Question about Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger
I received my LWG151P yesterdat and I am having problems with assembling the safety guard. It does not fit, it appears to be about 1/4" too short and the hole does not line for the screw to fit. Any suggestions? I am at my wits end with this.
    President:
  • Worx Master
  • 1,545 Answers
If you can, just mark and drill out the guard with a powered drill and drill bit (not too big) in the correct location for the screw(s) to fit. When in doubt, just drill it out! Plastic or metal guard....doesn't matter....a steel cutting drill bit will go thru both. Sometimes drastic engineering flaws cause for drastic solutions.
Posted on Aug 27, 2010
Elu 172. How do I remove flip top and the safety guard to clean?
Hi mate this is in the wrong category but i have an elu flip saw and to remove the guard you take your blade off and guide bush and remove the circlip and the guard pops off but u need to make notes on where the guard return spring fits through a hole on guard so as to replace, and remove the bolt with the screw driver slot in and washer / spacer to detatch the folding arm inside the guard, i will check mine and jog my memory then get back to u,does yours have a duel size bush for different blade diameters / centres. Paul
Sep 19, 2015 | Garden
I have an older gun can't read any specs the lables are worn off, the guns safety plunger is sticking allowing for free fire of the gun. most of my other guns have a step plunger with the spring r
To find the model number, look on ebay for hitachi framers and hopefully you will find one listed that looks like yours. If no joy, take the gun to your local fastener/nailgun dealer for parts. The dealer most likely has box full of used parts for your gun. I have seen many older nailers with bent safety foot that caused the plunger to stick in the engaged position. Some nailers have the safety return spring incorporated within the trigger plunger /valve area and still others that have the spring hidden under a guard on one side of the nailer (guard part # 883493). Look under the main body of the nailer for an indention where one side of the safety spring fits into (less than 1/2 inch in diameter) ; directly below the indention will be a point on the safety foot to catch the other side of the spring. Good luck
Oct 22, 2012 | Hitachi 3 - 1/2" Full Roundhead Framing...
AMP GUARD
Amp guard is a protection circuit built o protect the output from short circuits. Please check your speaker wiring for shorting. Once cleared your system should work fine.
Jun 06, 2012 | Clarion DUZ385SAT Car CD/ MP3 Player
Husky mod. 51chainsaw. how do i re-assemble chain brake lever? i do not know how to reset the handle to allow the internal clutch locking spring to slip over the clutch
To re assemble the hand guard back onto the brake cover, place the hand guard as best you can onto the side cover, now use a conical punch to push throught the hand guard and cover, now useing the punch as a pivot pull the hand guard fully back until the brake loads, once loaded remove the puch, the hand guard should now easily align back onto the cover, insert the two puvot collers and re fit the allen screw.
Apr 10, 2011 | Husqvarna Chain Saw Models 51, 55
My phone is saying digital roam mode when i make an outgoing call, how do i take it off so i can make outgoing call with no problem.
This is pretty much what you need to do. Just turn off all the roaming features. However when you roam it typically means you dont have service through Sprint so dont be surprised if when you turn off roaming capabilities your phone doesn't get ANY signal. Here's the link to your phones manual page 112 is about roaming.
Setting Roam Mode
Your phone allows you to control your roaming
capabilities. By using the Roaming menu option, you
can determine which signals your phone accepts.
Choose from two different settings on your phone to
control your roaming experience.
1. Press > Settings > More... > Roaming > Set Mode.
2. Highlight an option and press .
n Sprint Only to access only the Sprint network and
prevent roaming on other networks.
n Automatic to seek service on the Nationwide Sprint
Network. When Sprint service is unavailable, the
phone searches for an alternate service.
Call Guard
Your phone has two ways of alerting you when you are
roaming off the Nationwide Sprint Network: the
onscreen roaming icon and Call Guard. Call Guard
makes it easy to manage your roaming by requiring an
extra step before you can place or answer a roaming
call. (This additional step is not required when you make
or receive calls while on the Nationwide Sprint Network.)
To turn Call Guard on or off:
Call Guard.
2. Select On or Off.
To place roaming calls with Call Guard on:
1. From standby mode, dial 1 + area code + the
seven-digit number and press .
2. Read the message and press .
Note Call Guard is turned on by default on yourphone.
To answer incoming roaming calls with Call Guard on:
1. Press .
Data Roam Guard
Depending on service availability and roaming
agreements, yourphone may be able to access data
services while roaming on certain other networks. You
can set your phone to alert you when you are roaming
off the Nationwide Sprint Network and try to use data
services such as messaging.
To set your Data Roam Guard notification:
Data Roaming.
n Always Ask (default mode) sets your phone's Data
Roam Guard feature on. You will see a prompt that
will require you to respond anytime you access
data services while roaming.
n NeverAsk turns your phone's Data Roam Guard
feature off. Your phone will not notify you of your
roaming status when you access data services.
Touse data services when Data Roam Guard is active:
© When a notification appears informing you that data
roam charges may apply, press ROAM (left softkey)
to connect.
Note If the Call Guard feature is set to On, you need to
take extra steps to make and receive roaming calls.
Mar 08, 2011 | Sanyo SCP-2700 Cell Phone
To get the blade guard on a Ryobi circular saw to stay up.
Blade guards are spring loaded so they will not stay up unless you hold it up manually
May 05, 2010 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
CABLE ASSEMBLY APPEARS TO SHORT OUT MAKING THE
The wires feed from the dispenser switches down through the door and out the hinge. They can only be pulled one direction or the other and have to be disconnected from the components or the plug assembly to fit through. Eric
Aug 10, 2009 | Refrigerators
Kirby vacuum
The Kirby air flow can be reversed to become a blower (not pump).
This is ideal for blowing up low pressure items such as air beds etc.
Take off the complete bag assembly by twisting at the bottom and unclip at the top.
Fit the flexible hose to where the bag attached, align the arrows and twist fully until located.
Remove the front brush assembly, lift the front head light flap, detach the belt by twisting the square knob to the red position (off). un-clip the front assembly.
Your kirby should be supplied with a box type attachment (air intake guard) that fits on the front covering the motor spindle and making the safety switch.
Once fitted your kirby should now blow.
Mar 16, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Worx 10" 18v 2 In 1 Grass Trimmer/In Line Edger Logo
Top Worx Garden Experts
Tim Whalen
john milligan
Jay Finke
Jay Finke
Are you a Worx Garden Expert? Answer questions, earn points and help others
