Question about Denpa MP38 Voice Recorder
I have a machine that has been in use for a long time. The user has cleared all the files. She has replaced batteries. The screen display is: ***No Files *** Voice: 000/000 When we hit the button to REC/STOP the red light flashes and the device turns itself off and the back on to the same menu. What can we do to start recofding again
  • 5 more comments
  • richardwe808 Aug 27, 2010
    I think you missed the point. The problem is that when we hit the REC button the light flashes and then the recorder turns itself off and back on. So it is just recycling and not recording. Or must there be a mic plugged into it for it to record when not plugged into the phone.
    I think you missed the point. When we try to record by hitting the REC button the red light flashes to record, but then the device cycles off and back on to the same spot. What can we do to fix that? Are you saying we must have it attached to the phone or have a mic attached for this to work? I am not the person who uses this, but I am sure that was tried. We are looking for where we should go now.
    This is my third time trying to add a comment. After submitting it has not shown up,so I hope you do see this. I think you missed the point of the problem. The devise is powering on okay but when we push the button to REC the red light flashes on and then the device recycles off and back on. Are you suggesting that I must have a mic attached or have it attached to the phone? I know that the person who uses this device has used it for years and had everything properly attached but not working before she brought it to me. I want to know what I should do now so I can record.
    I think you missed the point of the problem. The devise is powering on okay but when we push the button to REC the red light flashes on and then the device recycles off and back on. Are you suggesting that I must have a mic attached or have it attached to the phone? I know that the person who uses this device has used it for years and had everything properly attached but not working before she brought it to me. It makes no difference if it is attached to the phone or used as a stand alone device, it recycles when pushing the REC button. I want to know what I should do now so I can record.
    Thank you, I am working on it now. When I started to look it says it only has 476 MB but I found that the .trashes folder has 475 MB because Check Flash will not run. I am verifying with the user that it is okay to wipe the .trashes folder and I will see what happens next. Because of your comments that I should have 900 MB and I only have 476 MB what can I do about the flash if it has to be be replaced. Actually I just looked on the back and see "512M" so I should be good. As I work more with it I will let you know.
    I wiped the .trashes folder and the Check Flash program is working properly now. That file had taken up all available space so there was no way to test. It is about 50% through the test now. I expect it to finish properly and I will then accept this as the solution. Thanks very much.
    My DENPA MP-38 voice recorder would not work at all. Following the suggestions I found out that even though there were no files found, there was a trashes folder that was so full there was no space left over. I emptied the folder and the device worked. I ran the program suggest to Check Flash and it found everything in working order. That is a great solution that saved me a lot of time in trial and error.
  • 864 Answers
Well it sounds as if the flash memory on the unit has gone bad. But lets see if it we cant fix it first.
  1. first plug the unit into your computer as you would regularly do.
  2. Now navigate to my computer.
  3. once in my computer right click on the device and hit properties.
  4. Once inside properties make sure the device is displaying the correct amount of space.
  5. If it says something like 50mb's or less than 900mb's the flash memory is damaged.
ok after you have confirmed that all the memory is there. Download the software check flash by clicking here
  1. To commence testing, run check flash. Select the voice recorder drive (this will be the same as the one you checked in properties) concerned in the ‘Drive’ combination field. Retain the ‘Use temporary file’ as the ‘Access type’ settings. Only the ‘Write and read test’ action is available for this type.
2. Also leave the ‘Small pattern set’ option as it is. Thus configuring, a complete test cycle consists of two test runs with different data. This is sufficient for a flash device.
3. If you want to do a thorough check, select ‘Full pattern set’. The tool then conducts 18 test runs for every single bit to check its functioning but this takes quite some time. To start the same, click ‘Start’ and wait for the analysis to complete.
Now after check flash has ran it will either tell you if there were errors or if the device checked out and is perfectly fine. If it is fine then you can try to reformat the device.
Before attempting a reformat you need to make sure there are no system files that will be deleted to do that you need to enable show hidden files or folders. to do that follow the steps in this video
once you are able to see hidden folders open the voice recorder and make sure there is not a hidden folder with a pmp_usb.ini file or anything like that they generally have a faded icon to let you know if its a hidden folder. if there is a folder copy and paste it to the desktop Do not cut it.
