Question about Samsung SyncMaster 940MW 19" LCD Monitor
Describe your samsung syncmaster 940mw poor reception Problem: I thought the TV tuner was digital-ready, but I can't pick up hardly any stations with it - the ones I do get are fuzzy. But with the same antenna, my HDTV picks up crystal clear digital channels with the same antenna. Do I need to use one of those digital converter boxes required for older TVs to pick up the new digital channels with my antenna?
    President:
  • 2,678 Answers
From your descriptiopn it would appear so.
Posted on Aug 27, 2010
No enciende samsung 940mw ya le cambie los capacitores y trabajo bien 4 dias
Carnot get Digital on my tv keeps saying cannot access digital services Was ok but not sure wats happened thanks
Dec 09, 2013 | Samsung SyncMaster 940MW 19 in. LCD...
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or...
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Syncmaster 940 mw says 'digital' on the front but I cannot receive digital tv after the switchover. Do I need a set top box?
Yes, You will need a digital decoder box. The tuner in the Samsung 940MW TV does not decode digital signals. The digital input that you are seeing is for the DVI video input on the back that you use when you connect the unit to a DVI port on a computer. Any of the digital decoder boxes from Radio Shack, Walmart or Best Buy type stores will work just fine.
I hope this helps, If so please rate my solution.
Sep 24, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Do i need a converter box for a samsung syncmaster 940 mw
It depends. What are you using the monitor for? If you want to watch digital TV, you need a digital to analog converter. (It has an NTSC tuner.) Note: the digital to analog converters that were subsidized by the US government coupon only gave SD out.
If you are connecting to a PC, it has DVI-D (21 pin SCART) and VGA connections (15 pin SCART). (An HDMI to DVI cable or adapter would connect to HDMI video cards.) Most other set-top boxes will connect to the component, composite or S-video connectors.
I hope this helps.
Jan 07, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
No reception on Polariod flat screen TV
this wright this tv is hdtv monitor and does not have digital tuner
Sep 01, 2009 | Polaroid FLM-1911 19 in. LCD Television
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Poor reception on atsc portable tv
an external or outside antenna will improve the amount of stations picked up and maybe a amplified antenna will help
but the boxes they sell seem to do better in reception even with only a rabbit ear antenna.
I use a box on my 32in LCD because the internal tuner just does not get all the channels without having to get up and move the antenna and the outside antenna , well I'm not going to go out there to move it all the time , and the amplified antenna I still have to keep getting up to move the antenna
so in all the box( "zenith","digital stream"are good , have yet to test others) works the best in recieving the digital channels without much worry of the antenna
Mar 13, 2009 | RCA 9V345T 9 in. Portable Television
Samsung SyncMaster 940MW 19" LCD Monitor Logo
314 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
