Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Where is the oil drain plug on the Briggs 24 hp V twin engine?
3 Suggested Answers
mowerman1857
  • 389 Answers
SOURCE: Briggs and Stratton 22hp v twin OHV smoking badly
First thing to do is pull your dipstick and check for broken or missing O-ring also as you pull it, look to make certain that it was seated properly and all the way locked. If either condition exists, you will be leaking into the crankcase which will cause your symptoms
Posted on Sep 14, 2009
SOURCE: briggs & Stratton 18 hp v-twin engine surges
I put a new carburator kit in a Briggs & Stratton 18 HP Twin. But did not replaced the needle nor the new seat that came with kit, because I did not know how to remove it and did not to damage it. now the gas over flows
Posted on Nov 06, 2010
Oil issue
try running the engine for 10 minutes then remove the drain plug. The sump oil is burnt to almost tar from lack of service or badly worn rings allowing combustion fire into the sump
Jun 01, 2013 | Tools & Hardware - Others
Briggs & Stratton 18 hp motor oil white
White oil in any motor indicates the oil has mixed with water . Drain the oil change the filter and find out how the water got in.
Oct 01, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
Wheres oil drain on 21 hp intek briggs
you should have a square plug on the side of the block usually on the starter side of engine
Aug 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
WHERE IS THE OIL DRAIN PLUG 0N 22 HP INTEC
Here is a link showing you parts layout that includes the location of the oil drain plug:
Page 8 discusses changing the oil
http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=ioswDLJU0HtjhJvcv4
I hope this helps,
Magoo
Mar 08, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs 24 hp twin v intek engine, started smoking last year with only 50 hours, now with a little over 60, it smokes like a steam train and uses 1 qt oil/30 min. Last week it fouled a plug, I...
Double check that the head bolts are properly torqued.There is a crankcase breather if stuck open could be drawing oil into the intake, and there is a valve stem seal on each intake valve that could be leaking. All this is assuming that the oil level is not over full. They will smoke like a banshee if they have to much oil in them.
Oct 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
What engine oil is recommended for the Intek 24 hp OHV engine? Will a multi-grade oil work?
multi-grade will be fine it realy dont need a pricy oil in it this kind of engine will run on dirty cooking oil,,with or with out the chips still in it?
Mar 29, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
335 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
