Question about Sony Cameras
My Sony DSC-W130 does not start even when battery is charged properly. It closed when we were watching photographs on TV and the shutter remained unclosed. After that it won't work at all. Please advise how to solve the problem. Thanks Juhi Gupta
My memory card not working and showing the msg re insert memory card what to do? please suggest me.
Posted on Aug 30, 2010
  • Sony Master
  • 17,130 Answers
It is possible that the camera has hung up and might need a reset.Remove the battery and keep aside. Now remove the memory card also . After about 30 minutes while putting the battery back hold down the Ok/menu button and switch on. Now if the shutter closes back the camera is reset. Now you can reinsert the memory stick.
however if the fault does not clear repeat the process with longer duration .If it does not work then refer the camera to the Sony service without much tampering.
Posted on Aug 27, 2010
Wheres reset button on sony cybershot dsc w130???
I'm glad to provide the information about the Camera. The Camera does not have a RESET button to press manually to reset it.
If you wish to reset the Camera, you can use the Initialize option from the Menu item to perform it if the Camera is allowing it.
Please perform a power resetting if the Camera is not turning ON or you're unable to access the Menu items. Please follow the below steps to perform a power resetting
  • Remove the battery from Camera.
  • Press and hold the Power button for more than 15 seconds.
  • Reinsert the battery
  • Turn ON the Camera.
Thanks for understanding. Please let me know if you require further assistance.
Sep 12, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
My Sony CybershotDSC-P200 camera works when it is plugged in, and the screen shows that it's charged. But as soon as I unplug it, it won't even turn on. Is there anything I can do to fix it? Would...
hi you might check battery first. sometime battery goes bad. if not then main pcb is the problem. your local repair shop could charge around $50 depend on what they really want to charge. Thanks...best regard!
May 21, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Problem with the Sony Cyber-shot DSC-W130 Digital Camera I am facing a problem in my SONY Cyber-Shot DSC-W130.When i m pressing the power button, then the lance continually up & down . After some...
it is just because there is something which is moved from within. . may be due to a fall or a hit. . so that thing is obstructing ur lens and the lens cant close. . so u will have to get it opened by an authorized service man and it will be done. . no other option. .
Mar 31, 2011 | Sony Cyber-shot DSC-W130 Digital Camera
Every time I power on the camera it goes into the setup menu to set the date and time. I've gone through the settings and am unable to prevent it from doing this
Are you taking the battery out for any reason? Taking the battery out for an extended period of time will sometimes reset the time/date settings.
Mar 24, 2011 | Sony USB Cable (D3F01007) for Sony...
I want to use my DSC-W130 Digital camera as web cam also can it be done? if yes, then please tell me how?
No. The DSC-W130 is designed to store images (and videos) to memory, not to stream live video to another device.
Sep 17, 2010 | Sony Cyber-shot DSC-W130 Digital Camera
Battery compatibility error, even tho it came with camera!
Try clean contacts of camera for battery and contacts of the battery also, specially the middle one - it is for communication between camera and circuit inside the battery. If the problem persists, try use another battery in your camera, or your battery in other compatible product - you determine this way if the problem is inside the battery (I hope, it is cheaper) or inside the camera.
Aug 23, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
Shutter of camera not opening up .sony camera model no DSC -W130
You may be need to replace lens cover (barriel block) in this camera.
let me know if you have camera repair experience to provide you further info.
Jan 30, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
How long time I churge "SONY NP-BG1 Battery
The first charge you should let it go overnight, so it has a good solid charge. After that it depends on the mAH of the battery, the higher the number, like 1400, it should take about 3 hours. There should be a led light on the charger, its red when charging and turns green when completed. The chargers have a voltage regulator on them, so that you can't over charge a battery.
Jan 08, 2009 | Sony Cyber-shot DSC-W130 Digital Camera
My sony cybershot dsc-w130 doesn't seem to be charging.
DSC-W130 camera battery doesn't charge via USB.
It has individual battery charger which plugged in AC.
You can see battery charger in user manual.
Dec 12, 2008 | Sony Cyber-shot DSC-W130 Digital Camera
HI. My Sony Cybershot dsc-w130's battery has been uncharged for a couple of months now. I just found the usb connector for it and am trying to charge, but it doesn't seem to be taking a charge. Do I just...
I just replied your question ...
Thank you.
Cameras Logo
55 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
