWorld box reversed. They look like they should be interchangeable, but they are not. A closer look at the cable connectors shows that one is marked "PC", one is marked "Monitor", and the 3rd is marked "SCAN CNVTR". Once I got them plugged into the right places, I got the screen image on the TV.
Jan 01, 2008 | KWorld PCTV CONVERTER KW-PCTV-1600 RT...
KWorld PC to TV (0872880887527) Video Capture Logo
136 people viewed this question
Top KWorld Televison & Video Experts
Electro Med Services...
Oluwadamilola Adu
Oluwadamilola Adu
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
