Question about Westinghouse Computers & Internet
I have a westinghouse monitor model #LCM17v8 and the screen gets going white after 20 min. It will turn back on. What can I do? new monitor? upgrade?
    Genius:
  • 1,478 Answers
If you turn the monitor off then about 20 minutes turn it back on and have a picture for twenty minutes again it sound like the power supply in the monitor. but if that did not solve the problem, the picture board on your monitor is bad, since it goes off after every 20 minutes and the power led or button is on, it means the picture board of your monitor has developed fault and will need to be replace.
I advice you replace the picture board on the screen of your monitor to solve the problem of the blank screen.
Take care.
Posted on Aug 27, 2010
White screen after about 20 minutes of operation
key words above, (change(d) PC) did you mean you changed out the PC, and it fails, I will guess yes) as in past tense?
old old , 1710s, most are now dead, you know that right?
all have CCFL tubes in it.(problematic for sure)
and had a sleep mode inside, (problem 2) sure.
so with PC turned on, the push the menu key
and turn off the sleep timer, keep it off for ever.
it is not compatible with NEWER PCs at all.
the Monitor is bad,
if cable and pc are ok, the monitor is bad.
you proved that, if change = changed. above.
like this. (GO LED !) avoid all monitors older than year 2010 !
https://www.walmart.com/ip/Asus-LCD-VS197D-P-LED-Backlight-18-5inch-Wide-1336x768-50000000-1-5ms-VGA-Retail/20701019
Nov 06, 2017 | HP L1710 LCD Monitor
NEC Multisync LCD 2080UX has a strip that appears on screen after 20 mins use.
Might be from overheating, monitors do overheat sometimes. I had the same issue happening to one of my old monitors and it wasn't fixable unfortunately. I had to replace it and get a new one.
Nov 05, 2013 | NEC MultiSync LCD1810X 18.1" LCD Monitor
When i turn on my westinghouse 17" LCD monitor it will have a sharp white bar appear through the screen in various sections then blotch out to completely white, after i let it warm up for about 20 minutes...
Hi
Well that's the age old question. Is it worth repair? The problem is probably 6 capacitors in the power supply that have aged significantly. In my shop those caps would run approx $2.00 each with a total labor charge of $50.00. Now whats the charge where you live? Then you can decide if it's worth a $62.00 repair or a new monitor for $150.00. Good luck
Mar 13, 2010 | Westinghouse Electric LCM-17v2 17"...
No image on monitor model LCM- 19v7
Look for bad capacitors (bulging top/seal) in the power supply first, post back what you see inside so we can guide you further, see example of failed Westinghouse monitors due to bad caps; http://s807.photobucket.com/home/budm/allalbums
Mar 13, 2010 | Westinghouse 19" Widescreen Flat Panel LCD...
MY SCREEN ON MY LCM-17v8 MONITOR TURNS COMPLETELY WHITE AFTER FIVE MINUTES!
Generic problem for all Monitors Benq lcd Displays only white var g_tryMail = 0; MessageRate.ThreadID = 421124; MessageRate.ProductID = 689784; function addthschng() { if($i('at_email') != null) { addthis_sendto('email'); } else { g_tryMail++; if(g_tryMail Report abuse shared by 2 users posted by MatrixNet on Mar 02, 2008
I have a BenQ FP791 17 in LCD. I was working until one day I turned it on and it now only displays an all white screen. I plugged it in to another computer, same problem. I can add it as a second monitor to windows but all it displays is white. Windows finds it and the mouse can move over to it but I do not see anything. I am handy with a soldering iron, but not nessisarily diagnosing electronic problems.
Comment posted on Oct 26, 2008I ended up replacing the bulging capacitors on the board inside, and now it works. Thanks for all the comments and help.
Feb 20, 2009 | Westinghouse 22" Widescreen LCD Flat Panel...
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Screen goes black.
It's a hardware defect. you can't repair that. if your monitor in under warranty you can go for repair.
or repair it through any good local vendor.
Nov 23, 2008 | Westinghouse LCM-19v1 Monitor
Westinghouse lcd monitor 19" - screen turns white
I have the same problem with my LCD tv... The DVI-D (white connector in the back) and the D-SUB (connector on main-board next to the DVI-D) work great for my computer. However, the antenna returns only a white screen no matter what I plug into with it using a coaxial cable. Judging by the modular configuration on the TV (1 main board with LCD monitor attached to it and the 2 computer inputs, and a smalled board on the back with the antenna, component video, S-video, mini-jack out, and composite video.) I think the smaller board which I believe is called a "NR Unit" is what has failed. I took off the back mini-panel of the TV off, which just slides off when you press down 2 tabs. And, I found the small board which is only held down by 5 small screws, and it pops right off. So, if you can find a NR board from westinghouse that works, it's a quick and easy (hopefully inexspensive) replacement. Hope this helped.
Oct 13, 2007 | Westinghouse LCM-19v1 Monitor
Computers & Internet Logo
54 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
cxbxr_3
cxbxr_3
Level 1 Expert
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
