Question about Kenmore 24032\24036 Top Load Washer
Washing machine does not drain or spin, I do not hear a click when closing the lid
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Aug 27, 2010
My washer does not spin or drain.
If the unit will agitate but not spin or drain I recommend checking the lid switch first. You should be able to hear the lid switch click as you slowly open & close the lid. If you don't hear a distinct click, replace the switch.
Here is the part you need.
Oct 13, 2012 | Kenmore 24032\24036 Top Load Washer
Will not drain
check the lid switch,close the lid,open it a few inches and close it down,you should hear a clicking sound no click bad lid switch
Mar 18, 2012 | Whirlpool Ultimate Care II LSQ9549L Top...
Hi Dennis! I have a whirlpool ultimate care II washing machine. It agitates, but will not drain or spin. any suggestions?
Check your lid switch, you should hear a click when you open and close the lid. If you don't hear a click, replace the switch.
Oct 17, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore 44152 3.5 high capicity washer will not spin
Open the lid of the washer and let it down gently to see if you hear a click when it closes. There is a lid switch that sometimes fails and prevents the washer from going into a spin cycle. If you don't hear the click when the lid closes, then you may need to have the lid switch replaced.
http://tclaundryrepair.com/home
Feb 19, 2009 | Kenmore Washing Machines
Washer won't drain or spin
sounds as if you have a lid lick/door switch issue, the machine is not recognizing the door being closed and for safety reasons will not enter spin/drain.. open anc\d close lid a few times slowly, cam you hear a "clicking noise" whe njust about closed?? id assume not replace teh lidswitch
Jan 21, 2009 | Kenmore 88732 Top Load Stacked Washer /...
My whirlpool washer won't spin or drain
soundslike a lid swithc error, you should be able to hear a "clicking" noise, as you open and close the lid, if not you need to replace the lid switch assy, it doesnt think the door is closed and for safety reasons it wont spin/drain
Nov 09, 2008 | Whirlpool Washing Machines
My Whirlpool washer stops in the middle of the cycle (between Rinse and Spin). What do I do?
sounds like a lid assy issue, can you hear a "clicking" just before the lid is closed, try opening nad closing a few times listening for a distinct "click" if not the machine doesnt think the door is closed and for safety reasons wont spin and drain.if so replace the door lid assy
Mar 16, 2008 | Washing Machines
Washer won't start spin cycle
Mar 16, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing machine stopped
try lifting the main top up and down and listen crefully do you hear any clicking just before the lid closes??? im assuming not, the lid switch sounds bad. wont drain or spin with a faulty lid switch
Mar 15, 2008 | Washing Machines
Washing machine
sounds lilke a bed lid switch for safety reasons it wont spin if it thinks the lid is not closed. open nd close the lid carefully agian and again, as your doing it do you hear a clicking noise??? if not your not contacting lid switch
Feb 25, 2008 | Whirlpool LSR6334LQ Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
