Question about GE Dishwashers
I have a GE Profile Performance Dishwasher. Triton: Triclean Wash System Quiet Power III. Every morning when I open up the dishwasher to empty the clean dishes there is about 2 inches of water at the bottom. What can I do to fix this problem?
5 Suggested Answers
  • 32 Answers
SOURCE: Dishes not thourghly cleaned on top sheelve
generally dishwashers rely on the pressure supplied by the water supply line. check to see if it is enough or if inlet pipe is of sufficient diameter for needed flow.in some instances i know of seperate lines needing to be run directly instead of coming off of supply to sink area.
Posted on Apr 07, 2008
SOURCE: GE Profile Triton Triclean wash system - quiet
I hit the pump with a hammer and it started washing and continues to do so. Thanks
Posted on Nov 16, 2009
SOURCE: dishwasher door lock does not unlock on my GE quiet profile 3 dis
Sounds like you door safety interlock switches, are faulty, these can be easily replaced, at reasonable cost.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=replace-door-switch
http://www.rd.com/how-to-repair-a-dishwasher/article18243.html
http://www.ehow.com/how_5676347_replace-door-switch-dishwasher.html
A DIY links above. it is pretty easy, you may even be able to adjust your one too.
Posted on Apr 06, 2010
SOURCE: our quiet partner III dishwasher is not working. ...
Our whirlpool gold quiet partner iii dishwasher is not working well . It is not gettting dishes cleaned soap left on dishes on top primarily
Posted on May 31, 2010
Our GE Triton TriClean III didn't drain, and now won't even give me an "on" signal when I lock it. Is it dead?
Check the circuit breaker before you make any hard-and-fast decisions. Find the appropriate circuit breaker, turn it off, wait fifteen seconds, then turn it back on. Now try it.
Aug 12, 2014 | Dishwashers
Dishwasher door lock does not unlock on my GE quiet profile 3 dis
Apr 06, 2010 | Dishwashers
Good evening, under the cycle selection buttons on our GE Profile Triton Triclean Model number : GSD5130D02WW , we are not able to select any of the cycles. The dishwasher activates on the rinse cylce only...
The fact that it does work (briefly) on one of the cycles but not on any others, points pretty strongly toward the control board. It's a pretty expensive part, so before you buy it you need to open up the door panel, and make sure that it hasn't come loose from the pieces inside, which would prevent it from making contact with the buttons on the front.
Of course make sure that the breaker to the unit is off, or unplug it, if possible.
Apr 15, 2009 | GE Dishwashers
No power or functionality - DOA
Ensure power is available to the unit, check the door switch for proper operation
Mar 23, 2009 | Dishwashers
RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Mar 22, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
GE Triton Dishwasher won't stop running
try to reset the circuit braker--remove all power.
Aug 27, 2007 | Dishwashers
Dishwashers Logo
97 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
