Question about Shop Vac (984-03-10) Vacuum
I am vacueming concrete dust the filter is not filtering properly and the dust is bloing out of the vacuum
  • Shop Vac Master
  • 43,501 Answers
When doing fine dust you need to get the paper filters that slide over the foam one and then also get the bag that slips right over the hole coming into the tank... this combination will get you dust free...
heatman101
Posted on Aug 27, 2010
MAINTAINING A EUREKA BAGLESS VACUUM
Helo Reader,
You can purchase replacement parts directly from Govacuum with an exclusive 11% discount coupon only for Fixya.com readers, use code: FIXYA11 at checkout to avail the offer. We also offer free shipping over $35.
Eureka Style U Belt - https://www.govacuum.com/products/eureka-u-extended-life-belt-set-of-2
Eureka HF7 Filter https://www.govacuum.com/products/genuine-eureka-premium-hf-7-hepa-filter-with-arm-hammer-61850c-1-filter
Hoover parts - https://www.govacuum.com/collections/hoover
Jeethu
Govacuum Team
https://www.govacuum.com9_17_2017_3_49_04_pm.jpg
Oct 04, 2014 | Eureka Altima Upright Vacuum Model 2996AVS...
Dust goes to filter
is the canister sealing properly? The air enters the canister under high pressure and it should slow down greatly in there so the heavier (dust) particles will fall to the bottom of the canister and the air should then pass through the filter under a reduced pressure. If the air is easily escaping the canister area without slowing down the dust cannot settle. It should look like a cyclone in the canister, if it's not swirling in one direction but rather bouncing around, look at the inlet to the canister for build up or an obstruction also. If the canister is not sealing the the air will remain moving rapidly and carry the dust along with it. I would also check your filter for a tare along the seam.
Apr 03, 2013 | Dyson DC08 Cylinder Bagless Canister...
Overheating and not sucking properly
You most like have a blockage in the vacuum hose or the filter is choked with dust. Clear the blockage and filter and the suction will return to normal.
Dec 06, 2012 | Miele Vacuums
My Riccar Upright leave lines of debris when I use it. Can you help?
Inspect the filter.Open the secondary filter on the base of the vacuum to ensure that dirt and debris have not collected on the filter, as this will limit motor performance. Remove the filter from the dust compartment and rinse with water to clean. Allow it to dry completely and return to the dust compartment.--------
Also check if dust bag is got over full and that is causing the problem.Open the dust compartment, take the old dust bag out of the bag holder and discard. Open the end of a new dust bag and attach to the dust bag holder. Close the dust compartment and tighten the dust cover.Also check properly that dust compartment is not got loose. Open cleaning attachment and check the hoses and nozzles on the frequently to ensure that they are free of dirt, obstruction or hair.Also inspect the brushes, if there is already dirt got stuck in the brushes and that is causing the problem.Clean the brushed.---------- This will help, to confirm where the problem is and to resolve the dirt /debris issue.----- Thanks.Helpmech.
Sep 06, 2011 | Vacuums
Has no suction
1. Remove dust collector compartment/s. Look for any filters, remove and clean. (Make sure you DO NOT clean filters with water.) Take filter/s outside and "slap" them against a flat surface. (Filter will be very messy to clean)
2. Replace all filters and compartments.
3. Also try using a wire hanger and try to reach as far down the hose as possible to remove any obstruction/s.
Note: Clean vacuum filters frequently to ensure proper suction.
Feb 10, 2011 | Bissell 3920 Bagless Upright Vacuum
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
Roomba 550 dust bin always empty but filter and brushes always need cleaning. doesn't seem to clean as well as in the beginning
Sounds like you either have a very clean floor, and only dust remains OR, you have dust and baby powder on the floor clogging the hepa filter. THIS time wash the filter with water, then check for blockage in your waste gate area.
Feb 22, 2010 | iRobot Roomba 550 Vacuum
My vacum has no suction power it spray the shampoo but it won't **** it up. Thnis Vacuem is a Bissell 9400
make sure the selector for carpet or tools is set to floor. also make sure water tank is seated well. clean filter in tank.make sure tank seals are in tact. good luck
Mar 25, 2008 | Vacuums
Upper Filter gets clogged quickly
You may have to replace the filters, air maybe restricted going thru them. The main filter is part #73494, and the foam #74038. Also make sure the SLINGER/CYCLONE ASSY part #74068 isn't clogged up.
Jun 10, 2007 | Eureka 5892AVZ Bagless Upright Cyclonic...
Shop Vac (984-03-10) Vacuum Logo
Top Shop Vac Vacuums Experts
Mike
maple flats
Level 1 Expert
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
