Question about Refrigerators
I have a Kenmore Coldspot 106.56663500 and it is no longer making ice. The tray will fill with water and freeze, but it doesn't dump. I took the whole assembly out, ran some warm water over it to melt the ice thinking it was just 'stuck'. That didn't help, got any other ideas. Thanks alot, Todd
  • 1314 Answers
SOURCE: kemore coldspot no ice?
no you ice it is on a separate valve as the water in the door so the water flow don't mean a lot in this case remove the front plastic cover on the icemaker and you will see a bunch of little holes make a jumper wire out #10 or 12 house wire strip about 1/4 inch off the ends an insert in the holes marked t&h this will start a test cycle make sure you hold the plastic insulation so you don't get bit if the ice maker starts cycling remove the wire and watch for it to stop listen for the icemaker valve to open if the ice maker finishes and the valve didn’t fill replace the water valves if the icemaker doesnt cycle and you may have to kind of twist the jumper back and forth to get it to make contact depending on the gauge you used then replace the ice maker motor module if you hear the valve open and the ice maker doesnt fill check for a frozen ice fill tube that should do it
Posted on Mar 28, 2008
  • 489 Answers
SOURCE: Ice tray sometimes stuck when dumping off ice
Your icemaker tray has an update for the water flowing over the tray.  You will need to call a qualified LG technician to get it replaced.  Also, the tray is twisted because it binds itself against the hinge pin on the left side.  To stop this, spray some cooking spray oil in the left hinge pin and it should unbind itself and return to normal.
Posted on May 11, 2008
  • 6 Answers
SOURCE: kenmore coldspot 106.556325 not making ice
could be your ice maker or your water valve
Posted on Aug 30, 2009
  • 106 Answers
SOURCE: Kenmore Coldspot #106.9750610. Icemaker does not
restricted water flow or pressure from house water where your taped into. your shut off or Tap a line may be cloged or if you have a water filter its cloged. It could also be a bad water valve in rear of refrig. start at the sourse of water and work back to frig. A rare thing could be that the timing gear on the ice maker is burnt and not trigering valve long enough to fill icemaker
Posted on Oct 30, 2009
TheMobilian
  • 8220 Answers
SOURCE: Kenmore Coldspot not keeping cold. Ice in freezer
Look underneath. Thecoils should be clean and the fan motor running. and no clicking from any compressor relay either.
Posted on Jan 08, 2010
Kenmore 795.5102 will not make ice
The problem is the ice maker, the modular head of the ice maker has broken, hence the clicking sound and the raised arm stuck up. You will need to have an accurate model number and contact a local parts distributor for a new ice maker. It is a simple repair usually only 2-3 screws.
Apr 25, 2012 | Kenmore Side by Side Refrigerator
Why has It stopped making Ice
Is the ice maker getting water ?
Is the wire that senses that the ice tray has filled up down in the empty tray or up in the off position?
Is the freezer section cold enough to make ice ?
Is ice in the tray waiting to be dumped or water in the tray that is not freezing or is the tray dry ?
how can we answer when you give us no information.
Nov 26, 2010 | Kenmore 53092 / 53094 Side by Side...
Kenmore by Whirlpool sxs water in the door. Ice maker 106.565424
The water control valve for the ice maker side is your most likely reason. If filling ice maker with tap water and allowing to freeze. If it dumps then the water control should fill. if not the valve is not working. Sea Breeze
Oct 16, 2009 | Kenmore 57029 Side by Side Refrigerator
Kenmore coldspot top freezer auto ice maker, water
Dear customer,
               We suggest u to perform the following checks to solve ur problem...
  1. Check the refrigerator for level
  2. Check the ice maker for level
  3. Inspect the fill cup alignment
  4. Inspect the water supply line
  5. Test the water inlet switch
  6. Test the water inlet valve
  7. Check the shutoff arm
  8. Test the shutoff switch
thank you..
Apr 08, 2009 | Kenmore Refrigerators
Trouble with ice-maker
Either the inlet valve is stuck or the icemaker solenoid is shored.
Most likely the second one.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Sep 30, 2008 | Kenmore 52632 / 52634 / 52639 Side by Side...
Kenmore Coldspot not making ice
sounds like the flap that u can usually hear once the ice has stoppped coming out it sounds like a pop or thud ...what happens is the magnet goes bad and keeps the ice maker constantly open to the outside air causing ice melting and massive ice cubes.....usually a costly repair...check and lemme know
ps. id have a licenced repair guy check it out
Ice maker not dumping ice
The freezer has to reach a certain temp. in order to freeze ive. You might have to wait overnight for ive-- keep the freezer closed.
Aug 27, 2008 | Kenmore 53642 / 53644 Side by Side...
My Ref.wount make ice
I have a friend who has a kenmore coldspot Model# 7028999 Serial # EJ5040321 and it won't make ice there is water to the coldspot from the angle stop. A new pump was acquired and installled, but no water reaches the ice cube tray area. When ewater is poured into the ice cube tray area by hand, the ice cubes are made and the machine dumps them into the ice holder. What is the reason for no water from the angle stop to the ice tray? could there be an electric switch in addition to the pump device? Bob 512-762-4585
Apr 26, 2008 | Refrigerators
Refrigerators Logo
111 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
