Question about Daewoo DW500M Top Load Washer
What value capacitor it uses - Daewoo DW500M Top Load Washer
  • Daewoo Master
  • 43,501 Answers
Look on the side of the existing cap... it will have number and MFD after it that is the valve you need also match the voltage...
heatman101
Posted on Aug 27, 2010
Why do some central air condensing units have 2 capacitors?
some use dual capacitors in one can with different values such as 35/5uf. others use the same values in two different cans.
Sep 14, 2015 | Heating & Cooling
Behringer xenyx 1222fx mixer capasitor
check the capacitor and its value and type. i havent see the equipment but knows about capacitors etc
it usually comes in values like 0.01 2.0022 and so on and higher value like 1 mfd to couple of thousand mfd.you shouls use the same value and the voltage for the replacement one has to be same or more in voltage since higher voltage is no harm but lower voltage will explode or burn in electrical appliances it is used as filters to block spark in the carbon or starting capacitor thich helps to run the motor if it is built to run with a starting capacitor like the one used in water pumps or electrical ceiling fans.
Aug 29, 2012 | Cars & Trucks
Nakamichi re 10 capacitor value
Its 10000uF 63V and use dual capacitors.
May 28, 2012 | Nakamichi RE-10 Receiver
Coloured stripes all down left hand side of tv. but does disappear after 20minutes. help please
This is failure of some capacitors in the circuit . There are electrolytic capacitors which loose value in time or it is due to defects in the production resulting in leaks causing lowering of value. When the circuit is powered the capacitors slowly regain power to get back to the near value and hence the circuit behaves properly . Have visual check and change any suspected leaked capacitors. If not use a hair dryer to heat suspected section , if the fault clears on cold start change capacitors in this section.
Feb 02, 2011 | Toshiba Televison & Video
I've connected a powered sub (bazooka BTA10250D) to my factory system (09 altima coupe 2.5s). I want to be able to control bass on the component speakers and the subwoofer separately. There is no sub out...
We used to use what we call bass blocker capacitors on the component speakers to block the bass coming from the head unit and to allow the bass to only come from the subs...there is several values of these capacitors that you can use(different values correlate to different frequencies). These type of capacitors are available at Radio Shack. You will need to request a NON-POLARIZED Electrolytic capacitor at a voltage rating of not less than 25 Volts...As for the value of the microfarad rating..you may need to experiment with different microfarad values to get the sound you desire...standard microfarad values are 1uF, 2.2uF, 3.3uF, 4.7uF, 10uF, 22 uF, 33uF, 47uF.
You probably won't need to go any higher on the value than those listed....in my experience, I have found the 4.7uF and 10uF to be good for most speakers...to install these...you need to put one inline with the positive lead to each component speaker.
Jan 14, 2011 | Bazooka BTA10250D Car Subwoofer
I have intel 845 GVSR mother board in that some capacitor are week i want replace it but i not getting same value capacitor. The capacitor value is 820mfd/6.3 v. Please suggest equalant value
hmmmm....
may I ask how did you know the capacitors are already weak? Do they look bloated and acid just came out?
The value of 820 mfd must not be changed, The value of voltage can be increase at 10 volts maximum!
Usually i go for the parts in my local computer shop where you could get theparts taken from a dead board!
Hope thats helps you out!
Dec 07, 2010 | Intel D845GVSR Motherboard
How do you fix the clock display
No or dim display? You can replace the clock at about $160.00, or Check for a burned capacitor on the clock board, The likely culprit is labeled C3 on the board, its a 35 Volt 68 mF capacitor that needs to be replaced with a high temp (105 degree C) capacitor . Any capacitor that shows signs of discoloration and or leakage should be replaced with the same value but high temp. component. You can use regular capacitors of near equal values in a pinch but find the good ones of the correct values for a long term fix.
Aug 16, 2009 | Jenn-Air JJW8530C Expressions Collection...
Fan not turning
Check fan capacitor,disconnect capacitor and measure it with ohm meter,put value on ohm meter ohm x100 or more,measure capacitor
it must show some value but it will be very fast,if there is no value change a capacitor,a new must have same parameters(values) as old
e.g. 80 micro F,220(110,380)V.Note a wire which was on capacitor.
If not capacitor,check fan motor,also with ohm meter,measure all wire for each other,ohm meter must show some value,e.g. 25 ohm.
DISCONNECT air conditioner FROM ELECTRIC POWER WHEN YOU WORK THIS,AND BEFORE MEASURING CAPACITOR SHORT CUT IT WITH A ISOLATED SCREWDRIVER!
Jul 02, 2009 | Ruud Matching Split Air Conditioner
We can't replace the capacitor because the value is erase. i don't know the right value.. And is there an specific starting relay to use? Or is there any compatible capacitor and relay for it?
The capacitor would need to be checke when not connected to power. There may be another reason for the capacitor and relay heating. For example the motor winding are breaking down or the wiring to the compressor is incorrect. below is a photo of where to locate the model number of your refrigerator. I will help you if you like, Thanks, Sea Breeze
May 27, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
6800uf/16v Capacitor?
You can use a higher voltage capacitors without problems its the value of uf that should remain the same. But sometimes you can use a higher uf like a 330uf can be replaced with 470uf but never go lower than the original value on uf and voltage. But you can safely use 6800uf 25v or 35v.
Jul 07, 2008 | RCA RT2500 System
Daewoo DW500M Top Load Washer Logo
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