Once you have done that and made sure there isnt a usb.ini file on the device or anything and check flash said there are errors you can attempt to format the device. Make sure before you format the voice recorder click on properties again and see if the device is fat32 or ntfs. below are the steps to format the device
  • 1
    Open up 'My Computer'. You should see it under the list of available drives.
  • 2 Check its contents first to make sure that you have the right drive.
  • 3 In 'My Computer', right-click on the drive and choose 'Format'.
  • 4 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 5 Once the process is completed, Try to browse to it to make sure it works fine now.
  • now if it you have done all this and you formatted the device giving it a fresh start and check flash verified that there is no damage to the flash memory. You can try the device to see if it will record. If it doesn't there could be a few reasons why the ma-7 processor chip inside the unit is no longer functioning correctly and get a error when trying to record. Now if you have any idea how to solder i might be able to find you a replacement that you could attempt to solder in. But at the price of the unit i see on ebay it seems this wouldn't really be cost effective or worth the time and it would be more effective to replace the unit.. Only reason i say that is you say you have used it or a long time which means its most likely not under warranty. If you need any explanation on the steps above or require further assistance on how to go about finding the smaf chip inside of the device please let me know and i can assist you further. Thanks-Midwest-tek
    Posted on Aug 27, 2010
    • 1 more comment
    • Nathan Ayers
      Nathan Ayers Aug 27, 2010
      yes please do, I didnt know if it was the 512mb or 1gb model so you would be correct to assume that is the right size. Now you said you cant get check flash to run what operating system are you using. Just wondering cause i will find a flash memory verification software to ensure that the memory is still in working order. As even though it may say it has the memory if all the sectors are bad or unreadable then that number doesnt mean much. But please let me know as i am here to assist you and will be glad to help you try to get this but in some cases the unit just may no longer work. An because of the manufacturer there isnt much hope in getting it repaired. But you may be able to repair it yourself as i said i read online it looks like it has a ma-7 wholesale audio processor. So it can be purchased. An actually looking i cant even find a ma-7 so in the meantime im going to call some distributors and see if i can locate one as that is a chip they may not make so much anymore. But i will see if i can locate one if you should choose that route. So let me know how it goes and keep me updated. Thanks- Midwest-tek
    • Nathan Ayers
      no problem this is what i do.
    • Nathan Ayers
      im glad it worked and i was able to suggest you in the right direction. Enjoy your recorder.
      Brigadier General:
    • 3,513 Answers
    Hi
    Simply plug the adaptor into ANY phone jack in the house and record both sides of the conversation on all the phones that use that specific line from the one location. No beeps, clicks, or any noise will be heard whatsoever. Activate 'voice activation' mode and the Denpa will only record when the phone is in use.
    Let us know if you have something more to ask else please accept the solution.
    Thanks for contacting fixya.com
    Ti 83 will not power on replaced all batteries
    When you clear memory, the contrast sometimes changes. If the screen
    is faded or blank, adjust the contrast by pressing 2nd and up- arrow or down- arrow keys .
    Resetting RAM restores RAM system variables to factory settings and
    deletes all nonsystem variables and all programs. Resetting defaults
    restores all system variables to default settings without deleting variables and programs in RAM. Resetting RAM or resetting defaults does not
    affect variables and applications in user data archive.
    Tip: Before you reset all RAM memory, consider restoring sufficient available
    memory by deleting only selected data.
    To reset all RAM memory or RAM defaults on the TI-83 Plus, follow these
    steps.
    1. From the RAM ARCHIVE ALL menu, select 1:ALL RAM to display the
    RESET RAM menu or 2:Defaults to display the RESET DEFAULTS menu.
    2. If you are resetting RAM, read the message below the RESET RAM
    menu.
    • To cancel the reset and return to the home screen, press .
    • To erase RAM memory or reset defaults, select 2:Reset.
    Depending on your choice, the message RAM cleared or Defaults
    set is displayed on the home screen.
