Question about Kenmore 62802 Electric Dryer
No heat from dryer 62972101. checked thermistor, element, thermostat and fuse. what could be wrong
  • gerlitz Aug 27, 2010
    Thanks a lot .the info helped.
    gerlitz@sasktel.net
    President:
  • 3,773 Answers
Check your voltage at the wall. A dryer will run on 110 but
not heat.
Also wiggle the timer but you need an ampmeter hooked up
when youn do this so you can see if you are connecting .
The needle will jump when you wiggle the timer then you know
that the timer is not making good connection.
Split the 220 ser cord and put the ammeter on one of the legs
not the middle ground. This will also let you find any shorts in anything elect.
Turn the timer fast and hard also when you are hooked up to the
ammeter. Don't forget to watch the needle.
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Posted on Aug 27, 2010
  • Leo Ponder
    Leo Ponder Aug 27, 2010
    Let me know if you need further help
    30 years Experience in Home Refrigerator,Washer,Dryer, A/C Repair
    I would love to help you find a solution.
    Leo Ponder
My dryer, a Whirlpool LER8648LW0, has stopped heating. It will turn on and run through the cycles but only blows cold air. Today I checked the thermal fuse, both thermostats, and the heating elements with...
Hi Jesse
Here are a few things to check:
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor/thermal fuse one at a time by removing the two wires and taping them together with electrical tape.
If the coil heats up then replace the thermostat/thermistor/thermal fuse as it is faulty.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,
then you do not have to tape the wires together as described above.
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST AS THIS COULD CAUSE A FIRE BECAUSE YOU HAVE REMOVED THE SAFETY.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset.
You can test it with an Ohm meter or continuity checker, remove both wires from the thermal fuse and put the test probes to each of the ends of the thermal fuse, if no continuity then replace the thermal fuse.
A vent clogged with lint can cause it to overheat.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace a generic element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Bud
Oct 10, 2013 | Dryers
No heat
Hi abbey
Check your Wiring
Check to make sure you heating problem is not a lint build up in the discharge hose or inside of the dryer venting system,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the heating element/thermostat/thermistor due to overheat.
You should read continuity across the terminals, if you do not read continuity you will need to replace the coil as it is faulty.
Try to run the dryer, if it runs and heats up then replace the thermal fuse/thermistor/thermostat.
If you have an ohm meter then you can test the thermostat/thermistor/thermal fuse,then you do not have to tape the wires together as described above.
But do not trust the ohm meter all the time, because sometimes it will give a false positive that the fuse is ok when in reality it is faulty.
DO THE FOLLOWING TEST:
To test your thermostat/thermistor/thermal fuse remove the wires from the thermostat/thermistor/thermal fuse and check the fuse/thermostat,thermistor for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
This test of the thermal fuses,thermistor,thermostat, will show if the thermal fuse,thermostat,thermister is really faulty or not.
Check your blower wheel to make sure it is secure to the shaft and not plugged with lint,socks,etc. If you have to replace your blower wheel it will remove clockwise as looking at the blower wheel. You will have to hold the belt end of the motor with a vise grip pliers or maybe the shaft of the motor has a notch cut on it for a wrench to fit.
If you do not have a volt/ohm meter then:
DO THE FOLLOWING: Remove the wires and tape them together and try to start the dryer.If the dryer starts then replace the fuse.
Right after replacing a dryer element, always run the dryer on air fluff/no heat, and go outside to verify there's plenty of air coming out your vent system.
Please take time to rate me
Bud
Apr 12, 2013 | Kenmore 80 Series Heating Element -...
I have model 417 88042 700 Kenmore Electric Dryer and I think the heating element is out. Where can I find a replacement or how can I ensure the heating element is the problem?
Hi James
Check your Wiring
Bud
Try these websites for parts: http://www.appliancepartspros.com/index.aspx
http://www.partselect.com/
Nov 26, 2012 | Dryers
Dryer runs but no heat
Hi jmacc_jaffha
I am also including a link for parts and breakdown/schematic of your dryer.
Check your Wiring
Bud
http://www.appliancepartspros.com/parts-for-model-kenmore-11084832201.html
Oct 24, 2012 | Kenmore Sears 110.84832201 Dryer Heating...
I have replaced termostas and replaced heating element and the machine gone cold again
Hi tony royce
Check your Wiring
Bud
Oct 22, 2012 | Whirlpool AWZ7303 Electric Dryer
My kenmore dryer elite h3 or h4>>>>> is not making any heat....what wrong and how do i fix?
Hi krigas73...
Check your Wiring
Please take time to rate me thumbs up
Sep 24, 2011 | Kenmore Dryers
My roper dryer won't start unless i find just the
Hi jodiew0228...
Sounds like you have two problems
1...Bad timer...replace your timer
2...Something wrong in the heating circuit...
Check your Wiring
Sep 16, 2011 | Roper Dryers
Will not heat, replaced heating element kit. still not heating
Hi denise bobby...
Check your Wiring
Sep 11, 2011 | Dryers
I've got an electric dryer (GE Model #DWSR463EG7WW) purchased Apr. 2010. It is tumbling but is not heating up. Any ideas for what could be wrong? We've turned the circuit on/off and that didn't...
Hi Zippy478...
Check your Wiring
Sep 01, 2011 | Dryers
MI have a Samsung DV330AEB dryer that is 1.5 years old. The dryer is running but is not heating up. We checked the vents and everything seems fine. What could be wrong?
Hi slank4d...
Check your Wiring
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape.
To test your thermostat/thermistor/thermal fuseremove the wires from the thermostat/thermistor/thermal fuse and check for continuity, if you DO NOT have continuity then replace the thermostat/thermistor/thermal fuse.
If the thermal fuse overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it.
Jul 25, 2011 | Samsung DV330AEB Dryer
Kenmore 62802 Electric Dryer Logo
223 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
