Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
I HAVE A COLEMAN STANBY GENERATOR MOD#PM0631212 AND A GENERAC TRANSFER SWITCH MOD#RTSE200A3. I CAN'T FIND AN ELECTRICIAN TO FINISH THE UNCOMPLETED JOB OF HOOKING THE 2 UP. THE GENERATOR BREAKER BOX IS IN PLACE AND WIRED, THE GENERATOR IS SET AND HOOKED UP TO PROPANE. I HAVE MANUALS/SCHEMATICS FOR BOTH BUT EVERYONE SCRATCHES THEIR HEAD BECAUSE THEY ARE NOT THE SAME BRANDS. CAN YOU HELP?
  • 1,420 Answers
There will be some re-wiring necessary but no more than a Generator Technician can handle. Check your local phone book for generator dealers. You will pay extra because of the mixed system and because you thought you could save money by doing it yourself and not purchasing the system from a dealer. You get what you pay for!
Posted on May 30, 2008
Generac generator won't turn off in automatic
It is possibly a transfer switch issue, not the generator control board. Have an electrican kill utility power, let it start and run, then disconnect the sensing wires in the ATS. If it stops problem is ATS
Mar 01, 2015 | Generac Electrical Supplies
Coils on transfer switch got fried when utility came back what could have caused this
possible failure of a relay. contact generac,sometimes they will accomodate you with new parts
Oct 08, 2012 | Generac Guardian 200 Amp Transfer Switch...
My rpm sens light is flashing on my anunciator panel generator will not crank
you may have to reset it, its probably shut its self down, on safeties. and wont restart till you clear it..
Aug 13, 2011 | Generac Guardian RTSE200A3 200 Amp...
Just finished installing a 20 KW Generac generator (fueled with natural gas). The included transfer switch will not automatically transfer to the generator, but transfers back to the utility without...
Check the connections on the tranfer relay and two coils. The two coils have blue wires. I have seen them come off from assembly or shipping its common. Each coil has two blue wires #8 and E1 with crimp steak ons and limit switches make sure there all pushed on all the way. Hope this helps
Mar 09, 2011 | Generac Guardian RTSE200A3 200 Amp...
I am installing a 20kw Generac generat or, how does the generator communicate with the transfer switch? there is no wire diagram for this all that is hooked in is the utility, the generator and the...
You need to pull in two yellow wires called N1 N2 for sensing 220v. One red and one white called 23 and 194 those are your 12vdc transfer wires. And then last of all your 12vdc from battery charger. Hope this helps
Feb 16, 2011 | Generac Guardian RTSE200A3 200 Amp...
I Am installing a Generac 20Kw air cooled unit with a 200 amp service disconect ATS What size conductors do i use from the generators 100 amp breaker to the transfer switch
It is always good to install a large enough wire where the maximum load can be drawn plus a little extra for safety. 7 gauge wire will do, if it was mine I would use 6 gauge wire. If the length is over 20 feet but not longer than 80 feet go to the next larger size wire.
Dec 18, 2010 | Generac Guardian RTSE200A3 200 Amp...
I have a new Generac 20KW Propane generator with a rtse 200A3 automatic switch. I had an electrician install the switch and make the connections from to the generator. The generator is blowing the 7.5 amp...
Sounds like the electritian wired something wrong. Control wiring for that generator should be:
N1 and N2 = 240 vac utility input
Wire 0 = ground
Wire 194 (15B) = + battery
wire 23 = transfer signal
Sep 02, 2009 | Generac Guardian 200 Amp Transfer Switch...
Generator Transfer Problem
There isn't much you can do with servicing the generator set or transfer switch unless you've got lots of experience in diagnoising semi-conductors and electronic components.
Depending on the age of the system, it would be benificial to have a qualified service tech take a look at it.
As an electrician, I've installed several back up generator sets in homes for customers and have had a few of these automatic transfer switches with intermittent operation issues. Sometimes it's the switch and other times it's the Generator that is causing the problems.
Hope this helps, and best regards!
Aug 07, 2009 | Generac 100 Amp 120/240-Volt Transfer...
I need to purchase an aluminum allen head load
From Generac only. And they wont sell it to you if your not an authorized dealer with a Business license. You ll have to get it from a generac dealer like an electrician business. I know because we sell work on and istall them everyday where i work.
Jul 09, 2009 | Generac Guardian RTSE200A3 200 Amp...
Heating & Cooling Logo
59 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
