Question about Whirlpool 24 in. DU1100XTP Built-in Dishwasher
Du1100xtpba The top rack of dishes doesn't get cleaned at all. And when we switched from a powder to liquid detergent (to see if it affected anything) the liquid detergent now stays gooped in it's compartment, and doesn't dissolve.
  • Whirlpool Master
  • 43,501 Answers
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Posted on Aug 29, 2010
Sears dishwasher dirty dishes after cycle and a film and crystals on glassware
Take out bottom rack, and check for garbage in filter area. Also use jet dri
Mar 01, 2015 | Dishwashers
I do most of my shopping online and liquid bleach sometimes doesn't ship without breaking. Is it OK to use dry or powder bleach? I have the whirlpool cabrio top load large capacity model.
It should be okay to use dry bleach, if you follow the instructions on the bleach. Some bleaches require dissolving in water first, others can be used dry.
May 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
There is always detergent left in the compartment and my dishes don't seem clean. It doesn't seem to matter if I use powder or gel detergent and I don't overfill it.
I expect your filter is clogged which does not allow sufficient water to get from the pump to your spray arms. Thus they do not clean out the detergent nor do they clean the dishes. You might test this by placing a glass right side up in the top rack and run a normal wash cycle. The glass should fill at least half way with water.
Mar 15, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Dishes bottom rack are marginally clean. upper rack is never clean anymore. The dish washer cycles through NORMAL and Dries dishes OK. Motor is running, and rinsing can be heard as well as washing cycles....
Just fixed my Frigidaire. The outboard o-ring on the main pump became distorted and stretched. Check your local hardware store as Frigidaire wants $17.50 + shipping. Good luck
Dec 25, 2009 | Dishwashers
Our 2 year old dishwasher won't clean as well as it did when new
If the filter has already been cleaned, try adding a cup of bleach to your next cycle.
Jul 30, 2009 | Dishwashers
The top rack is not longer getting clean
Using liquid detergent is the worst detergent to use. One possible solution to your problem could be as follows...pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. May need to do this several times (3 to 4). This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel, no liquid and no tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishes not getting clean
the problem is hard water leaving the residue. go to www.dishwasherfilter.com and get the dishwasher filtration system. it will reduce the hard minerals that leave the residue and your dishes will be clean as can be. it is very affordable and fits right under your sink.
Mar 10, 2009 | Maytag MDB6000 Dishwasher
Doesn't clean dishes completely, especially the top rack. also it doesn't completely empty out the detergent dispenser.
To the people here with the poor cleaning problems:
Try these steps:
Buy a small box of Cascade or Electrosol diswashing powder. Use only it for 30 days and report back. Do not use gel, tablets or ultra low end detergent. I have proven that ultra cheap powder WILL cause problems.
Also, fill a bowl or large cup with white vinigar, place it in the bottom shelf of of the empty dishwasher. Do not add any detergant. Run a normal or quick cycle.
If you still have poor cleaning, it is time to call for service or remove the filter beneath the lower rack and search for debris that will need to be removed.
Please report back with your results and the make/model of the dishwasher. Good Luck!
Dec 22, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
It not cleaning good
First detergents, make sure that its not expired. 2) some dishwashers do better with liquid or powder, so try each one, brands can vary also.
If hard water use more detergent soft less.
If only not cleaning on top rack you have a water pressure issue.
Also ensure you are properly putting the dishes on the rack, incorrect dishes restrict flow, pressure, and cleaning action.
May 01, 2008 | Dishwashers
Dishes don't come clean. Water spots on stainless and film on glass. Tried powder & liquid detergent and max. amt. of water softener. Increased water temp. as recommended in manual. Any suggestions?
cut back on the amount of soap and make sure you are not overloading bottom rack remember water has to get up through lower rack to do its job correctly
Dec 12, 2007 | Whirlpool 24 in. DU1055XTPS Stainless...
Whirlpool 24 in. DU1100XTP Built-in Dishwasher Logo
88 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
