Question about Cortelco Colleague 2200 Corded Phone (220021TP2-27S)
I have a 4-line multi-user capable Cortelco phone that has suddenly started making a rolling beeping sound for no real reason. Sometimes it is accompanies by a "Power Outage" message. I have tried disconnecting and reconnecting the power and phone lines to it. It will stop for a while and then start back up with the beeping. Any suggestions?
Suction stops when vacuuming with the DC40 model
There may be a clog where the air flows from the brush roll into the vacuum
Jan 29, 2014 | Dyson DC40 Multi-floor Vacuum DC40
Cortelco 2740 how does it work?
here is the PDF file that contains the manual for the Cordelco 2740
http://www.cortelco.com/manual/2740_manual.pdf
Oct 31, 2012 | Cortelco Lands Phones
Hi my RCA Visys phone, all of a sudden, keeps beeping
You directed this question at me, but unfortunately I'm unable to provide you with a "real" solution at this time. FixYa has informed me that by providing you with this "solution" your question will then be made visible to other experts; hopefully one of them will be able to provide you with a real solution.
Thank you for using FixYa.
Nov 28, 2011 | RCA ViSYS 2-Line Speakerphone
Printer header path type 1, 2, and 4 prolem request for feeding back
If the media does not feed into the in-feed slot in the media cabinet, try the following:
  • Make sure both roller levers are lowered to open the in-feed slot.
  • Trim the leading edge of the paper so it does not get caught in the slot.
  • Insert the media evenly to avoid angles. Do not insert one corner and then the other.
    NOTE: A beep means that the printer has detected the media in the in-feed slot. The printer will only beep once in a load cycle, if media is removed and reloaded the printer may not beep again if the load process is not re-started through the front panel.
Media does not advance If the media does not advance far enough into the in-feed channel in the media cabinet, the paper is slipping and the rollers do not grip the media. Try the following:
  • The pre-tension might be applied incorrectly. Always apply pre-tension by turning the star screw on the left side of the spindle. Never apply tension by turning the media roll or the spindle disks.
  • Clean the rollers using the cleaning procedure.
  • If the media being used is heavy coated, try changing the media.
Media jam in the in-feed channel If there is a media jam in the in-feed channel, try the following:
  • Turn the multi-roll feeder off using the power isolator switch on the connector panel at the back.
  • Open the media cabinet doors and lower the roller lever on both sides.
  • Turn the spindle to pull the media out of the in-feed channel and to collect it back on to the roll.
  • If the media is blocked, place the spindle in the park position for better access to the in-feed channel, and then pull the media edges in a downwards direction on both sides.
  • If the media cannot be reached because the roll has finished and it has not been ejected from the front of the printer, open the rear cover and try to remove the media from the motion control assembly.
    NOTE: Do not insert media with crumpled or damaged edges, trim the media first.
  • Make sure the leading edge is trimmed straight.
  • Make sure there is even tension across the width of the media.
  • Make sure media is aligned (the same amount of media is fed across the width).
  • Apply pre-tension the media.
When the printer is going to be unattended for a long period of time, it is a good idea to load and unload each roll using the LOAD/UNLOAD commands from the front panel (if the media loading procedure was not completed when prompted by the printer). This will ensure that each roll of media loaded is correctly aligned and that the printer is capable of loading/unloading each roll when requested by the print jobs in the queue.
Media misaligned When a "Misaligned?? message is displayed, the printer unloads the media. Press ENTER to continue and the printer will display the "Ready for paper?? status message. Do the following:
  • Check for even tension across the width of the media. If there is less tension on one side than the other, then the media is not straight in the in-feed slot.
  • There is a hole on the right side of the in-feed slot. Make sure the edge of the media is aligned with the left side of this hole.
  • Lower the roller levers on both sides and adjust the media so that tension is even across the whole width. Turn the spindle disk quickly two or three times away from you and then two or three times in the opposite direction. This will help to create an even tension.