    Mar 25, 2012 | Texas Instruments TI-83 Plus Calculator
    Tip
    Some of the important cmd prompt commands
    Copy and keep it handy..
    ADDUSERS --Add or list users to/from a CSV file
    ARP -- Address Resolution Protocol
    ASSOC -- Change file extension associations
    ASSOCIAT --One step file association
    AT -- Schedule a command to run at a later time
    ATTRIB --Change file attributes
    BOOTCFG --Edit Windows boot settings
    BROWSTAT --Get domain, browser and PDC info
    CACLS -- Change file permissions
    CALL --Call one batch program from another
    CD --Change Directory - move to a specific Folder
    CHANGE-- Change Terminal Server Session properties
    CHKDSK -- Check Disk - check and repair disk problems
    CHKNTFS -- Check the NTFS file system
    CHOICE --Accept keyboard input to a batch file
    CIPHER --Encrypt or Decrypt files/folders
    CleanMgr ---Automated cleanup of Temp files, recycle bin
    CLEARMEM ---Clear memory leaks
    CLIP ---Copy STDIN to the Windows clipboard.
    CLS ---Clear the screen
    CLUSTER ---Windows Clustering
    CMD ---Start a new CMD shell
    COLOR --- Change colors of the CMD window
    COMP ---Compare the contents of two files or sets of files
    COMPACT --- Compress files or folders on an NTFS partition
    COMPRESS ---Compress individual files on an NTFS partition
    CON2PRT ---Connect or disconnect a Printer
    CONVERT ---Convert a FAT drive to NTFS.
    COPY ---Copy one or more files to another location
    CSCcmd ---Client-side caching (Offline Files)
    CSVDE ---Import or Export Active Directory data
    DATE --- Display or set the date
    Dcomcnfg DCOM ---Configuration Utility
    DEFRAG ---Defragment hard drive
    DEL ---Delete one or more files
    DELPROF--- Delete NT user profiles
    DELTREE ---Delete a folder and all subfolders
    DevCon ---Device Manager Command Line Utility
    DIR ---Display a list of files and folders
    DIRUSE --- Display disk usage
    DISKCOMP--- Compare the contents of two floppy disks
    DISKCOPY ---Copy the contents of one floppy disk to another
    DNSSTAT ---DNS Statistics
    DOSKEY --- Edit command line, recall commands, and create macros
    DSADD ---Add user (computer, group..) to active directory
    DSQUERY--- List items in active directory
    DSMOD ---Modify user (computer, group..) in active directory
    ECHO--- Display message on screen
    ENDLOCAL--- End localisation of environment changes in a batch file
    ERASE ---Delete one or more files
    EXIT ---Quit the current script/routine and set an errorlevel.
    EXPAND --- Uncompress files
    EXTRACT--- Uncompress CAB files
    FC--- Compare two files
    FDISK--- Disk Format and partition
    FIND ---Search for a text string in a file
    FINDSTR--- Search for strings in files
    FOR /F ---Loop command: against a set of files
    FOR /F ---Loop command: against the results of another command
    FOR ---Loop command: all options Files, Directory, List
    FORFILES ---Batch process multiple files
    FORMAT ---Format a disk
    FREEDISK ---Check free disk space (in bytes)
    FSUTIL --- File and Volume utilities
    FTP --- File Transfer Protocol
    FTYPE--- Display or modify file types used in file extension associations
    GLOBAL --- Display membership of global groups
    GOTO ---Direct a batch program to jump to a labelled line
    HELP--- Online Help
    HFNETCHK--- Network Security Hotfix Checker
    IF--- Conditionally perform a command
    IFMEMBER Is the current user in an NT Workgroup
    IPCONFIG Configure IP
    KILL Remove a program from memory
    LABEL --- Edit a disk label
    LOCAL --- Display membership of local groups
    LOGEVENT--- Write text to the NT event viewer.
