Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is buzing and flashing F2. How do I make it stop?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
Karcher2.94 preassure washer problems
free the motor by turning the cooling fan if its freed then you may have a bad capacitor on motor
Jul 19, 2013 | Garden
Buzing noise and failure to drain during spin cycly washer wont spin
This is a very common issue on these units, the drain pump needs to be cleaned. You can access the drain pump by removing the back panel of the washer. If you find that the drain pump has failed you can purchase the part from the link below.
http://www.appliancerepairlesson.com/
Mar 06, 2011 | Frigidaire ATF6000ES Front Load Washer
I have an HE 3 front loading washer and I am having problems with
Hi
Thanks for using FixYa. F2 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F2" is flashed. Press PAUSE/CANCEL twice to clear the display. Also, check the drain hose and make sure it is not plugged or kinked. Then check the electrical connections at the pump and make sure the pump is running. If still the issue is not resolved then replace the pump.
Thanks
Rylee
Jun 16, 2010 | Kenmore Elite 45986 Front Load Washer
My washer will not complete the cycle or drain the clothes. It just stops and beeps then flashes an error code like F2.
And F2 translates to: long drain. Make sure the drain hose from the machine is not kinked or plugged. Do you hear the pump running when it is supposed to? Check the drain-pump filter for debris. Replace the pump if it doesn't seem to run. Hope this helps!
Feb 10, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag neptune do code - makes buzing noise when start button pushed - then stops & do code shows - door will not open - also codes pf & po show up
My husband read the book - took the soap dispenser off & did something with a little cord - washer works fine now.
Dec 27, 2009 | Maytag Neptune Washer
Whirlpool washer need to be repaired
The f2 code is a pump problem. Need to look in pump. It is the first cycle to be satisfied when started.
Oct 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F2 flashing on display screen washer won't continue cycle????
This means that the drain time has exceeded 8 minutes and the water valves have turned off. After 4 minutes the suds error is displayed then 4 minutes later the F2 error.
Potential causes
1.Check drain hose for kinks or cloggs
2.Check electrical connection at the pump and make sure the pump runs.
3.Check inside of pump for foreign objects
4.If none of the above fixes the machine replace the pump.
Oct 12, 2008 | Kenmore 46462 Front Load Washer
F2 problem
f2 is usually and indication of drain problems usually something in pump ..have seen impeller on pump shaft come loose and freewheel..remove pump completely 3-4 screws hold pump motor to housing remove them try turning impeller if impeller spins free replace pump ..impeller will usually have some resistance when turned by hand..a free spin on impeller indicates it has come free of motor shaft
Aug 28, 2008 | Kenmore Elite 45986 Front Load Washer
Oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Aug 07, 2008 | Ovens
Whirlpool Duet Front Loader
F2=Long Drain If the drain time exceeds 8 mins the water valves are turned off and F02 is displayed
Check drain hose
check pump filter for foreign objects
check pump motor for proper operation
Jul 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
