Question about Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
The vacuum voice changes after turning on and it is not sucking any dust. When it happened before I pulled a pen out of the sucksion line but this time I can't find anything thats hindering the path.
  • 78 Answers
Take the hose off and use a long wooden handle like a broom handle see if they is a clog in the hose by putting the handle into the hose
Posted on Aug 27, 2010
If I do not have any suction, is it the motor . I changed the clutch. My brushes are rolling and checked for blocks . What is my next step?
Hi there are several reasons, motor failing could be one but if it is spinning it will be sucking, look in the short flexible hose for a block, pull out the inspection bend and the double clip unit at the side and check these. Are all you seals in place and not leaking? With the vacuum cleaner in the upright position turn it on is the air being sucked into the hand wand? if it sucks here then blockage is before the diverter which is in the lower part. If the suction is low in the upright positon, did you remove the bin and cyclone and seperate the two? there is likely a build up of dust etc. in the cyclone. There are also pleanty of Youtube video's. If it is all clean and clear borrow a similar unit and swap over the bin/cylone and the various interchangeable parts, finally have you replaced the filters?
Nov 23, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka airspeed one
DustcupScreen
Latch
Pull dust cup latch to release
dust cup. Remove filter and wash. Allow to air dry thoroughly (24 hours) before placing back in dust cup
Empty the dust cup into the trash container. Wipe debris off screen.
Hold dust cup handle in one hand and the bottom of dust cup in the other, turn dust cup counter clockwise to unlock the cup from the lid.
Hold dust cup handle in one hand and the bottom of dust cup in the other, line up arrow on dust cup with unlock icon on backside of dust cup. Turn clockwise to lock the cup to the lid.
Replacing the Belt
Unplug vacuum.
Recline cleaner back. Using Philips screwdriver, remove 4 screws from hood.
Using thumbs, push down on height adjust knob, while pulling up on
inside hood edges with fingers. Lift and remove hood.
Lift left side of brushroll out of
grooves. Then lift right side of
brushroll out of grooves.
Line up corners of hood and put hood tab inside the front of cleaner. From front to back, push hood onto base, keeping hood in base grooves, and line up 4 screw hol
Remove belt from the brushroll and motor shaft. Loop new belt over motor shaft and brushroll, onto grey belt pulley.
Jun 28, 2013 | Vacuums
Dust and air coming from back side of vacuum cleaner
the bag of ur vacuum cleaner is full. thats y it is happening...
clean the bag of ur vacuum cleaner.
n check is there any blockage in the vacuum pipe, if any then remove that.
Oct 29, 2011 | Sharp Vacuums
Losing sucksion
If you look underneath your DC07 you will see a short length of clear plastic hose with spiral wire reinforcement. Quite often this hose splits (which lets in air and reduces suction at the brush head). Check this hose carefully, as a split is not always immediately obvious. If necessary, remove it by just pulling it away from the end nearest the motor and then unscrewing it from the brush end. A new hose costs very little so it's hardly worth trying to seal a split with tape.
If this is not the problem, post a reply and I'll try again. Good luck!
Jan 15, 2010 | Dyson DC07 All Floors Bagless Upright...
Soinds weird
dysons web site has an online area where you can walk through common problems like this:
http://www.dyson.com.au/support/help.asp?article=2&product=DC18-ALLFLOORS-AU
Apr 06, 2009 | Dyson DC18 all floors Bagless Upright...
I sucked up a dusing cloth with my ducted vacuum cleaner and now it does not **** at all. Help can not afford a three hundred dollar bill. blocked
Turn off the power on the main vacuum unit. Then thread a plumber's snake or stiff small gauge wire from the outlet you were plugged into when the dust cloth got sucked up. With any luck, you'll be able to push it through a bit or with a small bend at the tip of the wire, you might catch hold of the rag and pull it out. You could also try sucking out the line with a shop vac by fitting it tightly into the outlet and turning on the vacuum.
hope it helps.
please rate this solution.
Thanks for using FixYa.
Feb 13, 2009 | Emerson Vacuums
Please elaborate on the problem in detail.. Your vacuum sucked up a 'dusting cloth" ? Your description of a 'ducted vacuum' implies it is a central vac system ...is that true? If not please explain what you are using? The more details the more likely I can help...
Sep 14, 2008 | Samsung Quiet Jet 9068 Bagged Canister...
Vaccum has no suction
Here is what we did to fix the problem of our vacuum having no suction.
We unscrewed the three screws on the back and took the hose off of the vacuum.  Then we took the hose outside and put the water hose through the vacuum hose and turned on the water.  After about 30 second the water pushed through a dust bunny the size of a fist and a marker.  Basically, the vacuum did not have suction because the hose was clogged with dust, etc.  After reassembling the vacuum, it worked just fine.
May 11, 2008 | Kenmore 34923 / 34925 Progressive Bagged...
Blows dust and dirt out of brush area
Did you make sure to cut all the strings, hair, etc. out of the brush attachment on the bottom? Look in the corners too to make sure none has gotten stuck on the sides that needs to be cut out.
Jun 03, 2007 | Kenmore 25812 / 25813 Progressive Bagged...
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum Logo
21 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
