Question about Miele S4210 Antares Bagged Canister Vacuum
Vacuum won't turn on. I just used yesterday - Miele S4210 Antares Bagged Canister Vacuum
  • 78 Answers
Look on the nozzle and see if it has a reset switch
Posted on Aug 27, 2010
What causes my Shark Vacuum to work only intermittently?
If the brush roller operation is intermittent, there may be hair jammed inside the end caps. The brush roller can be removed and the end caps also for inspection. Intermittent operation also can be caused by a stretched drive belt.
The periodic failure to pick up may be caused by something such as a ball of hair migrating through your vacuum cleaner and stopping from time to time to test your patience
Jun 26, 2013 | Shark Navigator Bagless Upright Vacuum
Won't turn off
It's highly probable that the Dyson power switch has gone bad.
You can buy dyson dc14 switch here.
The switch is located right behind the front covering of the neck or handle when you remove the telescopic wand. Please make sure that the vacuum is unplugged before you start this project.
May 27, 2013 | Dyson DC14 All floors Bagless Upright...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Brush doesn't turn all the time
The belt is worn out and you need to replace it. It's slipping and that's what you smell.
Nov 13, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
The vacuum keeps falling over and won't stand upright. The vacuum won't **** from the bottom, only from the hose in the handle.
No Vacuum will work for more than a few weeks
if you don't own an air compressor & blow them out
after every 2 or 3 uses
May 29, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
My vacuum worked fine yesterday and now doesn't start
To my knowledge, the on/off switch is the only area to turn your vacuum on or off. There might be a problem with your cord, or with the switch itself. I suggest checking for clogs and anything that may cause a problem.
I also suggest taking it to a local vacuum shop to have it looked and as you may need some new parts (cord/switch)
Apr 13, 2010 | Eureka Whirlwind 4388 Bagless Upright...
Vacuum doesn,t leave a foam over total area,
All simply if yesterday, but today... See cord of the feeding, sooner whole this housed, sliding contact if you woman, return in service, or have man)
Sep 22, 2009 | Kirby Generation 3 Bagged Upright Vacuum
Canister vacuum won't turn on
the cords inside might be frayed so you need to check that out.
Jul 03, 2009 | Kenmore Canister Vacuum Vacuum
Brushes wont turn on shampooer
Dear Momneville
I have the same steamcleaner and had the same problem, I took mine apart a found a clog between the turbine and the wheel that the turbine moves by vacuum when it gets glogged there is no vacuum to move the wheel. If you are not mechanically inclined in suggest you do not take it apart unless you think you can get it back together properly.
Hope this helps
ahill_1
Dec 24, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Miele S4210 Antares Bagged Canister Vacuum Logo
148 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
