Question about Garden
I NEED A MANUAL FOR TORO WORKHORSE RIDER MODEL 71225
2 Suggested Answers
  • 3074 Answers
SOURCE: I AM LOOKING FOR FREE REPAIR MANUAL THAT I CAN
this may help Tim:
https://lookup3.toro.com/request/request.cfm
Posted on Oct 16, 2010
Have toro workhorse 1996 won't shut off. All connections clean or new. Checked pto and neutral safety and won't start with them not position. The seat safety makes the solenoid click when I sit on it.
The model number is going to be needed The issue is most likely the ignition switch is made to short out the ignition If it goes bad or become disconnected then it wont shut it off.
May 24, 2018 | Toro Garden
I have a new toro rider mower and can I put it in reverse without turning the blade off
There should be a switch or setting on the ignition for this. Check your manual
Jan 05, 2018 | Toro Garden
Why won't my toro model 71225 15 horse hXL m554201196. Will not pick leaves
I do not pick up leaves. I just keep mowing over them until they are very small pieces. Over the winter they decompose and fertilize the lawn.
Nov 06, 2015 | Toro Garden
Why did my Toro Wheel Horse model # 71225 stop while I was mowing the lawn? Why does it not turn over? Charger indicates full charge. What can I do to get this tractor started? Where can I obtain a re
DOES IT TURN OVER BY HAND? IF IT WAS LOW OR RUN OUT OF OIL IT MAY HAVE SEIZED UP AND THE CRANKSHAFT AND CONNECTING ROD HAVE LOST THEIR BEARING SURFACE AND SEIZED. pERHAPS YOUR STARTER MOTOR IS FROZEN UP AND NEEDS REPAIR/REPLACEMENT. i DON'T HAVE MUCH TO GO ON WITH THE SHORT DESCRIPTION AND NOT MANY DETAILS.
Aug 12, 2014 | Toro Garden
I have Toro Wheel Horse model # 71225 and does not turn over. Charger indicates full charge
pull the plug out and see if it will turn over it could have overheated causing it to lock up if it is look at buying short block are new motor but befor doing this how old is it is it worth buying a new motor
Belt diagram
HOPE THIS HELPS.. http://www.toro.com/en-us/parts/Pages/PartsDetails.aspx?mybeid=34870&serialNumber=310000001&modelNumber=74366&searchTerm=9lzIRv+p5zeMaPWIo2YCaldb2KV6U4WnyxmRpPSpeQehTowzmaCEK/baRX71tPfJ&defaultTab=parts
Apr 23, 2014 | Toro Zero Turn Rider 74366 Lawn Mower...
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
Toro workhorse rider leaks oil
what bolts are you tightening if it is the bolts going up from the inside the deck then you are tightening the wrong ones they are sitting on top of the deck under engine the bolts under deck need to be taken out motor taken off then tighten crank case bolts to stop leak
Jun 22, 2010 | Poulan "Poulan" Push Mower
Garden Logo
200 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
