Question about Philips BDP9000 Blu-Ray Disc Player
I have a Philips bdp3000 bluray player but have no remote what universal remote will control this for me.
SOURCE: Remote Control for Philips DVP 320 DVD Player.
I guess, the easiest way to go is to get an universal remote control and try codes from the provided list until you run into a working one. Many universal remotes have a mode when you can try to click tens or hundreds time on a button (like UP button) until it accepts the code.
Posted on Oct 15, 2007
Gigatech
  • 259 Answers
SOURCE: Philips PM3S - 3-Device Universal Remote Control
Here is your product manual:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000053128.pdf
It includes the codes2.gif for your remote. :}
If you dont see your product on the code2.gif list try a code search. If this fails your remote might not support your device.
Posted on Dec 17, 2007
aprmaejun
  • 97 Answers
SOURCE: philips universal tv remote not working
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
Thisis the user's manual for a Phillips remote control. There is a list ofcodes in it. They should be rather universal. There's also instructionsas to how to program it. I believe that there is a way to program itwithout using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.Press the Channel Up button repeatedly (up to 300 times) until thedevice could be controlled changes channel. The red indicator blinks,then stays lit. If you accidentally overshoot the code required, pressthe Channel Down button to backtrack through the library until thedevice changes channel. Pressing Channel Up changes direction toforward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jul 29, 2008
  • 138 Answers
SOURCE: My Remote Doesn't Work
Contact universal remote and see if they have a code for the unit. 919-573-7854
Posted on Aug 20, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
What's the best universal remote app for my Philips Bluray DVD player?
In fact, it will be difficult to get a universal remote control for a blu-ray player; whatever its brand may be. You can get a URC, which will be compactible with its CE and DVD regions, but not with the Blu-ray region. Even though, some manufactures claim that their universal remote control will be comactible with blu-ray region too. But; I'm not sure about it.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Good Luck
Feb 29, 2016 | Philips Televison & Video
How to update firmware on a plilips bluray player
hope this helps
http://www.p4c.philips.com/cgi-bin/cpindex.pl?ctn=BDP3000/05&dct=QAC&faqview=1&refdisplay=C19_BDPXXXX_003&refnr=0073435&scy=GB&slg=ENG
Jul 24, 2014 | Philips BDP3000 Blu-Ray Player
My roc8507 wont pair sitt my bluray Philips player, ive tried every metod and code
You can't pair its blu-ray region with no remote control. This is true to all blu-ray players. You can pair its DVD region with a universal remote control. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
May 13, 2014 | Thomson ROC8507 - Universal 8 in 1 Remote...
I have home theatre system/blueray player w/o a remote and I was wondering if the remote I bought was going to work and how I set it up
You can buy a universal receiver remote and follow instruction in manual book to set up with your home theater / Bluray player.
I recommend to buy a same brand universal remote with your home theater system so it will easier to pick up signal form your receiver.
OR you can contact to manufacturing of you name brand receiver to buy directly from them a new remote for your home theater system / bluray then you don't have to worry about set up
Feb 25, 2011 | Philips Audio Players & Recorders
I need the remote control code (for onkyo receiver
Philips Blu-Ray player codes for Onkyo universal remotes are: 33007, & 33016.
You can download Onkyo universal remote codes with instructions here.
I hope that helps.
Jan 23, 2010 | Onkyo TX-SR605 Receiver
Update sofware via usb for bdp3000 bluray model
down load it from the manufacture onto a flash drive. unzip/read directions if needed, remove all dvds from unit, plug the flash drive into the usb port, and follow the on screen promps. now you can watch all the "new" Blue Rays ( this works on 90% of the dvd players too If you don't have a usb port get the update that goes on a data dvd ...follow those instructions
Nov 26, 2009 | Televison & Video
Bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I didn't have to mess with universal remote control codes or anything.
Hope that helps.
Jun 17, 2009 | Sony BDP-S300 Blu-Ray Disc Player
I need the code for a Philips SRU3006WM/17
Codes listed for Sony DVD players are 0300,0400,0500,0541,0200,0540. Hope this helps due to no listing for Blu-Ray players.
Mar 29, 2009 | Universal Remote Control 6-Device...
Philips BDP9000 Blu-Ray Disc Player Logo
143 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