    LOGOFF --- Log a user off
    LOGTIME --- Log the date and time in a file
    MAPISEND ---Send email from the command line
    MEM --- Display memory usage
    MD --- Create new folders
    MKLINK --- Create a symbolic link (linkd)
    MODE ---Configure a system device
    MORE --- Display output, one screen at a time
    MOUNTVOL ----Manage a volume mount point
    MOVE --- Move files from one folder to another
    MOVEUSER--- Move a user from one domain to another
    MSG ---Send a message
    MSIEXEC --- Microsoft Windows Installer
    MSINFO ---Windows NT diagnostics
    MSTSC --- Terminal Server Connection (Remote Desktop Protocol)
    MUNGE --- Find and Replace text within file(s)
    MV --- Copy in-use files
    NET --- Manage network resources
    NETDOM --- Domain Manager
    NETSH ---Configure network protocols
    NETSVC ---Command-line Service Controller
    NBTSTAT --- Display networking statistics (NetBIOS over TCP/IP)
    NETSTAT --- Display networking statistics (TCP/IP)
    NOW --- Display the current Date and Time
    NSLOOKUP--- Name server lookup
    NTBACKUP ---Backup folders to tape
    NTRIGHTS E---dit user account rights
    PATH --- Display or set a search path for executable files
    PATHPING ---Trace route plus network latency and packet loss
    PAUSE --- Suspend processing of a batch file and display a message
    PERMS --- Show permissions for a user
    PERFMON ---Performance Monitor
    PING ---Test a network connection
    POPD --- Restore the previous value of the current directory saved by PUSHD
    PORTQRY--- Display the status of ports and services
    PRINT --- Print a text file
    PRNCNFG --- Display, configure or rename a printer
    PRNMNGR --- Add, delete, list printers set the default printer
    PROMPT --- Change the command prompt
    PsExec --- Execute process remotely
    PsFile --- Show files opened remotely
    PsGetSid --- Display the SID of a computer or a user
    PsInfo ---List information about a system
    PsKill --- Kill processes by name or process ID
    PsList --- List detailed information about processes
    PsLoggedOn ---Who's logged on (locally or via resource sharing)
    PsLogList ---Event log records
    PsPasswd --- Change account password
    PsService --- View and control services
    PsShutdown ---Shutdown or reboot a computer
    PsSuspend ---Suspend processes
    PUSHD --- Save and then change the current directory
    QGREP --- Search file(s) for lines that match a given pattern.
    RASDIAL ---Manage RAS connections
    RASPHONE ---Manage RAS connections
    RECOVER --- Recover a damaged file from a defective disk.
    REG --- Registry: Read, Set, Export, Delete keys and values
    REGEDIT --- Import or export registry settings
    REGSVR32--- Register or unregister a DLL
    REGINI ---Change Registry Permissions
    REM --- Record comments (remarks) in a batch file
    REN --- Rename a file or files.
    REPLACE --- Replace or update one file with another
    RD ---Delete folder(s) [remove dir]
    RDISK ---Create a Recovery Disk
    RMTSHARE ---Share a folder or a printer
    ROBOCOPY--- Robust File and Folder Copy
    ROUTE --- Manipulate network routing tables
    RUNAS --- Execute a program under a different user account
    RUNDLL32--- Run a DLL command (add/remove print connections)
    SC --- Service Control
    SCHTASKS--- Create or Edit Scheduled Tasks
    SCLIST --- Display NT Services
    ScriptIt Control ---GUI applications
    SET --- Display, set, or remove environment variables
    SETLOCAL--- Control the visibility of environment variables
    SETX ---Set environment variables permanently
    SHARE --- List or edit a file share or print share
    SHIFT --- Shift the position of replaceable parameters in a batch file
    SHORTCUT ---Create a windows shortcut (.LNK file)
    SHOWGRPS ---List the NT Workgroups a user has joined
    SHOWMBRS ---List the Users who are members of a Workgroup
    SHUTDOWN ---Shutdown the computer
    SLEEP --- Wait for x seconds
    SOON --- Schedule a command to run in the near future
    SORT --- Sort input
    START --- Start a separate window to run a specified program or command
    SU ---Switch User
    SUBINACL ---Edit file and folder Permissions, Ownership and Domain
    SUBST --- Associate a path with a drive letter
    SYSTEMINFO--- List system configuration
    TASKLIST--- List running applications and services
    TIME ---Display or set the system time
    TIMEOUT--- Delay processing of a batch file
    TITLE --- Set the window title for a CMD.EXE session
    TOUCH --- Change file timestamps
    TRACERT --- Trace route to a remote host
    TREE --- Graphical display of folder structure
    TYPE --- Display the contents of a text file
    USRSTAT--- List domain usernames and last login
    VER ---Display version information
    VERIFY --- Verify that files have been saved
    VOL --- Display a disk label
    WHERE --- Locate and display files in a directory tree
    WHOAMI --- Output the current UserName and domain
    WINDIFF --- Compare the contents of two files or sets of files
    WINMSD --- Windows system diagnostics
    WINMSDP--- Windows system diagnostics II
    WMIC ---WMI Commands
    XCACLS --- Change file permissions
    XCOPY--- Copy files and folders
    on Dec 16, 2009 | Computers & Internet
    HP scanjet 8279 displays an error 05 and won't clear. I can't turn the machine off either. I have to manually disconnect the machine from power source to try to reboot it. It turns back on then after a few...
