Can't find flash drive on my computer after inserted into USB port.....Comes up saying not in right port..I have transferred photos onto it several weeks ago, but can no longer retrive them from the flash drive...
  • 5,568 Answers
Try removing the USB drives from the Device Manager, then power down, plug in the flash drive and power backup again.
Win should find the drive and reinstall drivers and recognize the drive again.
Despite improvements in the behavior of Widows, it is also still advisable to 'turn off' a removable drive before unplugging it.
If you system is pretty much standard, you should find the drive symbol with an arrow indicating 'remove' on your task bar to the right.
Left-lick on that symbol and it will bring up a short menu of any removable drives and then just click on the one you want to pull.
Posted on May 06, 2008
Windows vista
There were several models made in the Classic format.
Early units had either Firewire or USB ports.
If USB...you would need an External CD Drive that plugs into the port on the player. Drivers would have to obtained from Apple at their web site and copied to a CD. Then a CD with the drivers would be inserted into a USB CD Drive and loaded on tot eh Player. The other solution is to Download the Drivers onto a computer, insert a FLASH Drive into the USB port on the computer, copy the drivers to the Flash Drive, and move the Flash drive over to the IPod's USB port. Copy the drivers or install from the Flash Drive.
Apr 03, 2014 | Apple iPod classic MP3 Player
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
How to install a USB flash drive
Just plug your USB flash drive into the USB port of your computer or other USB-equipped device and drag the files you want to take with you into the folder that appears on your screen. Your files are instantly transferred to your USB flash drive. To transfer the items on your USB flash drive onto another computer, simply plug your USB flash drive into the computer that you want the files transferred to, open the folder that appears on your screen, and drag the desired files onto the computer's desktop.
1.) Insert Flash Drive into the USB Port of your computer.
-Where is my USB port? It is usually found in newer model computers in a hidden compartment on the front of the hard drive and in the back of the hard drive on older computers. The port for laptops is found on the side or back of the computer.
2.) Wait for the hardware to automatically install on your computer.
After the hardware is installed, it is ready to use!
3.) In most cases, an Options Window will automatically open. Select "Open folder to view files" Click "OK."
Jul 19, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
How to transfer photos from computor to flash drive
right click on photo then send to \ flesh drive
Jun 13, 2011 | Office Equipment & Supplies
My photos won't transfer to my computer. The the last time I loaded photos onto my computer which was last week, it worked fine. however today the same computer says it does not recognize the USB device,...
Change the USB port. If you are connecting it to front USB of your computer, try connecting it to USB port at back of computer..
The cable might be fauty.
Apr 11, 2011 | Kodak EasyShare C330 Digital Camera
Want to know how to get photos from my Acer desktop to my Aspire One
With the use of a USB flash drive.
Insert USB drive into Acer Desktop and copy the photos onto it by selecting the photos you want and then right clicking copy. Navigate to USB drive in My Computer, open location of USB removable drive, then right click paste. Wait for the files to copy.
Then right click the safe to remove icon at the bottom right hand corner of your screen (it should be near the system time). Select safe to remove.
Now insert the flash drive into your Aspire One and navigate to removeable flash drive in My Computer. Double click on it. Then select the photos you would like to copy, right click copy, then navigate to location where you would like to store it, right click, paste.
Thats it.
Please rate this solution.
Thanks
Oct 31, 2010 | Computers & Internet
Can I download photos from my computer onto the sandisk? to give me more room on my computer
Sure you can. Just plug the flash drive into a USB port and open it in a Windows Explorer window. Open the directory you want to copy the photos from in another window. Then you can just drag and drop the files from the computer to the flash drive. After you're satisfied that all the files transferred correctly you can clear them off your hard drive.
Mar 06, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I would like to transfer photos' from laptop to cruzer using Window Vista! How to do that?
Hello..
Insert the Cruzer and allow your computer to acknowledge it. You will know this by going to "My Computer" and double clicking. You should see that the computer has assigned a drive letter to it. Double click that drive letter for the Cruzer. With that window left open, find were your photos are. Open the folder were the photos are located. With both windows open you can now drag the photos over to the Cruzer and drop them into the window for the Cruzer.
Good Luck
Jan 12, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I want to put photos from my camera onto my laptop but my laptop is an old one so no disc can i do this without disc no slot for disc
Then Transfer the Photo from the Disk Onto a Flash Drive (USB Storage Drive)... And plug into the old laptops USB port then transfer photos
Nov 15, 2009 | Dell Latitude D600 Notebook
Computers & Internet Logo
137 people viewed this question
David Payne
David Payne
