Question about Casablanca Fan Stealth 3211T Ceiling
The glass light cover falls off when the fan is on. I have made certain that the cover was screwed in properly but the vibration of the fan loosens the cover. Any suggestions?
  • 377 Answers
I would first tighten any screws that might be part of the vibration problem. They do work loose. As far as the globe goes, sounds like you might need some kind of spacer material between the glass globe and the frame it screws into. Perhaps a few pieces of small clear plastic hose. Try and wedge them between the globe and metal frame when screwing the globe back on. Make sure it is snug, but do not over tighten to the point where the globe breaks.
Posted on Aug 29, 2010
I am unable to remove the glass globe on the fan to replace a burned-out light. Do you turn to right or left to remove. Is there a trick to it?
is this a ceiling fan perhaps if so there are 4 little screws that hold gloobe up try lifting the globe some while you loosen screws
Mar 08, 2015 | Dryers
Broken glass cover. i need a replacement and can't find it anywhere
I'd love to think that Home Depot would be able to help you but it seems they have no memory of this awesome ceiling fan. I bought it for my first house and wish I could even find a photo of it now. If memory serves it had a somewhat shallow globe, similar to many of the Hampton Bay fans. My suggestion would be to carefully measure the diameter you need, understanding that it stays in place by means of the insertion screws. Then find a replacement that fits among Hampton Bays current offerings. I'm certain it's possible. Such a shame they no longer sell this extremely cool looking and enormous fan. Cheers.
Jun 26, 2014 | Hampton Bay 04345 Cruiser Ceiling Fan
How do I uninstall a ceiling fan?
Turn the power off, to be safe i recommend turning it off at the breaker box, there should be a list on the onside of the panel door showing what switches operate what. or you can simply leave the wall switch that operates the fan in the off position if you're sure nobody will turn it on. If fan has a light remove the glass bowl over the bulbs, should be three screws it the top of the glass fixture, loosen them with your fingers, if they are to tighttry pushing up on the bowl from the bottom to relieve pressure off the finger screw. Remove light bulbs then unbolt each fan blade, once the blades are off remove the motor cover should be one small screw at top of the cover close to the ceiling, once the screw or screws are removed if the cover does not come down you may need toturn it using both hands, it only needs to turn a little bit and no need to be gentle. With the motor cover off the mounting bracket should be easy to spot. Some brackets only have one srcew on one end and a tad that slides into a slot on the upper bracket, by removing the one screw this will allow the motor assembly to swing down but still be attached to the bracket for support. Whith the motor hanging the wiring in the fixture box in the ceiling should be visible, pull the wires out of the box so ythat the wire nuts are accessible. there will bee three wires coming from the fan, one screwed directly to the box or bracket, loosen the screw with a screwdriver and pull the wire from the box, the other two wires attached to wires with wire nuts, one at a time remove the nuts by twisting them off with your fingers, pull the wires apart and twist the wire nut back onto the wires coming from the box in the ceiling, the fan should now be disconnected. romove the motor from the brack by turning it 90? and sliding the tab out of the slot in the upper bracket. remove the upper bracket piece from the fixture box. Now that you have done this installing a new light fixture should bea breeze for you.
the video shows a different easier type of fan removal. There are numerous types of fans and how they are mounted, i hope this helps you
Apr 09, 2014 | Dryers
Maytag over range rattling and vibrating noise
Make sure you tighten all the attachment screws that may have loosened during long term usage. Make sure the fan is running properly and not causing undue vibrations. Use WD 40 on the fan.
Mar 15, 2014 | Maytag Appliances Over-the-Range Microwave...
How do I get the cover off to change the light bulb?
Depending on the fan you have a couple possibilities. If the Glass has a knob, or metal piece in the center on the bottom then unscrew this to remove. If not, then Look at the top of the glass, where it meets the fan. If there are three, or four small screw you loosen these and the the glass will come off. If you see none, or just one, then the glass should either unscrew, or twist and unlock.
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
Whow to replace lamp on tv sony kdf-e60a20
Follow this procedure to replace the lamp:
1. Turn off the power on the main unit. Wait several minutes, then unplug
the power cord.
(The cooling fan will continue to operate for about two minutes after
turning the power off.)
2. Wait at least 30 minutes after unplugging the power cord to allow the
lamp to cool down before replacing it. To avoid being burned, do not
touch the lamp receptacle once the lamp has been removed.