    Error code 5 denotes a device failed and requires an arbitrator/administrator. If an installed device requests a resource type and detects that there is no arbitrator, computer users will receive this error code. The arbitrator/administrator redirects the system in a chosen field. It cannot happen if the computer has a firewall or has user restrictions. The administrator does this for security purposes. The system denies admission to other users to protect information and important data.
    A user is denied access to some files or program. As a result, the user will not be able to obtain information from certain files nor actions like delete, restore, or edit can be executed.Errors on your system may be caused by invalid registry entries and outdated or corrupt drivers.
    Update the driver of the files. Use the click start control panel administrive tools Device Manager scroll to ports(Com<p)+to expand you should see a communication port& Ecp printer port you might see a yellow question mark? right click to uninstall and reinstall the appropriate device. Run wizard in the Add New Hardware in Control Panel
    hope this helps
    Feb 10, 2011 | HP ScanJet 8270 Flatbed Scanner
    Hi My dad is currently away on holiday and he has a Canon IXUS Z70 Camera which has a H in the screen. Can this be cleared or does it need to be replaced? Thanks
    Your dad's camera has a self-diagnosis feature when it powers up. If a fault is detected, then the letter H appears on the LCD display panel on top of the camera.
    The user manual for the IXUS Z70 says on page 55 that under such circumstances the user must remove the battery from the camera and wait for the H to disappear before refitting the battery.
    If this does not solve the problem then the camera is effectively scrap. It's an obsolete APS film camera and spares are no longer available.
    Hopefully, your dad will be able to clear that H with just a simple battery reset, but if not then I still hope that my posting will save him from wasting further time on the problem.
    Please don't forget to take a moment to rate my answer.
    Jan 19, 2010 | Cameras
    RICOH FT 7650 shuts itself off when not in use after 45 minutes
    Enter in the user mode:
    1.Press the Clear mode key.
    2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
    3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
    4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
    5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
    6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
    Aug 31, 2009 | Ricoh Aficio 450 Copier
    Cannot reboot unit after inserting new batteries
    THIS IS A CMOS PROBLEM AND THE BATTERY THAT KEEPS ALL THAT IMPORTANT INFORMATION STORE ON A CHIP IN THE MOTHERBOARD AND THE BOIS SETTING,
    EVERY TIME YOU TURN THE MACHINE OFF IT DOESNT REMEMBER WHAT IT DID THE DAY BEFORE BECAUSE THE BIOS SETTING ARE CLEARING EVERYTIME YOU RESTART THE MACHINE.
    Feb 25, 2009 | Computers & Internet
    Palm m130 display screen will not display after replacing battery
    have you fully charged the battery?
    Have you tried a reset and a hard reset?
    hard reset, push the power button and the reset button at the same time. (All data will be cleared)
    Hope this helps.
    Ed
    Jan 10, 2009 | Palm m130 Handheld
    Abt transcend tsonic840
    Introduction
    Combining a mirrored surface and metal body, Transcend’s MP840 catches people’s eyes. This new MP3 player is easy to carry because of its compact size (82mm long x 40.5mm wide x 12.5mm deep) and light weight (70g with battery). The 1.8-inch color TFT-LCD screen with high resolution (176 x 220 pixels), which delivers the best image quality, is especially designed for video and photo playback. The 3-phase wheel is easy to use and the brilliant graphic user interface displays clearly through the shiny screen.
