Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
917270820 model engine cranks but wont start - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Hi you might want to try to see if you have spark from your coil if so change your spark and make sure it is gaped at 27 to 30
Posted on Aug 29, 2010
Starter wont crank ,engine wont start even when i cross starter and starter turns engine over, shifter wont come out of park what do i need to check
I can't help much w/o year--make--model? Do you have a security system on this vehicle?
Most starters have two voltage circuits, one comes from the battery, hot all the time. The other circuit goes hot with key in the start position, may be wired through neutral switch, depending on the tranny, maybe you have a starter relay? The starter motor usually grounds through the engine block. The fact you can jump the starter motor and it cranks, sounds like the ground is ok. Use a test light, check for voltage on those two voltage terminals. Make sure tranny is out of gear and parking brake is set.
Some makes and models have shift-interlock, you can't shift it unless you step on the brake. Do the brake lites work? If not fix that first.
Some makes and models have a shift-interlock bypass button so you can press the button, then shift into neutral. Parking brake set.
Mar 12, 2017 | Cars & Trucks
Why doesn't it crank?
some MAF sensor are sensitive, some throttle bodies are never to be operated manually what is the year make and model of yours, is or was there any trouble codes . when you say car wont crank, do you mean {it wont start} or do you mean {engine does not turn} when trying key.
re post with all the info
Jan 26, 2016 | Cars & Trucks
It turns over but it wont start
Engine cranks but won't start. Troubleshooting tips
www.samarins.com/diagnose/index2.html
In this guide, we are going to look into no-start problems when the car engine cranks,but won't start. If your engine won't crank at all, check the first part No-start: ...‎Why a car won't start - ‎Crankshaft position sensor - ‎Check Engine light
Engine cranks but won't start - YouTube
? 8:03
https://www.youtube.com/watch?v=1L4nB2NdA0U
May 16, 2014 - Uploaded by jimthecarguy
2003 Ford Taurus 3.0 liter 24 valve no start cranks OK.You will not ... Car will not start trouble shooting guide, wont crank, wont turn over, etc.
Problem 5: Engine Cranks But won't Start
Jan 01, 2016 | Cars & Trucks
Just brought and new alternator and battery is charged car still wont start
The engine doesn't spin when key is turned to start position ? That's a no-crank no start condition . Now if the starter turns the engine over when key was turned to the start position an did not start an run ,that is a engine cranks -no start condition . If you would say what make model an year vehicle also ,we could help you .
Dec 09, 2015 | Cars & Trucks
Yesterday i was driving and car died wont start
What is year--make--model? If it cranks good but won't start, have a helper crank it while you visually check for spark at the spark plugs, gasoline engine. If spark everywhere, use a gage and check proper fuel pressure. Check for fuel injector pulse, engine cranking. Check for applicable trouble codes, see if anything shows up.
If the starter motor won't crank, that's a different diagnostic procedure. I need more info.
Nov 04, 2015 | Cars & Trucks
My car does't start
engine cranks over but wont start??? or engine wont crank over, you will have to provide a wealth of information to get a clue to this one.. start with make.model. year, engine,
Feb 16, 2013 | Protege 5 pipe, by - pass. 1500 - cooling...
Volvo 2005 EC210 BLC Engine Crank but no start .display shows code 140SID and 250 9
It can be faulty fuel pump or clogged fuel filter or its issue with starter or battery or may be problem with sensors.There are few possibilities that can cause these problem,there are few help links provided related to these issue. Click the link below and refer the troubleshooting procedure to solve the problem:-----
Engine cranks but will not start? http://technoanswers.blogspot.in/2012/02/engine-cranks-but-will-not-start.html
-------- Landcruiser prado won't start http://technoanswers.blogspot.com/2012/10/landcruiser-prado-wont-start.html ------- 2007 ford expedition engine cranks but wont start http://technoanswers.blogspot.com/2012/10/2007-ford-expedition-engine-cranks-but.html
: Engine Cranking Fast but not Firing up? http://whatisbyme.blogspot.in/2012/05/1999-lexus-gs300-engine-cranking-fast.html
1997 Oldsmobile Cutlass Ciera: The Engine cranks but not start? http://schematicsdiagram.blogspot.in/2012/04/1997-oldsmobile-cutlass-ciera-engine.html
Mazda MPV cranks but will not start? http://technoanswers.blogspot.com/2012/01/mazda-mpv-cranks-but-will-not-start.html
-------- MAZDA MPV WILL CRANK BUT NOT TURN OVER TO START? http://technoanswers.blogspot.com/2012/01/mazda-mpv-will-crank-but-not-turn-over.html
--------- Vehicle Cranks Fast but Won't Start http://whoisbyme.blogspot.in/2012/07/vehicle-cranks-fast-but-wont-start.html
How to test Crankshaft Position Sensor? http://fordrepairhelp.blogspot.in/2012/03/how-to-test-ford-focus-crankshaft.html
These details will help,keep updated for more help.
Oct 16, 2012 | Cars & Trucks
2000 ford zx2 shreded serpentine belt in half while driving after replacing car wont start
More detail would be helpful. By not start, that could mean the engine rotates but won't start or you turn the key and nothing happens.
Since you do have a 2000 model I can tell you that they had issues in that model year with crank walk. The thrust bearing in some engines was too small and would allow the crank the move side-to-side (transversely) in the block. Some symptoms included knocking, engine dying on turns, timing or serpentine belt failure....
Oct 12, 2010 | 2002 Ford ZX2
Engine crank but wont start
have u checked to see if theres any gas in the fuel tank
Feb 10, 2009 | 1994 Toyota Pickup
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
116 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
