Question about Garden
How do you replace a fuel throttle cable on a craftsman weedwacker model #358.791141
  • 2 more comments
  • wmorse831 Aug 27, 2010
    i gave you the wrong weedwacker model # it should be 358.791140. sorry
  • wmorse831 Aug 28, 2010
    I was expecting and need a diagram that shows exactly how the cable fits in the handle and trigger!!
  • wmorse831 Aug 30, 2010
    MY PROBLEM IS NOT ON A LAWNMOWER IT IS A CRAFTSMAN WEEDWACKER MODEL #358.791140. I WOULD LIKE A DIAGRAM OF HOW THROTTLE CABLE FITS INTO THE HANDLE AND TRIGGER.
  • 857 Answers
Follow these steps:
Search for the gas tank next to the engine. Follow the fuel hose attached to the base of the gas tank to side of the carburetor on the engine. Squeeze the clamp holding the fuel hose to the side of the carburetor and slide the clamp up the hose a few inches.
Pull the hose off and direct it into the bucket to capture the gas.
Unscrew the red cable from the side of the starter with the proper-sized wrench.
Follow the throttle lever to the throttle linkage on the side of the engine. Unscrew and remove the throttle wire from the side of the engine with the correct screwdriver head.
5
Unscrew the bolts holding the engine to the frame of the riding lawn mower. Position a wrench on the bolt head on top and on the nut under the mower frame. Remove all the bolts.
6
Lean the engine forward and pull the belt off the pulley attached to the crankshaft under the engine. Pull the engine off the mower frame.
7
Place the pipe wrench on the crankshaft area above the pulley under the old engine. Hold the pipe wrench with one hand so the crankshaft doesn't rotate and then put the proper-sized wrench on the bolt holding the pulley on and unscrew it with your other hand. Place the pulley on the crankshaft of the new engine. Screw it on tightly.
8
Place the new engine on the riding mower frame. Slide the belt around the pulley as you set the engine down on the frame. Tighten all the bolts and nuts through the base of the new engine to secure it to the riding mower frame.
9
Reattach the throttle linkage, starter cable and the gas line to the new engine.
Posted on Aug 28, 2010
  • 10,319 Answers
Take the handle apart to remove the cable from the finger trigger
The other end is fairly easy
It will simply weave out of the carburetor.
reverse this proceedure to reinstall
Posted on Aug 27, 2010
  • frank thomas wilson
    frank thomas wilson Aug 31, 2010
    You need a service manual. Most can be found on any GOOGLE search engine with the sears model number
  • 3,083 Answers
For some reason, the model number didn't come up in google, or at the Sear's site. However, I did find Sear's question submittal site, and I would recommend you try to ask them, since they have the diagrams, manuals, etc. Here's the site page:
http://www.sears.com/shc/s/v_10153_12605_Lawn+%26+Garden?adCell=WH
I tried to find a diagram, but had no luck. Perhaps this will be of assistance to you. Good luck, and thanks for using FixYa.
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Managemylife com
1.You have to remove the air filter *** cover.
2.Remove air filter.
3.Remove 2 screws, to remove the rest of air filter ***.
4.Remove the 2 fuel lines with a long nose plier.(Take a photo of
the position of fuel lines or mark fuel lines for reassembly)
5.Unhook the throttle cable.
Now to fix the Carburettor
1.Remove the 4 screws on primer bulp side of the carburettor.
2.Open the carburettor and clean with paint brush and clean fuel.
3.Replace diaframe kit(available from your nearest dealer) and reassemble the trimmer.
Dec 30, 2013 | Craftsman WeedWacker Gas Trimmer 29cc...
Manual for a craftsman weedwacker model 31679108
Trimmer Starts but stall out as soon as throttle is used and choke turns off. if I hold the throttle and pull the choke it runs but will stall as soon as choke is let go.
Jan 31, 2011 | Craftsman 27cc 2 Cycle Crank Straight...
Replacing throttle cable on craftsman weedwacker
how does throttle cable attach under the carberator?
Sep 20, 2010 | Craftsman Garden
Craftsman model 358.791042, gasoline weedwacker wont stay running
let it warm up first and then pull the trigger. if that doesnt work, it might be the diaphram . they are cheap.
May 10, 2010 | Garden
Craftsman line trimmer model 358791560 fuel issues
clean the carb really good. you can resoften the carb diaphrams by cleaning them with carb cleaner and rub them and dry them off then use some dish washing soap and rub them for a couple minutes. then just wipe it off. also make sure the screen in the carb is clean. you can burn the screen off to make sure its clean.
May 03, 2010 | Craftsman 25cc Gas Line Trimmer
The high speed needle valve needs adjusting and it takes a special splined tool to adjust it. I currently am trying to find where I can purchase the tool to adjust the high and low carburator screws.
Mar 17, 2010 | Craftsman Garden
Garden Logo
395 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
