Question about Mtd 22" Yard Machine Push Mower
I bout a 22" push mover last year.The priming bulb on this has been torn and it is difficult to start it.It should not tear or get damaged so easily.Please help. Harjinder S Sabherwal
  • 843 Answers
I agree the priming bulb should be more robust or somehow protected. You could replace the bulb, but soon have the same problem again. A simple work-around is to buy a can of spray instant-start (spray ether sold in auto parts stores). Spray this into the air filter each time you start the mower cold, thus avoiding the need to prime it.
Posted on Aug 27, 2010
Primer doesnt prime when presses
either the passage is plugged or the bulb is torn
Apr 11, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Briggs and Stratton Troy Built 21inch 190cc 650 series Gas Powered self propelled Lawn Mower. I moved to new house and the movers lost the manual. I bought it last year so only one seasons use. How do I...
If how you described you unit is true you do not have an electric mower you have a gas powered mower, you DO NOT have a battery!!!??? Place the throttle lever to choke position and prime carb with primer bulb 3-5 times then pull cord. Wala!!!! It's running rite. That guy at Loews must have been smokin somthin. Good Luck...
Apr 22, 2011 | Briggs & Stratton Lawn-Boy Insight Series...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Lawnmower very difficult to start
Hello. Get a can of starter fluid. A couple of good squirts into the air cleaner and it will take right off for you. J.
Jul 03, 2010 | Poulan Pro PR550N22SH 22Inch Briggs ...
Will only run until primed fuel is burnt - 2 seconds or so
Dave,
I am having the exact same problem. Did you find a fix?
Don
Jun 03, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Wont start and lost manual for a mtd yardmachine 8/26
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it run a few times like that and it will flush the gunk out of the jets...but most of the time you will need to rebuild the carburetor. If the mower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank. When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Dec 24, 2009 | Mtd 22" White Outdoor Self Propelled High...
Blue dots appearing on screen n bulb blew twice
IT NEEDS A LIGHT ENGINE. COST A LOT TO REPAIR.
Oct 06, 2009 | Televison & Video
Primer bulb on weedeater won't prime
when you prime the bulb it sucks gas from the tank with the small tube, any excess gassed pumped will be fed back to the carb via the big tube leading to the tank. If you prime it and the bulb stays pushed down, then you have a clog or kink. To fix , pull the small tube out of the tank through the fill hole. Pull off the filter on the end and put the tube back in the tank. If it primes, your fuel filter was clogged. If it still wont prime check the hose going to the carb and make sure isnt clogged or kinked.(take of carb and blow in it). If that doesnt fix it take off the bulb from the carb with two screws. The bulb assembly will come off too(rectange metal thing) Take off the two black gaskets, be carefull with them. Take off hoses from carb and bulb asembly. Blow carb cleaner in all holes and over surface. Put back together.
If the carb wont prime and the bulb isnt staying depressed. then you might have a bad bulb or carb gaskets. Make sure hoses are not cracked, cloged, or pinched.
Jun 17, 2009 | Troy Bilt Tb70ss Gas Trimmer
Mtd 22" Yard Machine Push Mower Logo
73 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
