Question about Canon CanoScan 3200F Flatbed Scanner
How do you open case to clean inside of glass
Lock the carriage first! Remove the two medium-sized Phillips screws under the hinge and the small one over the small plastic cover plate. Remove that cover plate. Slide the top tray (glass and cover) off the frame by pulling laterally in the direction of the hinge. It will snap out if you work on it. Clean the glass. Slide tray back in and seat it securely. Put the large screws in to hold the carriage. You won't be able to screw them in if the cover isn't seated right. Now make sure the 5-conductor ribbon cable that is under the small plastic cover plate gets stuck back in the socket. You just push it into the tiny black socket. I think that tells the scanner what's going on with the cover. Then reinstall the cover plate. Now you should be good to go! Don't forget to unlock the carriage.
Posted on Jan 10, 2011
  • fixya981559 Jul 09, 2011
    After removing the small hinge over the plastic cover plate, be sure to CAREFULLY remove the ribbon cable from the connector, or else it might break when removing the cover. Some units have a piece of double-sided tape on the glass by the buttons to help keep it in place. If you can't easily slide the top tray away from the buttons, carefully pry the top loose starting at the hinge side to make it easier to break the glass free from the tape.
    For streak-free cleaning, use glass cleaner and a piece of newspaper to rub the glass. The newspaper won't leave any fibers behind that would be magnified when scanning at higher resolutions.
2 Suggested Answers
IrishDruid
  • 2712 Answers
SOURCE: HP Scanjet 3400 C
Unfortunately, The 3400 series cannot be cleaned on the underside of the glass. Scanners with the capability of having the under side of the glass cleaned are listed below.
Posted on Oct 04, 2008
How do I clean inside of glass on the door
Since "open the oven" feels like an obvious answer, I'm going to assume you mean the interior side of glass on a double-paned window to your oven.
If this is the case, you are going to have to break the seal along the outer and inner windows to remove them. Unfortunately, without specifics on the oven's construction, this procedure could vary. I'm surprised the inside of the glass became dirty, which may lead to you finding a bad seal anyways which may need replacing.
Oct 02, 2015 | Ovens
Pictures scan with a dark line
Hi ,
can you please specify your printer model for more appropriate solution Buddy!..Thank you!..
Jul 19, 2008 | HP Office Equipment & Supplies
Tip
Never open the scanner case stopped me from having a go. But the dust is on the...
Steps how to clean scanner glass
1. Unplug the power cord.
2. Clean the outer case with a cloth dampened with a mild detergent and water.
3. If the document table glass gets dirty, clean it with a soft dry cloth. If the glass is stained with grease or some other hard-to-remove material, use a small amount of glass cleaner and a soft cloth to remove it. Wipe off all remaining liquid.
4. Ensure that there is no dust on the glass of the document table. Dust can cause white spots in your scanned images.
*** CAUTION: Do not press on the document table glass too hard.
5. Be careful not to scratch or damage the document table glass, and do not use a hard or abrasive brush to clean it. A damaged glass surface can decrease the scanning quality.
6. Never use alcohol, paint thinner or corrosive solvent to clean the scanner. These chemicals can damage the scanner components as well as the case.
7. Be careful not to spill liquid into the scanner mechanism or electronic components. This could permanently damage the mechanism and circuitry.
8. Do not spray lubricants inside the scanner.
9. Never open the scanner case.
***NOTE: Wipe the inside of the document cover and the scanner's document table before scanning transparencies.
on Aug 21, 2008 | Epson Perfection V200 Flatbed Scanner
Tip
How to Clean Scanner Glass
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Clean Fungus from glass insides
open scanner case, clean glass and reassemble.
Mar 13, 2009 | Acer S2W-4300U Flatbed Scanner
How do I clean the INSIDE glass/platen?
You mean the inside of the scanner glass? (The platten is a part of the print unit),
You'll have to remove the sides and read cover. Unplug the scanner wires and remove the scanner assembly. Separate the document feeder from the scanner bed. Open the covers of the scanner bed (usually there are screws holding it together). Remove the glass and clean it. Reverse the process to reassemble.
Be careful. Canon multipasses are built a little like a Chinese puzzle box. There are little snaps everywhere as well as screws. Watch out you don't force anything and cause the snaps to break.
Nov 05, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Cleaning the scanning glass
Hard to get a smudge inside but basically you take it apart and clean the inside of the glass
Aug 31, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Scanjet 3400 C
Aug 03, 2008 | HP Scanjet 3400c Flatbed Scanner
Cleaning inside of glass scanmaker 4800
OK Just Stupid (G).... Open the lid, pull it up and off and you will see two screws below the hinges. If you have decided to purchase another scanner already, you are clear to proceed. Take these out, pry the halves apart until you hear a click. Push the upper section toward the control panel and the will come apart like a freshly caught oyster.
I would not only clean the inside of the glass, but would get a can of compressed air and blow the heck out of the area below the black thing. This should get most of the dust off of the mirrors (3).
I took mine apart and cleaned them, but, if you had problems opening the case, I definately would not try taking this assembly apart. It'll make you cuss.
Dec 19, 2007 | Microtek ScanMaker 4800 Flatbed Scanner
Clean Inside Door
dont wory kishk help is at hand ,im a profecional oven cleaner ,and would in almost all cases be able to strip the oven door for cleaning .and it want cost the earth
Jun 08, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Canon CanoScan 3200F Flatbed Scanner Logo
815 people viewed this question
old marine
old marine
