Question about HP Pavilion m8120n PC Desktop
Can anyone tell me what the difference is between the two motherboards used in the HP m8120n system? The two P/N's are 5188-7408 and GC674-69001. My system has the second motherboard in it however when I ordered a new one I got P/N 5188-7408 (both are compatible with this system) I just need to know if there will be a problem with using the P/N I received verses the P/N that was originally installed in my system
  • HP Master
  • 1,876 Answers
The spec on it is here
https://support.hp.com/us-en/product/hp-pavilion-media-center-m8100-desktop-pc-series/3440688/model/3440608/document/c00916901
as you can see this HP service man; lacks the parts lists
the mobo usually have a suffix letter group that tell what OS level it supports.
in your cars NO OS stated.
so....
fore example things needed for w8 and newer may be mising
like TPM , and UEFI upgrades.
Posted on Jul 22, 2017
    Top Expert:
  • HP Master
  • 47,568 Answers
No problems if you got the intel chip with it
otherwise the new board may require the later chip for it to work
Posted on Jul 21, 2017
  • 8 Answers
SOURCE: hp compaq d530 CMT motherboard diagram
You are missing the front headphone / microphone connector that plugs into the motherboard. Or a way to jump this to close the headphones so the sound will come out the back.
Posted on Aug 19, 2008
SOURCE: hp pavilion m7330n motherboard issue
The system in question requires motherboard model ms-7184 and can be found on ebay for less than $100.  If your repair guy used a different motherboard you will get the issues described and need to reinstall the OS.  It is impracticle to put any more than $200 in most desktop computers more than 2 years old, your repair guy should have advised you of this straight off.  Find a new person to take your equipment.
Posted on Sep 08, 2008
antiochpc
  • 1314 Answers
SOURCE: replacing power supply HP M8120N
Here is the link for the upgrade and service guide.
This one is just as easy as 1) removing the side panel; 2) Remove the four screws that hold the power supply into position; 3) Remove the power supply cables from the motherboard (NOTE: If the media bay reader is in the way, you remove the front bezel by pressing the release tabs on the bezel and it will swing open. Remove the one screw securing the bay in position, then slide it forward so you can reach the power cable to the motherboard.); 4) Remove the power supply cables from the hard drives, cd rom drives, and other peripherals inside the PC. 5) Remove power supply...sometimes there is a button to push and it will slide out, sometimes not. 6) Replace power supply, then reverse procedures.
Thanks and please take a moment to rate as fixya.
Posted on Dec 07, 2008
byteguy
  • 2229 Answers
SOURCE: need motherboard for hp a6300f
I suppose you could get one from HP for big bucks, but I would suggest you try E-Bay. You are likely to find a used one at a much more reasonable price.
Posted on Nov 27, 2009
Testimonial: "thank you very much"
  • 644 Answers
SOURCE: My HP Pavilion a6300f powers up but no signal to the monitor
It could be the motherboard, try resetting the the bios first by either taking the lithium cmos battery out and then replacing after 30 secs or finding the the cmos jumber and unshort it for 30 secs, and reboot the mechine.
If the same and no monitor responce then the onboard graphic electronics may have failed, the motherboard does have a AGP expansion slot which you may want to test with a graphics card to see if that will work.
If you find that you do have to replace the motherboard, try to find one that uses the same processor and memory that you already have, that way you will keep expence down to a minimal.
Replacing the motherboard will mean you will have to contact microsoft to give you the installation codes for the operating system to work with the new motherboard, when you boot for the first time with the new motherboard fitted you will have to phone the number on the screen to reregister the system just follow the instructions, it is quite self explanetry.
Once all booted up and drivers installed the computer should run as normal, as for the hp recovery disks it should still work as all the information on the disk is on the harddrive any way, the only thing you would need to do is keep the motherboard installation disk with all the drivers on.
hope this helps.
Posted on Mar 23, 2010
Testimonial: "Thank you for taking the time to reply and for your suggestions."
How do I open dvd tray on hp m8120n?
On all CD/DVD look for a tiny hole on the front tray.. use a paper clip ... insert the paper clip in the little hole... do it gently .. it will open the tray.. ALL CD/DVD have the little hole.. so look for it.. remember the hole is as little as a paper clip .. like a pin head small...
May 18, 2014 | HP Pavilion a305w (DM181AR) PC Desktop
System fan error
If you have replaced the fan and you are still getting a "Fan Error" then you have replaced the wrong fan. The system fan is not fitted to the top of the processor, it is usually fitted to the case.
Sep 08, 2013 | HP Pavilion m8120n PC Desktop
Bios
clayton have you changed motherboard ?.you can use the RAM your motherboard are built for.
Apr 27, 2013 | HP Pavilion Elite M9060N PC Desktop
Computer was moved and now I have no sound
Firstly check whether the sound driver is installed or not. Secondly, make sure that you haven't turned on the Mute (You will see red X mark on the sound icon). Thirdly, Check the output connector (Audio Jack). Forth, try your speaker to another system to see if it's working or not. If you follow all these steps and you still get no sound, then the problem is with the sound card. But in your case, I hope these will definitely fix your problem. Good luck
May 16, 2010 | HP Pavilion m8120n PC Desktop
Which motherboard to use in replacement of
Unless the motherboard is a late model motherboard, it maybe impossible to get a exact replacement. Your best bet is to try HP.
Motherboards and desktop cases have standard mounting holes, I would suggest you buy a late model motherboard that suit your requirements and mount it in your desktop case. There are a large range different manufacturers to choose from. My favorites are from Gigabyte and MSI.
Make sure the ATX power supply has adequate power output.
Dec 20, 2009 | HP Computers & Internet
System can't bootup any cd or dvd
Do you have a Win98 install CD? If yes, you should be able to tell it to boot with CD-ROM support.....then use xp disk to load or install your OS.......I'm doing that right now on a different system. It will format your drive first....which takes a looooooooooooong time, however, it is worth it.
Sep 27, 2009 | Intel Motherboard
Video cards are causing 3 beeps
The 3 short beeps indicates a video card memory problem.
The video card uses video RAM that is part of the video card. Try reseating the video card and if the problem is not resolved then the fault is the video card and it needs to be replaced.
Aug 30, 2009 | PC Chips (M925G) Motherboard
HP Media Center M8000. Network card bad, must replace motherboard
hello Friend,
here is the solution.
Buy New good Network Card Like D-Link or other cost about (10$-15$) install it on pci slot.then install drivers.so now u r system with new working Network Card.
if helps Rate the solution
Jul 02, 2009 | HP (D7580-60003) Motherboard
Replacing power supply HP M8120N
Dec 07, 2008 | HP Pavilion m8120n PC Desktop
Installing XP on HP m8120n
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Dec 04, 2008 | MSI K8MM-V Motherboard
HP Pavilion m8120n  PC Desktop Logo
115 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
