Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lid switch not working - Whirlpool Ultimate Care II LSQ9549L Top Load Washer
  • Whirlpool Master
  • 2,605 Answers
Hello, welcome to FixYa.
Based on your description it sounds like you`ll need to replace it, but first...
Here`s how you can check it pretty easily...
( this is based on the most common Whirlpool, Estate, Kitchen-Aid, Roper, Kenmore, Inglis topload washer, not neccessarily applicable to ALL...especially those built in the past 1-2yrs. the model number would distinguish if it applies to your particular model )
Lift the lid, if you observe the underside of the lid there will be a plastic "strike" or "actuator" that goes into a hole when the lid is closed.
Check the hole where the actuator goes into the cabinet and insure you can see a gray oval shaped piece. If so take a small screw-driver, pen/pencil or something small enough to fit thru the small hole and try activating the switch by pushing it down ( machine must be in the agitate or spin cycle ). If you don't see it, the switch has likely broken loose and needs to be replaced.
If it start's to function than the switch is not being contacted properly by the actuator on the lid and likely is due to the switch being worn...unless the actuator on the lid is broke, if so there`s the problem.
Make sure the switch is being held in place via the two screws along the side, if they are loose tighten them, if it is broken, it will need to be replaced.
Here`s a helpful link for changing it out,
http://videos.wittysparks.com/id/3098139337
The lid switch will look like this...
Let me know what you find and if I can assist you further.
good luck.
macmarkus :)
Posted on Aug 27, 2010
  • Mark MacDonald
    Mark MacDonald Aug 27, 2010
    Actualy your model number indicates this DOES apply to yours, I checked...based on the model at the head of your post.
    Good luck.
Tip
How to service a lid switch
The lid switch on a washer often serves as a safety switch. If the switch is not working, or if the switch opening in the lid is clogged with detergent, the machine will not run. To check and repair the lid switch:
- Unplug the machine. Clean out the lid switch port with a wood manicure stick or chopstick. Clean off any detergent buildup around the rim of the lid. Sometimes there's enough detergent encrusted on the metal to prevent the lid from closing tightly and keep the washer from operating.
- If cleaning doesn't help, remove the top of the cabinet to get at the switch. With the switch exposed, check the screws for looseness. Loose screws can cause the switch to move when the lid is closed or as the machine goes through its cycles. Check the terminals of the switch to make sure they're tight. Tighten the mounting screws after the switch is in alignment. -Test the switch with a VOM set to the RX1 scale. Disconnect the power leads to the switch terminals and clip one probe of the VOM to each terminal. Close the lid of the washer. If the meter reads zero, the switch is working. If not, the switch is faulty and should be replaced. - If necessary, replace the lid switch with a new one of the same type. Connect the new switch in exactly the same way the old one was connected.
- If the switch still doesn't work, it is probably misaligned. Realign the switch by repositioning the screws holding it in place, testing the switch as you go until it works properly.
on Jan 16, 2010 | Washing Machines
My Kenmore elite 100.24942301 Lid switch problem
You may can slightly bent the part the lid contacts so it will be depressed further thereby making the switch. If that doesn't work then you will need to replace the switch.
Dec 29, 2009 | Washing Machines
Will not spin clothing out
do you hear it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . sometimes , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Aug 19, 2009 | Washing Machines
Washer filled up and wont drain or do anything!!!
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it using the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down . Have to replace the lid switch for it to work properly or bypass the lid switch from under the console .
Aug 18, 2009 | Washing Machines
Washing machine not spinning
Aug 18, 2009 | Hotpoint VBSR3100GWW Top Load Washer
Frigidare washer will not go into spin mode
Aug 16, 2009 | Washing Machines
Won't spin
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore washer
Check the lid switch first, make sure when you close the lid the switch is activated with the tab on the lid, if the switch doesnt work, your machine will only fill and wait for the lid switch to be satisified. You should hear the lid switch lick or snap when you open and close the lid.
Start here, if could be the motor or timer, however check lid switch first.
Jul 12, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
