Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Our top rack is not getting cleaned at all-- although the rinser seems to spin freely when pushed, and fits correctly into the hole back. We were using powder detergent, and a little residue was always left in the compartment. So we tried liquid detergent, to see if it would help, and now it seems like almost none of the detergent is dissolving out, at all. The compartment's full and a goopy mess after each cycle. So now the bottom rack isn't very clean, either! Please advise. Thanks!
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa,
Based on your description... I`d suspect a plugged or really dirty wash pump. It could ultimately be a worn out wash impeller/chopper assembly, but I'd certainly try my suggestions before considering that.
The place to start for that is to pull the pump filter, spray arm and check for food deposit, broken glass, undissolved detergent and general water deposit built up in the sump well.
The key is to get in there and clean it all out, I`ve attached a link at the bottom that will show you how to go about it, ( This will be applicable to most Whirlpool, Inglis, Kenmore, Kitchen-Aid, Jenn-Air )
When you`re finished run it through a test cycle and see how it goes. You may even want to run it empty with just a bowl of "white vinegar" on the top rack for a dishwasher bath.
Let me know how you make out and what you find.
macmarkus :)
http://www.youtube.com/watch?v=iRCCrEwrst8&NR=1
Posted on Aug 27, 2010
Why is the upper sray arm is not working in kitchenaid model KUDR01TJ
There are 2 spray arms for the top rack. A small one on the dishwasher top and a bigger one attached to the bottom of the upper rack. Both get water feed from a flat tube that runs up the back wall of the dishwasher. Not much to the very top little arm--just check the spray holes for any food blockage and try to clean with a brush or tooth pick. The bigger arm on the bottom of the top rack gets its water feed through a hole about half way up the flat tube on the back wall. When you push the rack all the way in, it has to plug itself into that hole in the back wall. Check that plug in area and make sure nothing broke off that would keep it from making a good seal with the rack all the way in. All check all the holes in the spray arm for food blockages. On the very end of all spray arms is a main hole that is the drive hole to spin the spray arm. The water shoots out that hole and acts like a jet engine to push the arm around. Make sure those holes are clear.
Mar 24, 2015 | KitchenAid Dishwashers
Top rack not getting clean on Normal Cycle
Empty the dishwasher. Look at the 2 rotating plastic arms in it (like 2 bladed windmills) spin each one, do they move freely without hitting anything? If so remove the top one (its a press on fit) the look inside it with a torch, is there any debris or dirt inside it blocking it? Water has to flow inside it or it will not spin, and top rack gets no water spray.
Dec 20, 2013 | Dishwashers
Kenmore Dishwasher #665.16919001dishes on top rack are not getting clean.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are open. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and you'll need a Torx screwdriver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Jan 31, 2011 | Dishwashers
The top rack dishes are not being cleaned properly. It seems that the water is not makeing it way throught the feed arm, hence not being feeding the spray arm.
Hi
Jan 27, 2011 | Dishwashers
Dish washer not cleaning dishes in top rack
Hi
Jan 13, 2011 | Whirlpool GU2700XTSS / GU2700XTSY Built-in...
Dishes on upper rack are not being cleaned. Seems like upper sprayer is not working properly.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Daniel
Jan 01, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher is not cleaning top rack
If the top rack is not getting clean, then either the spray arm holes are slightly plugged and not allowing enough water flow to the machine. The water coming from the arms also makes the arms moved in a circular direction which also helps in cleaning. Either the arm is plugged and not allowing water flow or the arm is stuck and not rotating. I would use a toothpick and clean all the holes first. Then try it. Try and spin arm by hand and make sure it spins very easy and freely. If not, replace it or dismantle it and clean it really good so there are no clogs and it can spin easily.
Dec 31, 2010 | Jenn-Air 24 in. DW731 Built-in Dishwasher
Top arm not spinning
only the top rack isnt getting clean?
there is a little plastic circle in the middle of the bottom of the upper spray arm. turn it counter clock wise to pull the upper spray arm from the upper rack. make sure that isnt clogged and the spray holes are not clogged. otherwise....
the piece that the bottem spray arm plugs into and runs along the back wall of the tank to the top is called a feed tube. pull the bottom spray arm out. now you can see the part of the feed tube that feeds the upper spray arm water. does it pop out freely and easily? if so then you need a new feed tube, if not then its most likely your not achieving the right water level or your impeller connected to your circulation pump(motor) is clogged not supplying enough water pressure to travel up the feed tube to spin the upper spray arm.
Jul 13, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Top rack remains dirty
spin the top rotary arm to make sure it spins freely also take it off to see if its blocked (run it under tap) check all other filters too and when you load dishes make sure they do not obstuct top rotary arm if none of this works then it's time for an engineer im affraid good luck
Jan 26, 2008 | KitchenAid 24 in. KUDK02CR Built-in...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
62 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
