Question about Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
Will not pickup water - Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum
  • 15,935 Answers
Tilt the handle all the way down to the floor - and look at the big pickup hose.
Typically this is a weak spot in the hose, and it plits - just from normal use.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Aug 27, 2010
Why wont our bissell proheat 2x pickup the dirty water in the dirty water tank.
possibly a bad seal at the tank use some vaseline on the seal once
Sep 30, 2017 | Bissell Vacuums
HOOVER MAX EXTRACT DUAL V LEAKING SOAP INTO THE FRESH WATER TANK
that is purely normal to have cleaning material in the fresh water tank as the vac picks up the dirt from the floor it should really go into the dirty pickup tank purely normal nothing to worry about
Apr 22, 2017 | Hoover Vacuums
Wont pickup water
check dirty water tank make sure lid is on correctly and that the plunger is not stuck.
Jan 20, 2013 | Hoover MaxExtract Deep Cleaner
Won't pickup water on rug
I may have already given my best advice but, check the hose line to the extraction tank and make sure there are no cracks in it. This will allow it to **** in air, and therefore reduce the vacuum pressure at the head of the machine, causing it to malfunction.
Oct 06, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
Cant squirt water, nothing is coming up from the carpet
Try filling soap solution tank with hot water and make sure that the red filter in the pickup tank is not clogged, and always run hot water in solution tank after cleaning carpet. steve
Jun 06, 2010 | Bissell 1697-7 Powersteamer Pro Deluxe...
NEED WATER PICKUP HOSE ASSEMBLY FOR FH40000
All availble Hoover parts for the FH40000 can be found on usavacuum.com
Follow the link below to the site
http://www.usavacuum.com/category-s/86.htm
Mar 02, 2010 | Hoover Floormate H3000 Upright Wet/Dry...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
DOES NOT VACUUM NOW
Several possible problems:
1) Did you clean the blue lower pickup container (dirty water) before putting it away?
Take out the pickup container and open it up, check the filter (under the little blue piece on top) and also open up the container itself and clean under the flapper on the "screen".
2) Look inside the housing and check the vac hose that goes from the front of the unit up to the rubber grommet where it goes into the lower pickup container. Is it clogged? If yes, take off the front pickup (the part the runs along the floor in front of the rotating brushes) and run a very narrow lint pickup brush (like for cleaning dryer vents) and clean out the hose. It works great.
3) Check the front pickup for clogs and clean
4) If you are trying to pick up water, make sure the setting is set to wet. If you are trying to use it as a vacuum, set it to dry.
Hope this helps.
Nov 09, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Pickup water
The clear shroud covering the front of "hood" has two sheet metal type screws at the bottom in front of the brushes, these two screws also hold the little straight brushes ( one on each side) in place. I found one of these screws had broken it's plastic "socket" and was no longer applying any pressure to the hood, this caused loss of suction and would not pick up any water...You can test this by applying a little pressure to the "clear hood" after you have applied water and shampoo. You should immediately see water entering the pickup reservoir container. I removed the broken plastic "socket" and replaced original screw with a longer wood/sheet metal screw. I think this is a weak point on the cleaner and is easily broken by catching the front lip on any hard object. Hope this helps
Aug 24, 2008 | Hoover F6020-900 SteamVac Upright Vacuum
Does not pick up water.
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618960&thid=628888
Posted by lazybug002 on May 28, 2008
What can I do and what part do I need to replace? I have taken it apart and clean it but still won't pickup the water.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Bissell 9500 ProHeat 2X Clean Shot Upright. It sounds to me that you may have a clog or an obstruction or the channel to the suction motor per say might be broken and is not creating the suction needed to pickup the water to the recovery tank. So check with your local factory authorized vac dealer that carries and services Bissell. I will give you the Bissell factory phone # listed below for further questions. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.bissell.com/ Customer Service 1-800-237-7691
Hours of Operation Monday thru Friday 8:00 am to 10:00 pm EST
Saturday 9:00 am to 8:00 pm EST
Mail To: Headquarters, Bissell Homecare Inc
P.O. Box 3606 Grand Rapids. MI 49501
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 28, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell Carpet Cleaner Powerbrush Deep Cleaner Vacuum Logo
20 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
