Question about Ingersoll Air Tools & Compressors
Compressor ingersoll rand ssr.ep.40se.15 s/n je3897.u.97025 alarm no power control whats the problem?
5 Suggested Answers
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 205 Answers
SOURCE: I HAVE AN INGERSOLL RAND
I know you have checked voltage. However please remove the fuses for control power and check,also check fu4 and 5 16volt fuses. next check power on the controller input. Don't remember terminal # but if you look in electrical cover removed to gain access, a wiring schematic will be affixed to it. I think it's on j5 terminal 36 110volts. But please check the schematic first. If you have power at the input terminal I suspect the controller is bad but continue with the following checks. If no power at terminal 36 check the hat (High Air Temperature) switch. Its located on the end of the airend and about 1/2 inch flex connected.If the hat switch is good check the emergency stop contacts. Note the power lite picks up voltage before the emergency stop and hat switch. So even though the lite is on one of these switches may be bad.
Posted on Mar 28, 2011
  • 54 Answers
SOURCE: What does alarm start fault
I use to start up a 25 HP Ingersol screw type compressor. The only alarms I got were from power spikes which just needed the reset button to be pushed, then the on button - and the low oil sensor would shut it down and give an alarm when the tank was about half way down. They will blow up with no oil so there is a saftey margin on oil level.
Posted on Mar 29, 2011
  • 205 Answers
SOURCE: I have a ingersoll-rand ep-75
First check the emergency stop switch contacts. I usually remove them attach a fluke meter lead to each side of the contact and shake it. if reading is steady contact is good . if reading is up, down etc contact is bad. replace if bad. You need to check both sets of contacts on the emergency stop switch. You may also have a controller going bad which means you will need to replace it.
Posted on Jun 03, 2011
What level does the coolant need to be in the sight glass?
About 31,000 results (0.83 seconds) Search Results
    [PDF]IRM-G-8780 2-25hp US - Ingersoll Rand Air Compressor
    www.ingersollrandproducts.com/...
    Ingersoll Rand Industrial TechnologiesIngersoll Rand compressors are not designed, intended or approved for breathing ...does not approve specialized equipment for breathing air applications and ... unmatched service to meet your needs. ... drain, and low-oil-level .... Oil Sight Glass ... Value Package (5, 7.5, 10 & 15hp) An economical choice in a dependable ...
    [PDF]Owner's Manual - Air Compressors Direct
    www.aircompressorsdirect.com/.../irmanual2340_2475_2545_7100_15t...
    installation, operation and maintenance of your Ingersoll-Rand air ... An air-cooled aftercooler, low oil level ... for Models 2340, 2475, 2545, 7100, 15T & 3000 ... Ifcooling of the discharge air is required, .... motor does not have this button and the unit does not have a ..... l Drain compressor oil and clean oil sight glass.
    [PDF]XF 7.5 - 15 EP 7.5 - 15 HP 7.5 - 15 XP 7.5 - 15
    diagramasde.com/.../Manual%20comp%20ingersollrand%20SSR-15.pdf
    EP 7.5 - 15. HP 7.5 - 15. XP 7.5 - 15 ... The Ingersoll-Rand Company Rotary Screw Air Compressor that has been filled prior to its ... after shall have its AIREND warranted for twenty four (24) months from the ... comes first, when using ULTRA COOLANT.Coolant ...... check coolant level in the sight glass on the separator tank.
    Ingersoll Rand Air Compressors - About Air Compressors
    www.about-air-compressors.com/Ingersoll-Rand-air-compressors.html
Feb 08, 2016 | Ingersoll Rand 15 Horsepower Rotary Screw...
What does alarm start fault mean on the control panel on a ingersoll rand ssr ep-30 air compressor
Mar 28, 2011 | Ingersoll Rand Stationary Air Cooled...
I HAVE AN INGERSOLL RAND SSR HP/40SE AIR COMPRESSOR W/INTELLISYS CONTROLLER 15-50 HP.IT HAS POWER,BUT DOES NOT HAVE ANY LED ON SCREEN.CHECKED CONTROL VOLTAGE-OK POWER LT ON,WHEN PUSH BUTTONS NOTHING...
Mar 27, 2011 | Ingersoll Rand Stationary Air Cooled...
We have IR SSR 150HP compressor, where when starting alarm display "check motor rotation" we already change the phase L1, L2, L3 but this alarm still appear. what should we do?
to change rotaion on a three phase motor just which 2 leads.
Change L1 to the wire now on L2 and take the wire on L2 and move it to L1. the rotation will now change. or L2 and L3... just two wires
Nov 24, 2010 | Ingersoll Rand Stationary Air Cooled...
I have an Ingersol Rand SSR-EP40SE Rotary screw Air compresor. We ordered a new control panel for the unit because the old panel had a burnt resisitor. The new panel was installed and wont start the unit...
First you need to program the controller. Controllers do not come programed for a specific compressor. You will need to enter factory set point and and set all parameters. Horse power, pressure, DOL start or wye delta start etc. The new controller is probably set incorrectly. Look at factory set points on the old controller and copy all the parameters and then set the new controller to those set points.
Sep 06, 2010 | Ingersoll Rand Stationary Air Cooled...
Air Tools & Compressors Logo
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Joe Garcia
Joe Garcia
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
