Question about Sony MDR-V700DJ Professional Headphones
How to know whether the MDR V700 headphone is fake or genuine?
4 Suggested Answers
  • 4 Answers
SOURCE: How to Rewire Sony MDR-7506 headphones
Okay, cut and strip the cord. There should be two copper wires and (on Sony headphones, at least) a red and a green strand. On a new 1/8" jack, there should be three connections. The middle one is left, and is where the green one goes. The short one on the side is right, and is where the red one goes. The long bit is the common, and is where the copper one goes. Before you solder, however, remember which strand is which, because you have to sand or burn off the colored enamel. (Use a fine grain paper, or use a standard lighter or stick match- anything else might damage or melt the wire)
Posted on Apr 03, 2009
M2Tech1
  • 313 Answers
SOURCE: My headphone jack is bent and so the headphones barely work.
THE BEST WAY TO DO THIS IS TO GET THE REPLACEMENT JACK FROM AN AUDIO OR MUSICAL SUPPLIES SHOP.. ONCE YOU HAVE THIS CUT BACK THE CABLE OUTER SLEEVE TO SHOW THE CONNECTORS AND CABLES ON THE JACK..GET A SOLDERING IRON READY WITH SOLDER.. STRIP BACK A SMALL AMOUNT OT THE CABLE SLEEVE TO SHOW THE WIRES THEN STRIP BACK EACH OF THE CABLES AND TWIST THE ENDS SLIGHTLY..GET THE SOLDERING IRON HOT AND TOUCH THE WIRE TO THE END WHILST BRINGING TEH SOLDER TO THE WIRE TIP. IF TEH IRON AND WIRE ARE HOT ENOUGH A SMALL AMOUNT OF SOLDER WILL MELT ON TO THE WIRE TIP.. DONT HOLD THE WIRE TO LONG OR THE HEAT WILL MELT THE PLASTIC COATING., DI THE SAME FOR THE OTHER WIRE.THEN UNSREW TH NEW JACK YOU SHOULD SEE EITHER TWO OR THREE CONNECTORS MATCH UP THE NEW WITH THE OLD ON THE CONNECTOR AND SILDER ON ONE BY ONE THE SAME WAY JUST HOLD THE WIRE AND IRON TO THE PLATE AND HEAT WILL CAUSE THE SOLDER TO ATTATCH TO NEW CONNECTIONS..MAKE SURE YOU HAVE PUT THE SLEEVE ON THE WIRE BEFORE YOU SOLDER OR YOU MAY HAVE TO TAKE IT OFF AGAIN TO PUT THE JACK BAK TOGETHER..TAKE YOUR TIME WIT THIS AS IF YOU TRY TO HURRY THE SOLDEDRING PART IT CAN BE MESSY AND NOT TAKE PROPERLY AND CAUSE BREAKAGE AWAY LATER IF THE JACK IS PULLED.. ONCE THE WIRES ARE SOLDERED ON TURN OVER THE GRIPS AND IT SHOULD WORK FINE.. I USUALLY GO FOR THE METAL TYPE JACKS AS THEY ARE STRONGER AND EASIER TO SOLDER.. GOOD LUCK A...
Posted on Aug 06, 2009
Grubhead
  • 5193 Answers
SOURCE: where to buy sony headphone
At the bottom of this tip you will find a place that should be able to help;
http://www.fixya.com/support/r4548519-replacing_dodgy_plug_cable_headphones
Posted on Dec 18, 2011
I am looking for replacement earpads for Sony MDR V600 headphones. Will replacement pads for MDR 7506 fit the V600?
Yes, the replacement pad for mdr 7506 fits in for the v600. They can be replaced for one another. There are different types of v600 and 7506, You just have to look for the 7506 that looks more like the v600. That should do the job for you. Hope this information helped You.
Jan 13, 2011 | Sony MDR-V6 Professional Headphones
Are the MDR-RF925R useable with TV's
You can use MDR-RF925R with any thing that has Line Out RCA jacks and your tv should have TV Audio Out RCA jacks to connect this wireless headphone.
Thanks.
Jan 04, 2011 | Sony MDR-RF970RK Headphones
Aug 06, 2009 | Sony MDR-V700DJ Professional Headphones
Sony MDR-V500 headphones: Cushions falling apart!
You can go to Radio Shack and find some that fit. Although Sony does not sell them as they woudl ofcourse want you to purchase new ones you can buy third party cushions that fit.
Nov 26, 2008 | Sony MDR-V500 Professional Headphones
Got no sound from the right earphone of my MDR-v500 headphones
It's actually quite easy to open up ... the pad just slips off, and its really easy to get back on and there is a set of three small t screws underneath that just need unscrewing and then you're inside
Jan 27, 2008 | Sony MDR-V500 Professional Headphones
Sony MDR-V700DJ Professional Headphones Logo
154 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
