Question about Kenmore 63663 Microwave Oven
What does it mean when your microwave shuts down and flashes F-9
  • Kenmore Master
  • 17,130 Answers
It is possible that the magnetron is faulty as there is a load indication to the board. it can also be the failure of the capacitor, the board or a faulty thermal switch.
check the Thermal cut off switch, check the capacitor or disconnect the magnetron to confirm if the fault changes.If so you have identified the fault.
Posted on Aug 27, 2010
Panasonic 1250w genius senor inverter less then a year old. Control panel lights up, works.microwave itself does not, control panel shuts off in a few seconds
When a Panasonic Inverter Microwave shuts off after a feew seconds, it is either a bad inverter which is the quite expensive circuit board that powers the magnetron that puts out the microwave energy, or a bad magnetron, Or BOTH typically this would be a costly repair, But since it is still under warranty. You need to find a Panasonic warranty service provider in your area. If it is a counter top unit, you may have to take it to them for repair.
Jul 05, 2017 | Panasonic Microwave Ovens
What is the se code that comes up on the oven, and it wount work? How can we fix this error code?
Hi longislandlu,
SE stands for "Sensor Error". This appears if the keypad is held down for longer than 10 seconds but if not held down this means that your humidity sensor has shorted and needs to be replaced. You will need to uninstall the entire unit and remove the outer shell to access the sensor that needs to be replaced. It will be mounted somewhere around one of the vent on the cavity of the microwave. You may contact Sears for the replacement part at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central.
Hope this helps.
Thank you for using FixYa.
Mar 31, 2011 | Samsung SMH9187ST Microwave Oven
Our microwave has an error code -SE- and will not work what is this and how do we fix it.
Hi wmp_44,
Hope this helps.
Feb 18, 2011 | Samsung SMH7174BC Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
My Kenmore Elite Microwave Model No. 721.64683300 does not seem to be heating well and will shut off and flash an F9 code. What does the F9 code mean
Oct 07, 2009 | Kenmore Microwave Ovens
Shuts down after running about 8-9 seconds.
We'd need the full model number to be sure, but it sounds like an inverter failure. Due to the lethal voltages involved, I do not recommend that a person without training and experience ever work on these models. I would call Sears for service. See http://www.sears.com
Sep 15, 2007 | Kenmore 80883 Microwave Oven
Microwave completely shut off, including the display
check the diode and the cap they like to go bad.good luck
Apr 06, 2007 | GE Advantium 120 Convection/Microwave Oven
Kenmore 63663 Microwave Oven Logo
55 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
