Question about Whirlpool Kitchen Ranges
I incerated baked potatoes in it last night. I have tried baking soda. It did not work.
  • Anonymous Mar 18, 2014
    My daughter has severe acne and Dr. Oz had a recipe for baking soda and honey as a mask for treatment do you know the recipe
Mt problem is solved.
Posted on May 07, 2008
How many teaspoons of baking powder equals one teaspoon of baking soda?
I'm by no means a baker, but the two are different. However, you can substitute, but you may not get what you are looking for and have to modify the recipe in other ways.
Generally, you will need 3 teaspoons of baking powder to equal a teaspoon of baking soda. But the baking soda is a base, and the baking powder is more neutral, so you may have to reduce the amount of acid in the recipe.
The following article explains it well.
The Difference Between Baking Soda and Baking Powder SimplyRecipes com
Good luck,
Paul
Dec 11, 2016 | Office Equipment & Supplies
How much baking powder equals one teaspoon of baking sodo?
Good luck,
Paul
I have a 3-year old Amana microwave installed above my stove. Last night I was baking two potatoes in the microwave. I noticed that the microwave sounded "louder" than normal. After about 13...
No! But it will need to be repaired. Did you wrap the potatoes in tin foil? The reason for the smoke needs to be found and repaired. Smoking means a short or a part shorted, failed, or wires touching another wire that did not blow any fuss.That is not good.
Trained technicians can help the mfg improve their products if they find the problem and report it to the Mfg.
LOL
Jan 28, 2011 | Amana MVH210W Microwave Oven
Brown residue from muratic acid fumes on stainless steel applianc
Just a thought it may not work.
Since Muratic acid caused the trouble try it to remove the stain. Then after its removed use baking soda to kill the acid and within 3 toi 4 hours re apply baking soda and re clean. Maybe do the cleaning 3 times just to be safe.
I only say this because to remove oil you use an oil based solvent. Water use a water base solvent.
So maybe ...
Then again maybe not
If this works or doesn't Id like to know.
The last thing to use is a piece of aluminum tape to cover the area so its not brown.
If this helped you please rate me accordingly and good luck.
Mar 13, 2009 | Kenmore Refrigerators
Need directions to clean my tappan oven
1. Add baking soda to a cool oven. Sprinkle a thick layer of baking soda onto the bottom of the oven. Make sure the oven is completely cool before you attempt to do this. 2. Spray the baking soda with water. Using a spray bottle, spray the baking soda down until it is damp, not saturated. The water and baking soda together will help break down the food particles. 3. Continue spraying baking soda as it dries out. Every few hours spray the baking soda down again to keep it moist. Continue this process over several hours, spraying water as the baking soda begins to dry out. 4. Scrape out the baking soda. Scrape the baking soda out of the oven. Food residue will be scraped out with the baking soda. 5. Rinse the bottom of the oven out thoroughly. Yes, you'll still have to rinse out the oven, but next time you cook your food won't have an added taste of oven cleaner.
If I had the rest of your model number I may find what Tappan now Fridgedaire Electrolux reccomends, but this is the least toxic. Have a great day..
Feb 08, 2009 | Tappan TEF242 Electric Kitchen Range
How clean oven??
  1. Buy an empty spray bottle and some baking soda.
    You'll find that baking soda is cheap -- especially if you buy in bulk.
  2. Using a funnel, place 3 heaping teaspoons of baking soda into the spray bottle.
    If the baking soda clogs the funnel, unclog it with water.
  3. Wash the baking soda into the spray bottle by running water into the funnel.
    Fill the bottle with water. After the bottle fills, you'll notice undissolved baking soda that has settled at the bottom of the bottle.
  4. Shake the spray bottle so that all the baking soda dissolves in the water.
    Unless all the baking soda is fully dissolved, some of it gets left behind in the bottom of the bottle as a residue.
  5. When the oven is cold, spray the baking soda and water solution on to the black stuff. Do this one or more times a day.
    It is important to work on a cold oven for two reasons:
    • Safety. You can't burn your hands if the oven is cold.
    • Containment. You'll get baking soda all over the house if you start with a hot oven. I know. I've done it.
      Starting with a cold oven solves the problem.
  6. Use your oven as you normally would. Keep spraying wet baking soda on to the top and sides of the interior of the oven between meals.
    Wet baking soda will break up the carbon sticking to the sides of the oven. Keep spraying baking soda on to the black stuff between meals until it is all gone.
    Don't worry about getting baking soda in your food. Baking soda is one of the prime ingredients of many recipes such as corn bread. It is safe to add it to your food should you do so inadvertently.
    Using this technique, the black carbon that was stuck to the sides of your oven will flow to the floor of your oven and settle there as a black carbon powder that can be wiped away.
    Your oven will look like a mess while this is in process. Choose a good time to do this.
  7. At your convenience, when the oven is cold, wipe your oven with a damp cloth.
    Eventually, you will have to wipe down your whole oven with a damp cloth. The black carbon and baking soda will will settle together on the bottom of your oven. Both are easily removed with a damp cloth.
    In theory, you will have to apply the spray bottle many times but you should only have to wipe down your oven once. Try not to wipe down the oven prematurely as this removes the active ingredient that makes the whole thing work -- the baking soda.
    Important! Let the baking soda accumulate so that it can do its job.
  8. Repeat, repeat, repeat until all the black carbon is gone.
Nov 10, 2008 | GE Kitchen Ranges
Fridgidaire stove oven baked potatoes one night the next day...nothing.
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
73 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
