Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
Hi, I have D Link ADSL 2640U +2 Modem, The problem I face is if my Internet connection is inactive[idle], it gets disconnected from the net.I face no problem if i keep on using the net. How can I fix the problem. Kindly help Jayesh Ariwala
  • 75 Answers
Just download and install Router Commander software, the program will prevents your connections from idle disconnects and other router problems.
Posted on Oct 04, 2010
Bsnl adsl modem configure with TL-MR3420 router!
make bsnl adsl router as abridge router , then connect tp link router from wan port with any one of lan port of adsl router , then configure tplink router connection depending how you get internet from your ISP
Jan 30, 2014 | TP-LINK TL-MR3420 Wireless Router
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have the DCM425 RCA Modem and I'd like to use it with another internet provider but I don't know how to get it connected. Can you help?
Hi.
You should have no problem using the modem with another internet provider as the modem is a cable modem and not a ADSL modem.
Make sure that your new ISP (internet service provider) is supplied by a cable company and not one that comes through the telephone line as the modem will not work if that is the case.
Once you have cable installed its as simple as connecting all the leads like the coaxial lead and the Ethernet lead. turn it on and you should be good to go after about 2 minutes.
Click on the link below for an on-line PDF operators manual for the RCA modem which will tell you exactly how to install the modem.
http://www.simplehelp.net/images/cable_modems/manuals/RCA_DCM425.pdf
Regards.
May 03, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
My modem is not working Power Led will be displed but not diplayed ADSL led, PPOE lead or LAN conection led. all are atteched with modem but
maybe there is no internet connection coming on your modem...ask your internet provider if your connection is disconnected..if its not..maybe your modem is not working properly..replacing it will help..
Feb 20, 2011 | D-Link Computers & Internet
My modem is connecting problem,it will connect after five minits it will disconnect. modem model:utstarcom-wa3002g4
I have a link about how to configure it to Always On mode with ADSL as the connection technology from the ISP.
http://www.indiabroadband.net/bsnl-broadband/4545-configuring-utstarcom-wa3002g4.html
If you are using other technology there might be difference on the settings. You can contact your ISP to find out the technology they are using which your modem connects to. You can apply for an additional IP address to improve the performance of your connection too. Make sure you have a filter on every phone line if you are sharing the phone jack with your ADSL connection. Most of time they should have done that when they install the ADSL but just in case.
Aug 18, 2010 | Computers & Internet
I have bought a wireless ADSL modem, Dlink DSL 2640u , How can I install and use it for another laptop? I want to use it without wire. Thanks
all wireless devices must be allowed in the router by either MAC address or by name. This is accomplished by logging into to the router and setting up the device in with the wireless setup feature in your router. The router will not allow the device to connect without permissions.
Aug 07, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
When the phone rings and I answer it, and I'm on
Hi, the problem is unlikely to be related to your wireless router and more likely your internet modem.
If sounds like you are most likely on a DSL internet connection.
If you have a DSL modem, you need to have a filter on your phones in the house to prevent internet disconnecting. Usually you get one with your adsl modem, but if you need more or if you did not get one you can purchase them from any computer store and possibly an electronics or even supermarket. They are very cheap.
Apr 06, 2010 | D-Link DI 514 Wireless Router (DI-514)
I have an ADSL D-Link modem (DSL-300G)that works fine. I hooked a D Link wired router, EBR-2310 and can't get to the internet. It use to work until one day recently the kid moved wires arround because no...
First: Connect your computer directly to the ADSL modem. It has an Ethernet port.
If you can't get to the Internet while your computer is connected directly to the modem, then ytour router never will either. Call ISP if you can't connect to the Internet when directly conencted to the modem.
Next: Check your router wires again, The modem must be connected to the "special" port on the router. Look at the router. There is one port separated from the rest. Connect the modem to that port. Conenct to the Internet.
Still no Internet?
Reset your router by pushing a stylus (straightened-out paperclip) into the reset "hole" on the router (with router powered ON).
Push & hold for 30 seconds or until the lights do their reset dance. Connect to the INternet.
Oct 07, 2009 | D-Link 4-Port Ethernet Broadband Router...
Vio and d-link wireless router dsl-2640u connection problem
hi
firstly check to see if the wireless is set for wireless access based on MAC address filtering
also check to see if both the laptop and the wifi router are communicating on the same channel
Jun 24, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
283 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