    As a portable multimedia center, the MP840 supports many audio and video formats such as MTV, JPG, BMP, MP3, WMA, WMA-DRM10, and WAV. This allows you to enjoy your favorite videos, music, or photos. In addition, you can read e-books with the MP840. It features a lyrics display, and is equipped with 7 equalizer effects that include a customizable USER EQ mode for you to create your own music style. With a fully charged battery, the MP840 supports up to 30 hours of continuous playback, so you can enjoy music all day.
    The versatile MP840 is not just a portable entertainment center, but also provides many useful functions such as digital voice recorder, FM radio, FM recorder, real time clock to display world times, and has a 13-language interface. The language-learning feature, with adjustable playing speed and A-B repeat function, helps you learn foreign languages in an effective way. The built-in Hi-Speed USB 2.0 connector provides quick charging and data transferring. MP840 is now available in two capacities: 2GB (Glacier White) and 4GB (Mystery Black).
    Features
    - 1.8-inch (176 x 220 pixel) Super Color LCD Display for Playing Videos and Photos
    - Plays Music, Video (.mtv) and Photos (.jpg, .bmp)
    - MP3 Player supports MP3, WMA, WMA-DRM10 (subscription music) and WAV music formats
    - FM Radio (FM Radio recording and the ability to preset 20 FM radio stations)
    - Advanced Digital Voice Recorder
    - Ability to read E-books (.txt)
    - Karaoke-type lyrics display
    - VAD (Voice Activation Detection), Very High quality Gapless Audio Recordings
    - A-B repeat function allows you to continuously replay a designated section of a track
    - Variable Track Playback speeds
    - Supports 13 user languages including song/artist name display
    (English, German, French, Japanese, Korean, Greek, Russian, Spanish, Italian, Portuguese, Turkish, Simple Chinese, Traditional Chinese)
    - USB Flash Drive capabilities for data transfer and storage
    - Included Software can be used to Lock your computer and setup Passwords for your files
    - 7 Equalizer effects, including a customizable USER EQ setting
    - Powered using a rechargeable Li-ion battery (fully charged battery supports over 30 hours of
    continuous music operation) *
    - Hi-Speed Mini USB 2.0 port for easy computer connectivity and fast file transfers
    - Real Time Clock (RTC) displays local and world times
    - Sleep Mode, preset the player to Auto-Power OFF after 15, 30, or 60 minutes
    - Automatic screen saver runs if the unit is idle for more than a few seconds, this acts as a battery saving measure
    hope this info helps u....
    Dec 15, 2008 | Transcend T-Sonic 840 MP3 Player
    How to use cmd ?
    to use the command prompt, press the "start" and "R" keys on the keyboard.
    On the small, "Run" screen, type cmd.
    click ok.
    type help in the command prompt. This should print a list of commands that you can use with it.
    This is what it puts on-screen:
    For more information on a specific command, type HELP command-name
    ASSOC Displays or modifies file extension associations.
    AT Schedules commands and programs to run on a computer.
    ATTRIB Displays or changes file attributes.
    BREAK Sets or clears extended CTRL+C checking.
    CACLS Displays or modifies access control lists (ACLs) of files.
    CALL Calls one batch program from another.
    CD Displays the name of or changes the current directory.
    CHCP Displays or sets the active code page number.
    CHDIR Displays the name of or changes the current directory.
    CHKDSK Checks a disk and displays a status report.
    CHKNTFS Displays or modifies the checking of disk at boot time.
    CLS Clears the screen.
    CMD Starts a new instance of the Windows command interpreter.
    COLOR Sets the default console foreground and background colors.
    COMP Compares the contents of two files or sets of files.
    COMPACT Displays or alters the compression of files on NTFS partitions.
    CONVERT Converts FAT volumes to NTFS. You cannot convert the
    current drive.
    COPY Copies one or more files to another location.
    DATE Displays or sets the date.
