Question about Vacuums
No manual with my fan, trying to put the fan up, please advise
  • 377 Answers
Kind of hard to help you with this little information you have provided, but this is what I would do. FIRST and most importantly, you MUST use an approved box hanger to hold the (I am assuming a ceiling fan) fan to the electrical box for connection. BE SURE THE POWER SOURCE TO BE USED IS TURNED OFF!!!!!! Determine the power wires for the fan unit (most likely a black, white and green wire) and, observing the proper polarity, connect to the house wiring. Make sure you are using an equipment ground to the fan. This is usually a bare or green wire. If these instructions are not clear to you, you may want to have a professional install the unit. You should also check with your local municipality about the need for a permit to do this installation.
Posted on Aug 29, 2010
Need manual for aereus electrolux carpet shampooer serial number a48181s bc2...model numbe 2101. we are tryingto put it back together after I took it apart to replace orings-now we cannot install the on...
As you may know Aerus does have a website where they do post manuals for some more current models. See here: http://www.aerusvacuums.com/support/manuals/index.cfm
However you will not fnd the manual for the 2101 posted here or readilly available on any other online reosurce site.
I have been in contact with Aerus Electrolux by email and have been advised to call 1-800-243-9078 regarding this. Please give this number a try and hopefully their Customer Service Representaive will be able to provide the manual you require.
Thank you for using FixYa!
Nov 23, 2011 | Electrolux Vacuums
After I press clean, my irobot works for about 5 minutes than stops and everything goes out, includiing lights on the robot, and i have to manually put it on the charger. Would I be right in thinking that...
possible your battery has a damage allready need for replacement. but try to fully charge your battery then after test it if it a minutes that use the problem happens againyour battery has damage.
Feb 23, 2011 | iRobot 53501 Roomba 500 Series Vacuum...
Putting a new belt on on my kirby sentria
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=780370
Generic problem for all Vacuums
Posted by cowangelgirl on Jul 14, 2008
Putting a new belt on my Kirby Sentria
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The belt install on a Kirby is to raise the height adjustment to the highest level and then dial the belt off counter clockwise so it is loose and not on the fan pulley, release the top lever on the bell housing, then remove the bottom plate and unhook the brushroll on one side, slide the old belt off and then slide the new one on, replace the brushroll with the screws facing the carpet and re-hook the bottom plate on the Kirby. Then take the bell housing and hook that back on to the Kirby and lock it down. Then dial the belt on clockwise all the way and the belt should be on the fan pulley. The belt should be ready to go, plug in your Kirby and then do the step down on the vacuum height adjustment until the tone changes, then try to see id it picks up, if not go one more height adjustment and that should be the correct setting.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/
Customer Service – U. S. & Canada
1-800-494-8586
Hours 8:00 am to 5:00 pm (EST)
Mail To: Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 14, 2008 | Kirby G6 Bagged Upright Vacuum
Oreck xl9300
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19810&thid=767429
Oreck XL9300
Posted by Cubfan70 on July 10, 2008
Bought a new motor but can’t figure how to pull off the metal fan from the old motor. Is it muscle or a trick?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. The Oreck fan is generally held on by a nut on the end of the motor and is replaceable, and it usually slides on but over the years it tends to stick on the shaft so you can take like 2 screwdrivers – one on each side and try to lift gently and the fan should come off, if not try some WD-40, and look on the inside of the new fan to see if there are threads that might screw on, if not then it should just side on, make sure if you use WD-40 to wipe off any excess liquid. Check you owner’s guide in the back pocket of the Oreck XL9300 to see any instructions that they might have, or call the Oreck factory to get a new owner’s manual for the vacuum.
http://www.oreck.com/ Customer Service 1-800-989-3535
Monday thru Friday Hours are: 7:00 am to 7:00 pm CST
Saturday and Sunday Hours Are; 8:00 am to 4:30 pm CST
Go Ahead. Use Us.
Jul 10, 2008 | Oreck XL Ultra Bagged Upright Vacuum
The fan blades under the motor are broken i like my dirt devil triangle please help fix it.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=758276
Posted by roadrunner19 on Jul 08, 2008
The fan blades under the motor are broken I like my dirt devil triangle please help fix it.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Changing the fan should not be a problem; it happens every so often if you pickup something big and the plastic fan breaks. The cost to repair is about $10.00 to $20.00 plus labor and you can repair it yourself if you are handy or take it to a local vacuum cleaner dealer in your area and they can perform the fan replacement. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Go Ahead. Use Us.
Jul 08, 2008 | Vacuums
I am trying to take my philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the...
I am trying to take
I am trying to take my Philips vision 8731 vacuum cleaner apart because a heap of c*** got sucked into the motor when the bag was not put in correctly. I have removed all visible screws but cannot for the life of me find how the wheel end comes apart. Any tips?
I believe the part you are taking about is the fan and the fans generally are installed by a reverse thread and screws off counter clock wise. Once you removed the fan or the wheel you can use a blower and blow the motor clean, remove the carbon brushes and use a pipe cleaner to clean out the carbon brush holders and then re-install. Also free to contact your local vacuum cleaner dealer in your area or in the yellow pages under vacuums.
Apr 22, 2008 | Vacuums
How do I change the fan on my model 2HD kirby
How do I change the
posted by Rogor on Apr 18, 2008
How do I change the fan on my model 2HD Kirby
1st you need to remove the head with the revolving brushing by dialing off the belt and undo the Kirby lock @ the top o the bell housing. Remove the head and that will expose the fan and the fan housing. The fan housing is held on by a couple of screws and once you removed the screws then you need to separate the fan housing from the motor section, it is held on by a Kirby fan housing sealer that is clear – so try to separate the fan housing with a knife or screwdriver, once the fan housing is off the Kirby fan is screwed on I believe either clockwise or counter clockwise and un-screw the fan and follow the reverse situation on installing the fan but you need to use the clear Kirby Fan Housing Sealer to re-seal the fan housing and let it dry and wipe of the excess clear sealer before putting it back together again. Always remember on the Kirby vacuums – use genuine Kirby parts on the repairs, it does make a difference. Then go back and place the Kirby head back on the vacuum – lock it on place and then re-dial the belt onto the Kirby fan shaft, plug your vacuum in the wall outlet and test run the vacuum.
http://kirby.com Contact Us by Phone
United States and Canada 1-800-494-8586
Between the hours of 8:00 am to 5:00 pm EST
Monday thru Friday
www.A-1Vacuum.com 1-800-657-1874
Apr 18, 2008 | Vacuums
I bought a ceiling fan from lowe's, got it home got ceiling fan up in the bathroom, when we put in the light one of the halogen bulbs does not work , also two of the cobalt blue glass covers are cracked...
If this is a new product and it is defective, take it back to Lowe's and insist on a replacement, talk to the manager if you have to. This site will only advise you on how to fix it.
Mar 05, 2008 | Vacuums
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
