Question about Nintendo Wii Console
I have installed a new motorol-0A141 and it is incalled through my cable one company. It is a cable wireless modem. I have completed the cable connection and now I am trying to connect with my WII and I am getting a error code 51331 can you please help me get connected? thank you Denyse
    Genius:
  • 1,234 Answers
Error Code: 51331 This error code usually indicates a problem relating to wireless security. Please try the following troubleshooting:
  1. Are you using WEP or WPA security on your router?
    1. Log into the router using the default IP (consult your router's manual for assistance)
    2. Locate the "wireless security" section of your router settings and find the WEP or WPA key.
    3. If you are using 64-bit encryption, the WEP Key must be a 10-character key consisting of numbers or letters A through F.
    4. If you are using 128-bit encryption, the WEP Key must be a 26-character key consisting of numbers or letters A through F.
    5. The WEP Key must be a Hexadecimal (0-9, A-F, no other special characters or letters).
    6. If your router has multiple slots for a WEP Key, make sure the active key is the one in the #1 slot.
    7. If you are using WPA, the Wii console is compatible with the following types:
      • WPA - PSK (TKIP)
      • WPA - PSK (AES)
      • WPA2 - PSK (AES)
  2. If your WEP or WPA key is correct, then the problem might be related to MAC address filtering:
    1. From the router settings, locate the "MAC address filter" settings (also known as "access control", "access list", or "network filter" depending on your router model).
    2. If the Mac address filter is set to "enabled", then you must add the Wii's MAC address to the "allowed" list. You can locate the Wii's MAC address from the "console information" page (located under "Internet" in the Wii Settings).
    3. If the Mac address filter was disabled, then continue troubleshooting.
  3. Check Nintendo's router info for special notes, if available, for your router.
    1. Click here to go to our Wireless Router lookup page.
    2. Use the drop-down box to select, if available, your router manufacturer.
    3. Click on your router's model number, if available.
    4. Read any "special notes" at the top of the router's page. Many issues can be solved by changing settings described in the "special notes."
  4. Try a "Manual Setup" with the Wii console (how to), using your network's IP configuration settings. To access these settings:
    1. On your PC, click "Start" and then "Run."
    2. Type "CMD" into the field that appears to open a new window.
    3. Type "IPCONFIG/ALL" and press "Enter" to display a list of internet settings. Locate the settings asked for by the Wii console during the Manual Setup process and enter them.
  5. Power cycle your router and modem by unplugging them both from the wall. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then turn on the router. Try to connect the Wii console online and test for proper response.
Posted on Aug 27, 2010
I have a SBG6580. I am trying to enter the security key but cannot find it on the back of the router...please help
I shall have to assume you in a 'Factory Reset' situation, where you have not signed into the modem, and changed username/password defaults, (new unit, fresh out of the box).
Do not connect to the cable company yet. First, secure the modem.....
From the User Manual, page 9..... You do have a User Manual?
1. Open a browser window, after connecting your computer.
Use a 'wired' connection. Never change security settings, using Wi-Fi connection.....
2. Type in the IP address for the modem 192.168.0.1 in the URL address. That should take you to the modem's password change window.
3. Type in the default Username: admin.
4. Type in the default Password: motorola.
5. Type in your new username in the Password Change Username field.
6. Type in your new password in the New Password field.
7. Re-enter your new password
8. Re-type your new username in the Current Username Password field.
9. Click Apply.
10. Connect the modem to the cable company. You should shortly be able to go online, after the modem has synchronized to the cable company. That usually takes about a minute.
Your question asks for the 'security key'. That generally refers to the Wi-Fi settings. If that is the case, go to the 192.168.0.1 address, sign-in, and click on Wireless. Follow the obvious directions.... Or, post here again....
Feb 12, 2015 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How to set up the wireless internet connect on my laptop to this new SBG901 modem?
Short answer: YOU DO NOT.
The cable-modem just converts from the cable-company's signals to/from Ethernet signals.
You use an Ethernet cable to connect the output from the cable-modem to the 'WAN' (or 'Internet') port on a router with wireless capabilities. Then, you configure the router to create your own wireless network, with:
* an SSID ("network name")
* encryption level (use: WPA)
* a password for your network
Then, your wireless device can cite the SSID/password to authenticate to the router.
Feb 24, 2011 | Arris SURFboard Gateway SBG901 DOCSIS 20...