    DEL Deletes one or more files.
    DIR Displays a list of files and subdirectories in a directory.
    DISKCOMP Compares the contents of two floppy disks.
    DISKCOPY Copies the contents of one floppy disk to another.
    DOSKEY Edits command lines, recalls Windows commands, and creates macros.
    ECHO Displays messages, or turns command echoing on or off.
    ENDLOCAL Ends localization of environment changes in a batch file.
    ERASE Deletes one or more files.
    EXIT Quits the CMD.EXE program (command interpreter).
    FC Compares two files or sets of files, and displays the differences
    between them.
    FIND Searches for a text string in a file or files.
    FINDSTR Searches for strings in files.
    FOR Runs a specified command for each file in a set of files.
    FORMAT Formats a disk for use with Windows.
    FTYPE Displays or modifies file types used in file extension associations.
    GOTO Directs the Windows command interpreter to a labeled line in a
    batch program.
    GRAFTABL Enables Windows to display an extended character set in graphics
    mode.
    HELP Provides Help information for Windows commands.
    IF Performs conditional processing in batch programs.
    LABEL Creates, changes, or deletes the volume label of a disk.
    MD Creates a directory.
    MKDIR Creates a directory.
    MODE Configures a system device.
    MORE Displays output one screen at a time.
    MOVE Moves one or more files from one directory to another directory.
    PATH Displays or sets a search path for executable files.
    PAUSE Suspends processing of a batch file and displays a message.
    POPD Restores the previous value of the current directory saved by PUSHD.
    PRINT Prints a text file.
    PROMPT Changes the Windows command prompt.
    PUSHD Saves the current directory then changes it.
    RD Removes a directory.
    RECOVER Recovers readable information from a bad or defective disk.
    REM Records comments (remarks) in batch files or CONFIG.SYS.
    REN Renames a file or files.
    RENAME Renames a file or files.
    REPLACE Replaces files.
    RMDIR Removes a directory.
    SET Displays, sets, or removes Windows environment variables.
    SETLOCAL Begins localization of environment changes in a batch file.
    SHIFT Shifts the position of replaceable parameters in batch files.
    SORT Sorts input.
    START Starts a separate window to run a specified program or command.
    SUBST Associates a path with a drive letter.
    TIME Displays or sets the system time.
    TITLE Sets the window title for a CMD.EXE session.
    TREE Graphically displays the directory structure of a drive or path.
    TYPE Displays the contents of a text file.
    VER Displays the Windows version.
    VERIFY Tells Windows whether to verify that your files are written
    correctly to a disk.
    VOL Displays a disk volume label and serial number.
    XCOPY Copies files and directory trees.
    this window is used only when the desktop cannot be accessed.
    For a user-friendly interface (easier to use), use My computer to do common tasks.
    Aug 25, 2008 | Microsoft Windows Vista Home Premium with...
    Scan to smb
    Setting up a scanning template using CentreWare Internet Services (CWIS) will fail if the user login name is a domain user, for example, ADSdomain\testadmin.
    1. Open an Internet web browser.
    2. Enter the IP Address of the machine in the Address field, and then press [Enter] on the keyboard. The CWIS home page will be displayed.
    3. Click on the [Services] tab.
    4. Click on the [Job Templates] link.
    5. Click on the [Display Job Templates Screen] button. The Device Template window will be displayed.
    6. Click on the [File Repository Setup] radio button. The File Repository Setup window will be displayed.
    7. Select the required File Repository from the File Repository Setup pull-down menu.
    8. Enter a username that only exists on the SMB server in the Login Name field.
    9. Click on the [Apply] button. A 'Settings have been updated' message will be displayed.
    10. Click on the [Back] button. The File Repository Setup window will be displayed.
    11. Click on the [Template] radio button. The Device Template window will be displayed.
    12. Click on the [Create New] button, and then setup the template again.
    13. Click on the [X] in the upper, right corner to close the Internet browser window and return to the desktop.
    May 19, 2008 | Xerox WorkCentre M128 Copier
    Open Questions:
    Denpa MP38 Voice Recorder Logo
    73 people viewed this question
    Top Denpa Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
