8" under the counter lcd tv/dvd not getting signal from dish.ran same cable to other tv work fine.tv says no signal.....mvuc821 8" tft dvd player with radio
  • 8 more comments
  • W4rp4th May 17, 2008
    same problem, senses signal strength, but no programs found. other TVs have no problem with the same feed.
  • Anonymous May 18, 2008
    Same problem, no channels, Radio and DVD work but no tv signal from cable input
  • tugash May 25, 2008
    I've been wondering what the deal is as I've the same situation. Connection works fine with other TVs but doesn't work with the MVUC821. I ended up connecting through a VCR to see if that would work, but it only works if I use the RCA cables and set the unit to AUX. What gives? The memorex site doesn't even seem to have the support materials for this unit.
  • edla May 26, 2008
    Same problem here.
  • Anonymous Jun 07, 2008
    Same problem, and no solution. What gives?
  • Sylill Jun 17, 2008
    Just installed MVUC821 Memorex under counter LCD unit and cannot get a TV picture from cable input. I'm thinking TV receiver only picks up digital (ATSC) and my cable signal is analog. I'm wondering if I need a digital cable box from Comcast for unit to work??? Going to try calling Memorex tomorrow.
  • Anonymous Sep 21, 2008
    Same problem. Crazy.
  • kizdrawt Oct 04, 2008
    The "no signal" showed up on mine as well. No one has a solution?
  • ravage326 Dec 23, 2008
    moi aussi, je viends de faire l'acquisition sur EBAY...
  • Anonymous Jan 03, 2009
    I'm going to return mine. This shouldn't be this difficult for a simple LCD TV. What gives?
Same problem. crazy.
Posted on Sep 21, 2008
The color red wont work on my tv
If Dish is providing signal via the COMPONENT input on the set look for a loose or bad red cable--hint in this case swap red cable to green or blue and if loss of color is now different--bad cable or output connection from the box.
Set (we are fond of saying this) does not know what is hooked so if one color missing and good with DVD etc it is a problem in the hookup.
I got paid triple to go to one house (nearly 80 miles each way) as set was under extended warranty for exactly this issue---red plug (component) coming out of the box was part way out.
Apr 18, 2012 | Televison & Video
I have a flat screen and Dish Network for my cable. I switched the "source" to watch a dvd, and when I switched it back to channel 3 I have a blue screen. cable (dish network) is on and working....
It all depends on how your dish cable is connected to your television. The possibilities I can think of would be by composite cables (not HD)--these cables are the yellow red and white combo. It could also be component--the video cables are the blue, green and red. The other possibility is a single HDMI cable which looks like a rectangle and delivers both the video and the sound from the cable source to the T.V. as one cord. Depending on which of these you are using to output the signal from the cable box to the T.V. will determine which "source" you should select when trying to watch tv. Hope this helps!
Aug 25, 2011 | Niko Televison & Video
My tv is not getting the signal from my direct dish.Just says no signal. I contacted direct and we tried several things via phone. They said the problem is with my tv not the dish or receiver. Nothing has...
Tries tv and the dish box unplug,replug it back an hour later for the tv to do a restting itself back to the factory setting and dish box to reboot and upgraded it software.This no signal problems should be fixed,not request another dish box for the replacement,because tv have no signal input bouncing around in the tv screen it is 90%-95% are broadcasting receiver boxes for tv incomming signal cable for tv signal problems.
Jun 27, 2011 | LG 37LC7D 37 in. LCD HDTV
LD4088 LCD will not play sound via HDMI cables. Component cables are fine. Hear a faint "click" from speaker when switching to HDMI input. Have tried all three HDMI connectors and have tried...
This is how AUDIO works in HDMI setup, you can select the source to send the digital audio along with the digital video through HDMI, the receiving end HDMI sound setup must be set to receive the digital audio through HDMI. Otherwise the audio may be sent and received through analog audio ports (Red (Right channel) and White (Left channel) RCA jacks) in stead. Most of the new TV and DVD player use auto detection.
So please check the HDMI audio setup to see how the audio signals are set to be processed.
Please leave rating if it helps.
Jan 14, 2011 | Apex Digital LD4088 LCD TV
Okay i have a digital labs 19" LCD HDTV/DVD and it works fine until you hook it up to an antenna cable, then it wont give channels when i auto scan. what should i do? buy a new cable or is it the tv
I have the same problem. Seemed to work fine with digital cable, but after switching to Dish Network, no luck. If I plug the AV cables (red/white/yellow) directly into the dish receiver, it works fine. The problem happens when I use it as a second TV connected via the RF cable wire. My only guess is that the dish receiver transmits the signal to the second TV via NTSC ... and the Digital Labs TV only supports ATSC and QAM. Hoping someone can confirm?
Jan 05, 2010 | eVision Televison & Video
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
Tv has sound but no picture.
If it works on DVD but not on your Dish, and when you connected it to another house it had the same problem then it sounds like your input connection is bad on the TV. That is if I am understanding this right. From what I am reading your Dish network is not showing a picture but the audio is working fine. The DVD player works fine on the TV though. Then you took the TV and hooked it to another dish system and it was the same problem. That sounds to me like you TV is having a problem, either that or the cables for your Dish network are bad. Try switching to a different input, like the one the DVD player is on and seeing if it works there. If not, then the cables are bad and you just need to replace the cables. If it does work though where the DVD was working before then your TV input is bad on that port you were hooked to before.
Let me know if you have any other questions and if this was helpful. If you need some more clarification let me know, I hope this is helpful. Good luck and have a good weekend. Get it fixed before the Super Bowl.
Jan 25, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
"No Signal" on Memorex 8" under the counter LCD TV/DVD
I have the same problem ! Please email me at kll5@njit.edu if you have a solution!!!!
Oct 18, 2008 | Memorex MLTD2622 26 in. LCD TV
No Sound In Home Theater with Dish HDTV DVR Dual Mode Remote Connection
HDTV is not carried via coaxial cable from tuner, you need HDMI or the 5 RCA cables that are different colors. I forget if they are called component or composite, I think they are called composite, the R and W are sound. If you run the HDMI or composite cables to your TV, there should be a variable out or audio out on the back of the TV that outputs ANY sound coming into the TV, like Wii, DVD, tv, etc. So if you want to listen to tv sound, just pipe the audio out to the receivers available input and turn it up. Cant be used with mag input (turntable) all others are compatible. Did this answer your question? Sat cables are usually kept under 130 ft from the dish, and the dish receiver can output coaxial signal over 400ft on RG-6 cable. HDMI is limited and can get very expensive. Does your sat box have a coaxial digital out (orange RCA) you can use that if your receiver can read it, usually associated with the DVD input or video input, but only for digital encoded programs.
May 19, 2008 | Insignia 5.1-Ch. Home Theater System with...
155 people viewed this question
 Grubhead
Grubhead
