Question about Kenmore Microwave Ovens
I got a kenmore spacemaster and all i got is the stock # 85641. the model no. is gone and i need the handle on the door.
3 Suggested Answers
SOURCE: Kenmore spacemaster microwave Auto recipe 300
My 300 model number is 564 8898410.
Must be a later model.
I'm looking online for a operating manual.
Posted on Aug 29, 2009
SOURCE: I have an old Kenmore spacemaster over the range
I have a Kenmore Spacemaster model#564-8755380 the handle was falling off and the microwave would not heat after the handle was loss. Could the handle be the problem or could it be the heating eliment.
Posted on Apr 21, 2011
Will lg microwave handle 3650w1a100b substitute for Kenmore handle 3651w1a0022b?
As I bet you know, 3651W1A022B is the correct original part number for Kenmore (by LG) model 721.80019401 and as I'm sure you know, it has been discontinued, with no other substitutes listed.
You could take the old one and *some* appliance shops will try to visually match it for you to see if it would mount, even if the color or style is different.
You may be able to find an original in "new old stock" at some parts supplier, either locally or online. I would Google the part number, then call them and ask if the part is actually in stock on their shelves.
Some suppliers list them on their Web site, even though they would have to order them, and sometimes you wouldn't be told it is "No Longer Available" until some time after you have placed the order thinking it was available.
Or you may be able to fix yours. I would first wash the broken handle in a dishwasher, then only dry it with compressed air or let it air dry.
Then I would use JB Weld (or something similar) to pack into the broken end. Once it's dry, I would sand it as needed, then drill a new mounting hole for the screw.
Let me know at microwavecontrol.com if I can help further.
Oct 01, 2016 | Kenmore Microwave Ovens
Why does the fan keep running on a kenmore spacemaster 300?
Check those 3 micro switches in the door latch assembly. A bad microswitch can blow the main fuse. This usually ruins the microswitch.
Nov 13, 2017 | Kenmore Microwave Ovens
Kenmore spacemaster microwave Auto recipe 300 will not light up or do anything at all
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Mar 31, 2011 | Microwave Ovens
Loose handle.
To access the door screws on MOST microwave ovens, you need to remove the inner door panel that goes around the perimeter of the glass. The following link explains:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This can be peroformed with the door in place, or with the door removed. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 18, 2010 | Kenmore 62622 Microwave Oven
I have a Kenmore model #721.89940490 The door handle broke off and need to replace it, I do not see any screws. how do I access the mounting screws.
You will probably need to take the MW down and remove the outer case to access the hinge for the door.
just received a new door assembly for my Kenmore microwave and spent about an hour searching for help with installation to no avail. , but managed to replace it by prying the small pin out with a flat head screwdriver and removing the door. I reused the pin (after straightening it), and it works great.
The door handle is secured with the two screws from inside of the door. In order to access them you have to remove the inner door frame. You can find how to remove it in the video clip from one of our previous posts.
Aug 03, 2009 | Kenmore 62702 Microwave Oven
HOW DOES THE DOOR HANDLE ATTACH TO THE DOOR? THE OLD DOOR HANDLE IS OFF BUT THERE IS NO SCREWS OR WAY TO ATTACH THE NEW DOOR HANDLE.
Normally You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In some cases, you remove one screw, then gently rotate the handle to unlock & detach it.
You can find helpful exploded view diagrams and order any needed parts at the Sears parts site.
A full Sears/Kenmore model number has 3 digits, a dot, then 8 more digits, such as ###.########
Jun 15, 2009 | Kenmore Microwave Ovens
GE Model Spacemaker Microwave Model #JVM1650WB008 handle broken.
Appliance Repaired: General Electric Microwave
Model: g
Age Of Appliance: 5 - 10 years
took a screw driver and pride off plastic on inside of door. be carfule not to break it. only one of two screws that go into handle were visable. had to drill a hole in metal braket to get at second screw. you can just bend the metal braket back inorder to use drill. bend it back when done. took off handle and replaced it. snapped plastic piece I took off back in place and finished.
ge told me i needed to replace whole door. which they nolonger stock and I could not find a whole door for my model on web. found handlw on this website and did it my self
Mar 26, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
If you didn't locate that model number yet, the number should be 5648698510. I have the same unit and just had Sears do a minor repair on it. Luckily, some but not all parts are still available, so check the Sears Parts site to see if what you need is available.
Mar 28, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
49 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
