Question about Acer Aspire One PC Notebook
I have an Axer Aspire one which is constantly giving me problems started with the charger which i had to change it now the laptop's desplay is totally blank how can i get it fixed as i failed to find a single authorised service centre here in pune city india
Have you tried the acer service homepage? For India, it's ACER (http://www.acer.co.in/acer/service.do;jsessionid=4540004EFD9F59DD938BC2D05DDE3CBF.public_a_14c?LanguageISOCtxParam=hi&ctx2.c2att1=158&CountryISOCtxParam=IN&ctx1.att21k=1&CRC=314854675). They give you some toll free phone numbers:
1-800-11-6677 (Toll free from BSNL/MTNL landlines).
i have an Axer Aspire one
which is constantly - icon_telephone.png 1-800-3000-2237 for India(1-800-3000-ACER, Toll free from Reliance Mobile/Landline. Local call charges applicable for other telecom networks).
Posted on Aug 28, 2010
I have an Acer Aspire 7741Z-5731. I've had it for
If you changed your laptop battery and charger now nothing left to change. It could be problem related to you laptop motherboard.
On your laptop battery charging section not working properly. you can check you your laptop motherboard.
Jun 16, 2012 | Computers & Internet
It does not recieve power from charger and not starting
Hi:
I had to change chargers twice due to the same problem seems to be that acer make very fragile chargers or we just don't take care of them. You need a new charger follow the link below they are very inexpensive.
http://www.amazon.com/Laptop-Adapter-Aspire-AOA110-AOA150/dp/B0028LK6IU/ref=pd_bxgy_e_text_b
Regards,
Sep 15, 2011 | Acer Computers & Internet
Computer been pluged in for hour and willnt charge over half way what do i do?
The battery or the charger may be malfunctioning. Please verify that the computer recognizes that the power cord is plugged into the computer. There should be a plug icon over the battery in your lower right hand corner. If it doesn't show the plug icon, and the battery is draining your charger is likely bad. Otherwise your battery is more than likely going. If your model is several years old, I'm afraid to say that after constant (or even semi-constant) use the battery will die after 2-3 years and need to either be replaced or used less frequently.
Mar 02, 2011 | Acer Aspire 5050-3242 Notebook
My acer aspire 9810 won't boot, only the lights on the board are visible but nothing is desplayed, the VGA card, RAMs and Processros were tested and are working well. Thank you for your help
If its giving out a video signal to an external monitor then most likely the display panel needs to be replaced.If is doesn't show video to the external display then your video card may be bad
Jan 21, 2011 | Acer Aspire 9810 Notebook
My laptop runs very slow on Mains power, but runs fine and fast on battery???? (Acer Aspire 5535) This only started approx 2 months ago. Tried all the usual clean ups, registry ect, but didd not help. Is...
Have you checked the power plan settings? This is usually accessed by a battery/plug icon on bottom right of the screeen, if not then on the control panel.
right click on the icon and select power options. This gives you options for balanced, high performance or power saver. Clicling on change settings allows you to set CPU performance for mains and battery for each power setting.
for instance I usually use the balanced setting with a fast CPU when using mains and slower (to conserve battery power ) on battery.
Feb 26, 2010 | Acer Aspire 5535-5050 Notebook
Can i use the lcd of aspire 4315 to my aspire 5050
dear lcd desplay are same in every model just you need the same size of both. means if you have 15' then you fit only 15'.and if you buy your model lcd there is no any problem because right now problem with cericuit of lcd
Jan 19, 2010 | Acer Aspire 5050-3242 Notebook
Charger light flashes when plugged into laptop , stays on solid when unplugged,had charger checked 19v ok ,had socket checked 19v ok ,then checked to first board 19v ok ?? has a board gone down ??? annoyin...
your battery pack is causing your problem rule #1 never!! leave the charger in!! everytime you start up!! run off the batteries till the power low light come's on then apply the charger constant charging causes early failure of all/ any nican battery pack
Jan 13, 2010 | Acer Aspire 5920-6335 Laptop
My Acer Aspire 5315 when I try to boot does nothing except for the power light staying on. I tried poping in another hard drive and that did nothing. I also tried swapping out the memory sticks as I have...
Hello!
If you have problem with bios, try when you turn on laptop some function key (F1, F2, F10,F12), first one, than turn off, and turn on, and another key.
I don´t remember what is key, but if it problem with bios, you can get a messages something like update bios.
If that not a case, check you fan at procesor, memory, CPU , motherboard or it is the problem with VGA card.
Still one thing can make something like that, battery at laptop.
Try take out battery and try turn on laptop
Nov 03, 2009 | Acer Aspire 5315 Notebook
How to use webcam in axer then wrere is the option to open it
whats the webcams name , and try looking at the acer website
Oct 23, 2009 | Acer Aspire 5610-4648 Notebook
Acer Aspire One  PC Notebook Logo
103 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