  • Lift the roller levers on both sides and try to load the media again.
If this does not solve the problem, remove the media from the in-feed slot and repeat the loading procedure. Make sure the roll is against the right hand spindle disk (fully inside the roll core), and do the same for the left hand spindle disk. The printer verifies correct alignment using the blue line on the right hand side of the printing area as a reference. Media does not unload correctly If the media does not fully unload from the in-feed channel in the media cabinet, check the following:
  • Maybe there is not enough pre-tension. Always apply pre-tension by turning the star screw on the left side of the spindle three or four times (or more if the spindle is on a low retainer bracket). Never apply tension by turning the media roll or the spindle disks.
  • The spring applying pressure on the retainer bracket is loose and the spindle is slipping in the retainer bracket. Turn the multi-roll feeder off and turn the retainer bracket screw one turn in a clockwise direction.
Partial or blank prints If the print is partial or blank, check the following:
  • Check the multi-roll configuration in the printer driver: Check that the Has Multi-Roll Feeder check box is selected.
  • Check default roll configuration: Check if a roll is installed for the roll configured as default. If a roll is not selected from the printer driver, the printer will try to print to the default roll, and if no identical roll is available, it will not print the job.
  • Check Productivity mode settings: If the mode is set to normal and the roll has finished, the job cannot be printed.
  • Check cable connection: Check that the printer and any network cables are securely connected to the printer. Make sure the parallel cable is connected between the multi-roll feeder and the printer and ensure that it is also firmly connected between the computer and the multi-roll feeder.
  • Check media configuration: Make sure the media rolls are configured correctly.
  • Check document file: When printing files that are generated with versions of printer drivers for printers without multi-roll feeders, the header section of some file formats already contains information on the media. In these files, roll or sheet information corresponds to roll 1 in the multi-roll feeder. These files will print to the Default Roll. HP advises that the top roll (roll 1) is used as the default.
Dec 09, 2010 | HP DesignJet 1050c plus InkJet Printer
My cortelco able-phone keeps cutting in and out while talking its hard to carry on a conversation
try replacing handset cord, these cords are generally interchangeable from any other phone
Dec 07, 2010 | Cortelco Colleague 2211 1Line Corded Phone
Can't type: hello folks... my Dell 630m won't let me type or click unless I am holding the shift key. When I turn it on the machine makes a beeping noise (sometimes one beep, sometimes 20 ) before Ubuntu...
Sounds like a bad keyboard.
There is not so much that could be done to repair a keyboard. Disassemble the laptop, check the ribbon cable connecting the keyboard to the motherboard. If the ribbon cable is loose, tighten it. If it is tight, replace the keyboard with a new one.
Sep 20, 2010 | Dell Inspiron 630M Notebook
Connection to answering machine
There should be one cord from the wall to socket marked LINE on answer machine, then one cord going from socket marked PHONE on answer machine to your telephone.
Mar 17, 2010 | Cortelco ITT/ 2220 Enhanced Colleague...
Which phone can i hook up with printer
If you are referring to a multi-function printer/scanner/fax machine, you can use just about any phone that will work in a typical home. Most office phones DO NOT work with these multi-function devices as they use a digital signal from the PBX in the office.
A Standard phone as well as a standard phone line are required to use the fax capabilities of these units.
(more advanced users will know that you can use a standard POTS line emulator on a PBX - but it requires advanced PBX knowledge, the proper card and phone etc...)
Jan 21, 2010 | Acer Aspire L310 (ASL310UD631A) PC...
Fax machine wont fax out or in.
Check an make sure the phone cord from the wall is plugged into the back of the machine in the port marked "line" and not "phone"
Jun 12, 2008 | Brother Multi-Function Center MFC-240C...
Cortelco Colleague 2200 Corded Phone (220021TP2-27S) Logo
16 people viewed this question
Top Cortelco Lands Phones Experts
David Burbee
David Burbee
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
