WHERE IS THE PUMP AND HOW DO I CLEAN IT - Washing Machines
  • 176 Answers
Wat is your machin?
the pump on the motor
Posted on Aug 27, 2010
Where do I clean the pump filter? Light keeps lighting to clean pump. Whirlpool front loader. A+A 5kg / 1200 AWO/D 4505
You have a code telling you to clean the pump now thats a first are you sure it says clean the pump filter? more info as to why you are needing to clean the pump filter its not really easy trust me, unless you have done it before which i am guessing you havent.
Mar 07, 2016 | Whirlpool Washing Machines
What's wrong the water will not spin out of my machine
It sounds to me that the pump or pipe is blocked, first check the pipe for any blockage if that is clean remove pump, open it (useually 3 screws) and clean that, if it is clean then your impeller is worn and needs to be replaced. Make sure the pump is running by actually, when pump are open start the machine and check if pump is running, if not check if all electrical wires are connected, also make sure that the opening that feeds the pump in the drum is clean as well
Dec 12, 2010 | Whirlpool Washing Machines
Clean pump
If this is a Whirlpool Duet model washer, the following link explains step-by-step, how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If this is not the model washer you have, or if you require additional assistance, please post back and let me know. I hope this is helpful to you.
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does problem f2 mean
the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) BE READY TO CATCH LOTS OF WATER. CAREFULLY AND S_L_O_W_L_Y unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Take care.
Jun 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
F 02 was flashing and the water is still in the machine how do i get the water out
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Jun 20, 2010 | Kenmore Elite 45986 Front Load Washer
F2 message appearing on washer, what does that mean
Something clogging the pump or drain line. Clean out the drain pump catchment.
- Pull the suction boot off the drain pump, clean out any gookus.
- Blow through the drain hose starting from the connection at the pump.
- If all else checks out, replace the pump.
This is how to clean the drain pump catchment: Remove the bottom front panel to see a white plastic catch basin with a removable-by-hand, large facing forward lid (peanut butter container sized) Remove it and clean out.
Feb 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have an kenmore elite with error code f02???
The drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap).
Unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Feb 20, 2010 | Washing Machines
I have philips whirlpool awo/d 4605 model and its showing a light clean pump where do i find the pump???
The unit front portion either right side or left side you will find the small door you just open the door and remove the filter in anticlockwise direction it will come out just clean the filter and then close it safely
If you want to clean the pump you are suppose to open the back door of the unit and trace the outlet valve it will be connected to the pump after finding the pump just remove the hose from bothe side of the pump and clean the drain pump neatly and refix it
Jan 05, 2010 | Whirlpool Washing Machines
What does F2 code mean with the Kenmore Elite HE3?
Oct 31, 2009 | Kenmore Elite 45986 Front Load Washer
Clean pump indication light on .how do i clean pump
dear sir/mam
clean pump means we should clean the filter provided in the pump line,in some models filter will be located inner bottom of the washing machine and outer bottom of the washing machine so please check it and clean the filter.
Sep 11, 2009 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