I want to re-install my wireless router #2300 after my cable company installed a new modem
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online
through the modem.
If your computer is able to go online through the
modem
Then you need to connect the computer to the router
ad the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for step by step by instructions
Jan 24, 2010 | Dell TrueMobile 2300 Wireless Broadband...
EMule TCP Port 11522 not reachable
Does you norton program have a firewall included with the software? If so, your windows firewall was probably turned off automatically because having two firewalls running simultaniosly can cause a conflict between the two firewalls and therefore will not work correctly.If you have a firewall included with your norton software make sure it is turned on and leave your windows firewall off, other wise turn your windows firewall back on.
As far as your situation with the broadband modem, I have to ask: Is your Thomson hardware a broadband router (wireless/wired), or are you using an access point? (wireless/wired) If you are using a "router" there is no way to set it up to work with the modem the cable company provided you. However, if the Thomson modem hardware is an "access point" the only thing I can suggest is to follow these steps:
1) Pull the power cord out of the back of the modem that the cable company provided to you.
2) Next, plug in your Thomson router in to the ethernet port of the computer.
3) You are then going to configure that device. Start by going to the "network and Internet" section in your control panel. There should be a section in there where you can click that says "setup a new network connection" There should be an option to set up and "access point" and it will search for your hardware. If your hardware is found you will probablybe promped to input information about your router and once that's done it should set up successfully. If it isn't successful by some chance don't give up just yet! Go to step 4-
4) Shut down your computer.
5) next, switch the ethernet cable going from your Thomson hardware to the modem from the cable company.
6) You will then need a second ethernet cable to go from a second port of the Thompson hardware in to the ethernet port on your computer.
7) next, plug the power cord back in to the modem from the cable company and your Thompson hardware and start up your computer.
You should be able to get a wired internet connection if all goes well. If you have a wireless access point go ahead and set up a separate internet connection only this time choose "wireless" and choose your settings. I hope this helps. Feel free to contact me anytime if you have more questions. Happy Holidays!
Rachel
Dec 04, 2009 | Computers & Internet
I need to reconfigure the Netgear router
There isn't really much to configure on a cable modem. If the modem is fully recognized by the cable provider (all lights are lit on the modem once connected to the cable (coax) side), then just plugging in the Netgear router's INTERNET connection directly into the cable modem will work fine. If the modem isn't properly recognized, you'll have to call your cable company and provide them the MAC address of the cable modem. The MAC is a 12 digit hexadecimal (0-9,A-F) number that should be on a sticker on the modem itself - it will be listed as six pairs of hex digits. If the cable company doesn't have that particular MAC address attached to your cable account, then it won't work.
Nov 10, 2009 | NetGear RangeMax WPN824 Wireless Router...
Cable company installed wireless router for internet into smartbox, but did not wire into leviton system itself. trying to connect to internet, only wireless works. which cat5 jack do you plug into, and do...
Make sure you can go online directly to the modem. If that is confirmed, you can connect the router directly to the modem and install it using the setup CD that came with it.
Oct 23, 2009 | Leviton (102-5G108-RW5)
Changed from AT&T to a cable company for DSL. Trying to set up
You need to "fool" your cable box into thinking that the wireless router is the computer. This just means that the modem is locking into the first ip address it can get... it tends to block out all others. Here's how to remedy and allow everything to get access...
1 Shut off computers, routers, everything.
2. Turn on your wireless router FIRST... leave everything else off until you see it's completely booted.
3. Then with the cable connected to the modem/cable box and the router, turn on the cable box/modem and let it cycle up. This should allow the cable modem to "find" the wifi ip address as the main ip.
After that, turn on any other routers, and the computers...
This should allow you access to the net by any of your computers because the wifi router should give all the other comptuers and routers on the system inddividual ip addresses and all should be well...
Give it a try and let me know!
K
Aug 28, 2009 | 2wire (1000-400108-001) Router
Wireless router install on cable modem w/static ip address set
Connect a computer to linksys lan port 1-4, point browser to linksys http://192.168.1.1 under Setup->Basic Setup->Internet Settings choose "Static IP" and fill in the fields below... the field for gateway should be set to the static ip of your cable modem. the field for netmask should probably be 255.255.255.0. It may help to turn on DHCP for local network so that lan hosts can get their ip's from the linksys.
May 15, 2008 | Linksys WRT55AG Router
Nintendo Wii Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
