Question about Dell PowerEdge 1800 Server
I have a Dell Poweredge 1800 with 4 Cheetah 10K.7 Ultra U320 SCSI Drives which are supposed to be mirroring each other in case of failure of one hard drive the exact same thing is on the others. Drives 1 & 4 show failure. When turning it the server won't boot up and shows "No Boot Device Available." If Drives 2 and 3 are truly a mirror of 1 and 4, I am assuming that if I could put Drive 2 in place of Drive 1, the server may boot. When I do this, the screen reads that "SCSI Drives not found at correct positions. Drive roaming done by firmware." Is there anyway to place working Drive 2 in slot 1 and change the utility configuration so a good drive will be in slot one and I can see if it will boot up?
  • 428 Answers
Hi!
This is a quite serious matter to be solved. The information you have provided is not enough at all.
What you have to include in here:
  1. First, Be precise. Don't assume.
  2. How did you recognized the failure. Which indicators or POST/BIOS/RAID BIOS reported you the errors? Was it from the OpenManageSA?
  3. Please specify the Hardware Controller model and manufacturer with the version (RAID controller).
  4. Which Operating System do you run (or ran)?
  5. Are these disks Hot Swappable?
  6. Have you used hardware RAID controller or software RAID? Provided by OS.
  7. Do you have Dell OpenManage Server Administrator?
  8. How do you describe the RAID configuration? Are you sure that Disk 1 and 4 are mirrored to 2 and 3? You must be precise. Because raids can be used in many ways. You can combine any two disks and mirror them to any two disks. Even though it prevents hard drive failures, if your OS had an issue Mirrors may not be an option to recover it.
  9. That message is a Warning Message. However Drive Roaming has completed. You don't need to worry about that.
  10. If your BIOS has associated firmware controllers you could rebuild the array. But you may have to add new disks to replace others. You may need to update the firmware if necessary.
  11. Then if you plan to use disk 2 and 3, you have to position them to 1 and 4. Then try to rebuild the array. But you may have to have Controller Drive installed on the disk. That varies from type to type. So I cannot say exactly. However if the mirroring of the OS is done to one disk, that disk would be enough. But you have to be certain. Reconfiguring should be done using both the disks replaced if you do not know anything about the configuration.
  12. Check BOOT ORDER. Change it if necessary. If disks fail again check one by one and repair them using a separate machine.
  13. Use Dell Software (OpenManage Server Administrator, if its the one available). Rebuild and or Resync the array.
  14. If boot record errors occur, you have to boot from CD/DVD and repair the Boot Record and/or MBR.
  15. If you need any other issue like BSOD, please write them down. Make sure the OS is not corrupted. If you backed up the System Status, restore it in such a case. Do an In-place Upgrade otherwise (will replace the OS files only, not data).
  16. Use the manuals for Dell Server and RAID Controller if you do not know how to use properly.
  17. If all the options are not working, you have to contact an engineer at Dell.
Feel free to contact again.
Thanks for using Fixya!
-Lasitha
Posted on Sep 04, 2010
PowerEdge 1800 Server: I have a Dell power edge 1800 that was used as a s...
yes you can do that but you need the drivers for the scsi interface. when you install windows xp (for example) i think you may have to press the f6 key on the installation to add these drivers.
Otherwise, installation wont take place.
May 17, 2010 | Dell PowerEdge 1800 Server
How can i onnect my ext. hard drive with a scsi connector to my computer?
I'm not sure you can get a USB SCSI hard drive adapter case.
I've got an Adaptec SCSI to USB adapter cable and found ot very useful.
It is not as handy as a USB hard drive case bur it works.
Dec 03, 2009 | Fantom Drives Premier (4606146-U320) 146...
I cant boot my server the hard drive can not be detected
Try taking the side off and removing and replacing all the hard drive leads. Remove and replace all the scsi drives and generally check for loose connections. If this does not work you will need to post more infomation.
Oct 29, 2009 | Dell PowerEdge 1800 Server
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Jun 03, 2009 | Dell PowerEdge 1800 Server
Flashing redlight on the front
Yes. Here are some things that could be an issue:
a problem with power supplies, fans, system temperature, or SCSI hard drives.
Install the Dell Open Manager software to run diagnostic. It will tell you what needs to be fixed.
Apr 29, 2009 | Dell PowerEdge 1800 Server
Dell poweredge 1800 scsi drive not found
check if the drive is showing in the bios of the server,
shut down the server, take out the power cable, press and hold the power button so as to realease flea power, open the server, and reseat the data cable at both ends and if there is another power cable available in the server swap it with the existing cable plugged into the scsi drive.
and now try to start your server.
Further Queries are welcome
Feb 26, 2009 | Dell PowerEdge 1800 Server
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Dell poweredge 2600 upgrade
Look at the service tag on the unit and go to support.dell.com to get the specs on the exisitng drives. Mine came with Seagate Ultra320 SCSI 80Pin 15K drives, You can shop for the 146GB versions and use your existing caddy's if you would like.
May 27, 2008 | Dell G6632 146 GB SCSI Ultra320 Hard Drive
Dell PowerEdge 1800 Server Logo
772 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
