Question about HP Photosmart D7460 Printer
Setting for blue tooth menu are greyed out and i am unable to select for change
  • HP Master
  • 4,924 Answers
If it is grayed than the bluetooth is not active ..take a look and initiate it from start button first ..it has to have something like that ..or it is faulty than and need replacing ..
Posted on Aug 27, 2010
How do I connect a blue tooth device that is already paired in my Samsung intensity 2?
Disconnect it first. means power off. unpair the device restart devices pair it again.
Oct 11, 2017 | Samsung Intensity II SCH-U460 Grey Verizon...
How do i set the blue tooth settings on my nokia c3
From your phone's menu, select 'settings'.
Go to 'connectivity', select 'bluetooth'. Under the bluetooth menu, you would see the following sub menu
1. Blue tooth
can be set to either 'on' or 'off'.
2.conn. to audio access - you select this if yuo want to connect your phone to a bluetooth earpiece.
3. Paired device
under this, you would see 'add
new device'. You select it if there
is a new device you want to add.
4. Active devices - it shows any device that is active.
5. Phone visibility.
Select 'always visible' if you want
your device to always be visible
to any active device.
Select 'temporarily visible' if you
want to be temporarily visible.
Select 'hidden' if you want to be
hidden. To other devices.
6. My phones' name. Select this to change your phones' name from the default to any name of your choice.
Hope this was helpful? Please do indicate. Success.
Apr 11, 2011 | Nokia C3 Cell Phone
Unable to receive files via blue tooth. i am getting a message operation failed
reset your phone to factory setting.go to menu, setting,scroll down and click restore to factory setting or use this code *#7780#
Mar 17, 2011 | Nokia 6300 Cellular Phone
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
Unable to connect bluetooth to another cell
Some of the carriers actually have a lockout on Blue tooth transfers. So depending upon your carrier even tough the phone itself is capable it may not be allowed. I work at US Cellular and all the B tooth options on these phone are unlocked, however they are unable to link to a verizon or sprint phone for example without having their associated data plan.
The process for doing the pairing is rather simple and if you followed the steps and they still wont its a lockout.
Go to your blue tooth setting on one of the phones, turn the find me mode on or make visable to others.
take the second phone and go to blue tooth check registered devices and click new search. once you find the other phone click pair and eenter in 0000, the other phone will ask if you want to pair in which case enter the 0000 pass code again.
Once paired if you are transfering pics or music go to your media library or pic gallary and find the fill. Select options and send via blue tooth, it will bring up the registered list and select the phone you are transfering to. that should be all you need to do, if it says not supported or unable to connect the BT is disabled and you need to speak with your wireless carier for assistance.
Nov 20, 2010 | Cell Phones
How do I send a picture message via bluetooth from my Samsung Moment
Hi
Via wap:
Go to: www.samsungmobile.com, register a free account then go to the play menu, click photo club and you should then see a photo studio tab click this then Launch mobile studio, it could take a while to launch but once it has you can select your phone and upload images, edit them then save them to an online photo-album which you can then access via wap and download your images.
Via Blue-tooth:
Make sure your computer blue-tooth is set to be visible not hidden.
The goto: Settings > Connectivity > Blue tooth > My Devices > Search new device (activate blue-tooth if it asks) select your computer enter a code, a box should the pop up on your computer screen saying samsung wishes to pair with you and it will ask you for a code, enter the code you put into your phone then find your computer on the list of devices select options and authorize device, this will allow your computer to send files to your phone without you having to click yes every time.
Now go into your blue-tooth program select send file or object push the browse through your file's until you find the picture you want to send then select send. The picture will go into the images file in your "Fun box"
Thanks
Aug 13, 2010 | Cell Phones
HOW DO I CONNECT MY BLUETOOTH TO MY LG RUMOR PHNE
first thing make sure your blue tooth is fully charge and on. Then go into menu go to setting find blue tooth setting go in there make sure your phone is set on enable blue tooth then turn on searching then it should pull all the blue tooth signals that are around the phone then just select the bluetooth device
Nov 19, 2009 | LG RUMOR Cellular Phone
How to connect between blue tooth with samsung phone ?
With a samsung cell phone press the MENU button then scroll to SETTINGS then scroll to BLUETOOTH. Once there select the option ENABLE and turn on bluetooth then sync and your set. Also make sure that your blue tooth is compatible with your phone.
Dec 07, 2008 | Lands Phones
Motorola h350 blue tooth headset microphone does not work
1.Press and hold the Multifunction button in the middle of a boom headset while the headset is closed. The light will glow blue.2.Open the boom microphone and the blue light should remain on. If not, repeat step 1.
3.On the cell phone, press Menu > Settings > Connection > Bluetooth > Handsfree > New Device
4.Select H350 once a connection is detected.
5.The passkey "0000" is now entered to confirm the connection has been made.
6.The cell phone screen will now read "Bluetooth Connection".
Tips:
1.Provided you set the Bluetooth power to "On" after the initial connection has been made, the phone will automatically re-connect to the headset.
2.To set the Bluetooth power on - Press Menu, Select Settings, then Connections, then Bluetooth link, scroll to Setup and select that. Scroll to Power and chose Change. Scroll to On and press Select. The screen should now read "Changed: Power On".
3.Test Your Connection: Close the headset and watch for cell phone to say "Disconnected". Re-open the headset and the phone should be connected automatically and will now display "Bluetooth Connected".
please give good rating if the solution works.
Thanks for using FixYa.
May 30, 2008 | Motorola Mobility Bluetooth Headset H3...
Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Dec 22, 2007 | Motorola Mobility Bluetooth Hands Free...
HP Photosmart D7460 Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