3. Take the new lamp out of the box.
Do not touch the glass portion of the new lamp.
✍ Do not shake the lamp. Vibration can damage the lamp or shorten
its life.
✍ Avoid touching the front glass of a new lamp or the glass of the
lamp receptacle. This may reduce picture quality or lamp life.
4. Loosen the screws on the rear side panel.
5. Remove the front panel.
6. Pull out the lamp.
Loosen the right screw on the cover with a coin or similar object.
Remove the screw from the lamp cover. Pull down the cover toward you.
Unscrew the lamp and pull out the lamp horizontally.
✍ The lamp is very hot immediately after use. Never touch the glass
portion of the lamp or the surrounding parts.
✍ After it has cooled, place the used lamp into the empty box of the
replacement lamp. Never put the used lamp into a plastic bag.
7. Place the new lamp into its place, then tighten the screw.
Mount the new lamp securely. Failure to mount correctly may cause a
fire or the screen to go dark.
Push the cover back on. Make sure that the hole on the cover aligns with
the hole on the unit. Reattach the lamp cover by tightening the screw.
✍ If the lamp cover screw is inserted incorrectly, the lamp may not
operate properly. In such a case, remove the screw, insert it
correctly and then tighten the screw completely
✍ If the lamp cover is not reattached securely, the self-diagnostic
function may be triggered and the POWER indicator flashes three
times
8. Reattach the front panel securely.
9. Tightly screw the side panel in its place.
That is it. Thank you.
Nov 29, 2009 | Panasonic PT-50LC13 50" Rear Projection...
I don't have an owner's manual for my wd 60735, but I need to change the bulb. whatt are the steps I should follow?
Removing the Old Lamp Cartridge
Turn off TV power a 1. nd allow the lamp to cool for at
least one hour before proceeding.
2. After the lamp has cooled, remove the cover of the
lamp compartment, located on the back of the TV.
Refer to figures 1 and 2. Use a #2 (large) Phillips
screwdriver to loosen the screw securing the cover.
Keep the screw and cover for re-installation
3. With a large Phillips screwdriver, loosen the two
shiny screws securing the lamp cartridge until they
disengage from the mating threads. These are
captive screws and cannot be separated from the
lamp cartridge.
4. Fully open the bag supplied with the replacement
lamp and set the opened bag aside.
5. Gently grasp the handle of the lamp cartridge and
pull the old cartridge straight out. See figure 3.
CAUTION: Do not tilt or rotate the cartridge, as
small glass fragments may fall out.
6. Without tilting or putting down the lamp cartridge,
insert it into the opened bag. Close the bag while
being careful not to let any glass particles fall out.
Installing the New Lamp Cartridge
1.
Do not touch the glass parts of the new lamp cartridge.
Insert the new cartridge into the TV in the
same orientation as the old cartridge. Push on the
cartridge housing until it is fully seated.
2. With either your fingers or the screwdriver, gently
tighten the two shiny screws. If using a screwdriver,
AVOID OVERTIGHTENING!
3. Replace the plastic cover and retaining screws.
4. WASH YOUR HANDS THOROUGHLY, AS THIS
LAMP CONTAINS MERCURY.
Nov 11, 2009 | Mitsubishi WD-60735 Projection Television
Fan works but light does not I have replaced the bulbs but still not luck
hi there,
the common problem on this is the connection on the terminal receptacle is loosening where the wire source for your bulb,only way to repair this is to pull out the fan from ceiling make sure to disconnect source and unplug from circuit breaker, and have repair on ground,on the bulb housing loosen screw to dismantle cover and receptacle appear,then rotate counter clockwise the top knob of receptacle and remove you will see the bolt terminal,make this tighten by flat screw driver the bolt where in wire for bulb was connected,loosening on terminal is due to vibration when fan rotate.have a nice day and don't forget to rate me,thank's
Apr 27, 2009 | Hampton Bay AC414-LRU 52'' Kemper...
How to remove cover in shower fan/light combination. Need to replace light bulb.
I tried turning my light fixture counter clockwise but that didn't work. I tried the screw driver technique as well, but that didn't work either. However, I applied pulled down the whole fixture with steady, even pressue on both sides and that did the trick. The fixture comes down a few inches while sliding on two wire guides on either side.
Apr 17, 2009 | Broan-NuTone N-8663RP Combination Light...
Casablanca Fan Stealth 3211T Ceiling Logo
171 people viewed this question
Top Casablanca Fan Dryers Experts
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
