Question about Canon imageRUNNER 5000 Copier
E000002-0000 showing when i switch on the machine what should i do now
  • 40 Answers
This error in heater section
The error must be reset in service mode (COPIER>FUNCTION>
CLEAR>ERR).
Posted on Sep 01, 2010
Main motor won't turn when in spinning cycle
Door switch is defective. Find the plastic piece on door and then find the switch in the machine. Ouch the switch in with a pencil. If you do not hear a clicking sound the switch is bad. Stops the machine from spinning. Easy to change
Mar 29, 2016 | Washing Machines
Indesit 1200 widl 126 no lights showing when machine switched on. Checked plug fuse is good
Hi Whalley
Are all fuses ok? kindly check your outlet as your power source and measure the voltage.
Jan 19, 2014 | Car Audio & Video
Sir, my photostate machine showing add paper
u have to check the interlock switch (front door switch).it is not working ,.either u have replace it or just short it with a wire and ola
Aug 01, 2011 | Panasonic DP-8020E Black and White Copier
Problem with the Samsung Washing Machines The machine keeps coming up with the message HEI 10x
Here is a list of errors for your machine.
I hope they help you.
SAMSUNG WASHING MACHINES, ERROR FUNCTIONS
When an error occurs, the alarm noise will sound and the error code displayed in the program window. Listed below is a series of error codes you may or may not see for your model of Samsng Washing Machine. The errors are shown as blinking in O.5 second intervals until the error status has cleared. In this case, all the driving devices are turned off until the error is cleared.
1. WATER SUPPLY ERROR - Display shows 4E.
Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON.
2. WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
3. OVER-FLOW ERROR - Display shows oE.
Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected.
4. UNBALANCE ERROR - Display shows UE.
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
5. WATER HEATER ERROR - Display shows HE, HE1.
HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF.
6. WATER PRESSURE SWITCH ERROR - Display shows 1 E.
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz)
Normal Level = Abnormal W/L Frequency
Low Level = 30.00 Khz
High Level = 15.00 Khz
If the same signal is detected for more than 5 seconds, it is a PRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error.
7. ABNORMAL WATER TEMPERATURE ERROR- Display shows cE.
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle.
At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF.
8. WATER LEAKAGE ERROR - Display shows 11 E.
Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts.
9. THERMISTOR ERROR - Display shows tE
Nov 21, 2010 | Washing Machines
How do I get to the lid safety switch to replace it? model # 24722300
The controls have hinges. You flip up the controls and then pop the S-clips so that you can remove the case. Their are several variations of the design2000 washer console. This video shows how to access that switch from various machines:
This video shows a typical lid switch replacement:
Jun 12, 2010 | Kenmore 24032\24036 Top Load Washer
It wont spin
Your washer has a lid switch.97a908d.jpg If the switch is broken the washer will not spin. The pump is mounted on the motor.c5ccc2f.jpg
In the wash cycle the pumps turns counterclockwise. In the spin cycle the pump turns clockwise, forcing the water out of the machine. So if that lidswitch is dead then she won't pump OR spin. This video shows how to get into your machine and the next one shows how to replace the lid switch
Use this GUIDE to help you
Did I help?
May 28, 2010 | Roper RAS8445KQ Top Load Washer
Machine washes but it does not drain water after cycle
You most likely have a bad lid switch. I have a pictorial that shows how to get to that lid switch
HERE
On this 2nd page HERE I have found a movie on youtube that shows how to get into this washer
Oct 05, 2009 | Whirlpool LSR5132PQ Top Load Washer
My machine show c 210
Please specify the machine model,in the Ricoh 1035 not exist the C210 error code.
If your machine show CC201=When the paper jam condition is not reset for 10 minutes the code is automatically generated.For reset please enter in the SP mode turn main switch OFF,unplugged and wait 10 sec.Plugged and turn ON the power switch.
Sep 05, 2009 | Ricoh Aficio 1035 Copier
I want to know which wire goes where on door switch on a servis 1300rpm washing machine as i cant get in touch with the person who took the switch off it has three wires two red and one black
Most older machines had only two wires so it didn't matter but if yours has three there should be a print either inside the control panel or on the back of the machine. Don't be afraid of the simple print. It will show and label the lid switch and show the wire colors. You just have to make sure THE POWER IS OFF THE MACHINE when attempting any repair.
Jul 29, 2009 | Washing Machines
Canon imageRUNNER 5000 Copier Logo
136 people viewed this question
old marine
old marine
