Question about Neff B1641 Single circotherm super Stainless Steel Electric Oven
NEFF CIRCOFIRM OVEN HAS DIED? ITS 8 YEARS OLD, HAS ALWAYS WORKED WITHOUT FAULT BUT 2 DAYS AGO IT STOPED RESPONDING TO ANY CONTROL, AND THE WINDOW WHERE TEH TEMPERATURE RANGE IS DISPLAYED IS SHOWING -5- OR -S- ACCORDING TO MY WIFE. THE VARIOUSE MENU OPTIONS DO NOT LIGHT UP WHEN SELECTED, THE OVEN LIGHT IS OFF ALSO, TEH ONLY THING THATS SEEMS TO BE WORKING IS THE DIGITAL CLOCK . HAVE TRIED TURNING THE POWER ON AND OFF FOR UP TO A COUPLE OF HOURS IN ORDER TO SEE IF THE OVEN WILL RE-SET. BUT NO JOY, ANY IDEAS AS TO WHAT IS WRONG WILL BE APRECIATED. REGARDS MIKE
    Sergeant:
  • 228 Answers
The chid lock is activated!! how did you manage to do that accidentally??? the instruction manual tells you how to disable it from memory it is turning the oven mode selector switch 3 times beetween the light position and off quickly.
Posted on Aug 27, 2010
Oven light switching on and off
which model is it?
switch it off at the mains ie fuse boad...label cooker switch....for 10 seconds, then back on.
Sep 04, 2014 | Neff Ovens
Smell has started in our 8 month old Neff oven. No obvious reason for it - pretty clean and no unusual food cooked. Any ideas ?
There may be a problem with the cooling or extraction fan on the oven. All Neff appliances come with a two year manufacturers warranty, so I would advise you call them out on 0844 892 8999. If you attempt a repair yourself, you could invalidate the warranty.
All the best.
Sep 01, 2010 | Neff U1461 Double circotherm plus Electric...
MY NEFF DOUBLE OVEN IS ABOUT 8 YEARS OLD I HAVE CHANGED ELEMENT 2 OR 3 TIMES ONE RECENTLEY 2MTHS AGO NOW OVEN IS STILL TRIPPING OUT REGULARY ANY SUGGESTIONS PLEASE HAVE ALSO CHANGED RCD AND HAD ELECTRICIAN...
it sounds to me that the fan is not working properly. as the oven gets older the fans become weaker and then doesn't blow air over the element at a rate that can the temp down enough..
regards
Richard Saupe
http://www.saupe.co.uk
Oven Specialist
Mar 02, 2010 | Neff U1721 Double circotherm Electric Oven
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Neff oven internal wiring colours
red is positive and black is neutral normally on these ovens, dont recall seeing blue and lilac.
Apr 15, 2009 | Neff B1421 Electric Single Oven
Neff oven U1661 shows fault code -5-
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Sep 17, 2008 | Neff U1661 Double circotherm super...
Main oven tripping the fuse
probable fault to earth of circular element - gets worse when element hot. you will need a megga to confirm this.
May 22, 2008 | Neff U1721 Double circotherm Electric Oven
Neff B1641 Switched my oven on the other night it made a noise like a fuse blowing and went dead no lights no controls whatsoever i checked the power and i traced it all the way to the control panel...
check you have power at the clock - the clock terminals not the relay. if not, there is a cut-out stat in the back. check this is still ok. if there is power at the clock then the clock itself may be faulty. you can bypass the clock by joining the terminals to the clock relay and get the oven going this way. another common source of problems is the terminal block where mains comes in and is distributed. these terminal blocks often burn out.
May 04, 2007 | Neff B1641 Single circotherm super...
Neff B1641 Single circotherm super Stainless Steel Electric Oven Logo
135 people viewed this question
Top Neff Ovens Experts
ashburton
paulcarew
bobby1964
Level 1 Expert
Are you a Neff Oven Expert? Answer questions, earn points and help others
